Question about Garden
I need to know what the chain lube adjustment is on a Stihl 028. It is slobbering chain lube oil
SOURCE: stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
Posted on Apr 24, 2009
Dolfoff
  • 148 Answers
SOURCE: tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
dontbother10
  • 2220 Answers
SOURCE: owners manual for a Stihl 034 AV Chain saw
Stihl Manuals
http://www.stihlusa.com/information/info_product2.html
For an IPL you must contact them.
HTH
Lou
Posted on Oct 19, 2009
dontbother10
  • 2220 Answers
SOURCE: i need a fuel hose diagram for a stihl model 028
Stihl IPLs (exploded parts list) are propriatary, You can request one here: The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but on multiple illustrations.
http://www.stihlusa.com/contact.php
Typical Fuel System (Primer Bulb and fuel lines may not apply)
http://www.img4free.com/images/Lou98321/fuelsystem.jpg
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Posted on Dec 24, 2009
dontbother10
  • 2220 Answers
SOURCE: oil does not lube chain on my chain saw, huqvarna, any ideas
It appears from the IPL and OM this saw does not have an adjustable oiler.
OM example here (2005 - may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_O0501001.pdf
IPL example here (2005 - may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2005/I05000/I0501901.pdf
I know you have done this, please verify whether or not you get the ooze with the saw running.
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL). I am seeing many non-adjustable oilers malfunctions, please contact Husky, there may be an unannounced repair.
HusqvarnaUSA Contact Us.com
http://www.husqvarna.com/us/homeowner/support/customer-support/
If you try the repair yourself it has an outboard clutch (oiler behind it), this will help with removal. Your IPL is also beneficial.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
The OM and IPL links I provided may not be your saw. If not yours can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; black numbers on silver tag 90s; silver numbers on black tag 80s)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Feb 28, 2010
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Stihl 028 av super not oiling
Part of the routine service while sharpening the chain and adjusting the chain tension is to remove the guide bar to clean the slot and to clean the side of the saw case of any and all impacted crud. This impacted crud many times inhibits the oil flow to the bar causing it to appear as though the oiler is not oiling. Make sure you clean the discharge port of the oil pump...it will be the opening that aligns with a slot in the bar to transfer the oil to the chain.
After cleaning and reassembling, start the saw and rev it up for 2 to 3 seconds and observe the bar tip as it is aimed against a clean piece of cardboard. If the oiler is working, within this time frame, a thin film of oil will appear as it is slung off the bar tip.
Nov 25, 2015 | Stihl Garden
Chain oil is not flowing through to lube the chain
Remove the side case on the chain clutch, remove the bar and chain, clean then oil ports thoroughly, clean the chain bar completely. Empty the chain oil tank and flush it with gasoline, there's a filter in the tank the gas will clean it, put it all back together and it should work fine. I've used Stihl for 25 years and never had any other problems with the chanin oil system.
Aug 20, 2014 | Stihl Garden
Where is the oil adjustment screw on the stihl 028 AV
Most Stihl saw have the adjustment screw on the bottom of the saw. The ones I've seen have an E mark which the factory setting. Turn the screw clockwise to increase the oil and counterclockwise to decrease it.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 16, 2011 | Garden
Stihl 028 leaks chain oil
Please ,
Remove the oil, fix the leaks and re fill the oil. And check the leaks again
Jan 05, 2011 | Computers & Internet
I do not appear to be getting oil to my chain on my Stihl 028 chainsaw, can you advise me how to fix this ? I thought I may have the chain too tight but having used a chainsaw for many years, I thought it...
Hello Tom;
This is an OM for a Stihl 028. I did not see an oiler adjustment. It does have the "Master Control Lever" and from what little I know of Stihl this is a source of headaches if not used properly. If you are not familiar with it suggest you read everything the manual has to say about it.
http://www.stihlusa.com/stihl_ownersmanuals/STIHL028_with_safety_manual.pdf
Oil System Plugged:
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL). I has a gear driven oil pump but because it is Stihl and they claim proprietatry right you cannot find an IPL on line. You must also find a Stihl dealer for new OE parts.
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
This thread is discussing an oiler falfunction on a similar saw, I think Fish is a Stihl dealer, is very helpful and his advice is proven.
http://www.arboristsite.com/showthread.php?t=121837&highlight=028+oiler
You can get IPLs and if the chainsaw Gods smile a shop manual or two here (please do a search and PM someone that has replyed to a similar request):
ArboristSite Beg for manuals thread (free to join)
http://www.arboristsite.com/showthread.php?t=72322
Lou
Mar 13, 2010 | Garden
NEED NEW CHAIN DRIVE UNIT INCLUDING PLASTIC
The model 028 Stihl Chainsaw was in production for many years and the clutch drum sprocket (or chain drive) came in three (3) versions over the years of production.
For several reasons, it is best to take the saw to an authorized Stihl Dealership (Locate your nearest dealership HERE) for production identification, evaluation of cost-effectivness and availability of parts.
Reason 1) The first-generation 028 saw is approaching 30 years old.
Reason 2) Extreme heat caused by a locked chain-brake can damage the engine case and render the saw unfixable (part support is going away due to age).
Reason 3) The shear cost of parts and amount of time it would take for a DIY repair.
Reason 4) The plastic gears you mentioned are the drive system that make the chain's oil pump work. If the plastic is melted, the oil pump is likely to be damaged as well. In most cases the oil pump cover gets damaged ... the list goes on and on.
Genuine Stihl parts are not sold online and aftermarket parts would be a gamble. It's up to you to decide if the cost, time and effort are worth it.
Hope this helps.
Oct 04, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Garden Logo
130 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
