Question about HP PSC 1315 All-In-One InkJet Printer
Printer keeps getting jammed when you try to print.
SOURCE: printer keeps jamming
snks
Posted on Jul 10, 2008
jackiaria
  • 350 Answers
SOURCE: Carriage jam
Did you try shutting it off, unplugging it from the wall and your computer for at least 1 minute then restarting it ?
Posted on Jan 21, 2009
  • 34 Answers
SOURCE: HP 4200 printer paper jam. No paper is jammed
check this out....when the printer reports the jam, open the paper tray very carefully and slowly.
Has the paper moved at all forward? Has it moved like 1/4 inch to 1/2 inch out of the tray?
If so, you probabaly need a torque limiter, no tools, $10 or so and a very very easy fix.
POBCM is very correct when he points out that the block/stop in the back of the tray moves when the tray is closed with too much force and this is the #1 cause most of the time.
You may see a "41.3" code displayed if the block is not up to the back of the paper and the paper is not all the way forward in the trays, and under the two metal clips at the front of the tray.
Posted on Mar 14, 2009
paand
  • 147 Answers
SOURCE: the printer keeps jamming when i try to print. The
Open the printer casing and clean the paper sensor and the tray . After that clean the rod with iso-propyle or petrol and remove all the dust from the board also.Your printer needs dusting only.Let me know when problem gets rectified.
Posted on Jun 25, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Photo Paper keeps jamming
HP all-in-one printers have had problems printing photos with glossy paper. The glossiness makes the paper stick together and that will trigger a jamb. If gloss paper is all you have, try separating the paper before you load it into the machine. If you continue to have jambs, try a non-gloss paper to see if that alleviates the issue.
Posted on Jul 12, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Paper keeps jamming
dear friend this printer is brand new/ old. if old how much old?
Jun 27, 2013 | Brother MFC 7840W Printer
Printer keeps jamming when i try to print but theres no paper jamming it.
printer keeps jamming when i try to print but there is no paper jam.
May 06, 2011 | HP Officejet J5780 All-In-One InkJet...
It's the top rollers, the paper is too slick to get through them. I'm using HP photo paper, in an HP printer. It needs to do a 180, but gets jammed right where it prints, so the paper never makes it to the ink. It's an engineering problem by HP. I suggest putting a rough surface on the top edge of the photo paper, something removable but rough enough for the printer to pull the photo paper through.
Jul 12, 2010 | HP Officejet 6310 All-In-One InkJet...
Epson R265 the disc print tray keeps jamming
did you align the track? check the tray for any cracks, when you try to print cd's make sure that the printer and cd are balanced in a horizontal or even manner
Sep 12, 2009 | Epson Stylus R265 InkJet Photo Printer
I keep getting paper jam messages when there is no paper jam.
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 23, 2009 | HP Photosmart C4180 All-In-One InkJet...
The paper gets jammed when I'm duplex printing
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 19, 2009 | OKI C6100n Laser Printer
Paper Jam keeps appearing
At the print driver there is a paper size selection before you print.Select the proper size and weight and it will work fine for you.
Jul 27, 2009 | HP PSC 2355 All-In-One InkJet Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
Printer keeps saying paper jam even after all doors are cleared of paper jam. Reset didn't work.
Dear, there is very minor mechanical fault but it is better to visit the repair shop to fix it.
Best regards
May 25, 2009 | HP Photosmart C6100 All-In-One Printer
HP PSC 1315 All-In-One InkJet Printer Logo
24 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
