Question about Refrigerators
How canI test an LG compressor. Side by side
How can I test an LG fridge compressor with a multimeter? Does it work? Does it get enough power? Side by side compressor lower rear w/4 pin wire connector.
    President:
  • Refrigerators Master
  • 1,922 Answers
You can check continuity of the windings, it will not tell you much more of the inner condition of the compressor
Posted on Oct 03, 2009
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
LG Refrigerator side by side suddenly not working at all other than interior lights.
If you're lucky, it's just the capacitor on the motor. Have it checked, but be prepared to need a new compressor.
Mar 10, 2012 | Refrigerators
I have a Kenmore Coldspot m# 57282791. Last night, it stopped staying cold, and I have not heard the motor/compressor come on at all since then (the part that cools the fridge, right?) There is a small fan...
If the compressor is not running, it could be either a bad relay or compressor.This is not an issue with defrost components or temp. control .If you have experience in repairing appliances, could take all precautions necessary and use multimeter - You could do a continuity check on compressor motor and all combination's. An infinity value on multimeter would confirm bad compressor.
On the side of the compressor you will see a box (maybe a cover) remove the cover if it has one and then remove the wire harness. next you will see the relay with the capacitor mounted to it. give the relay a tug and pull it off the side of the compressor. once you have it off pull the capacitor off and then give the relay a shake. If it rattles the relay is bad. if the relay does not rattle the compressor is bad and you will need to call a service guy to replace the compressor.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 10, 2010 | Kenmore 57029 Side by Side Refrigerator
My Whirlpool side by side fridge and freezer not working
Most likely, if you can hear the compressor running, the fan inside the freezer is not working. When the compressor is running, open the freezer and listen for the fan running. If you don't hear it, locate it and, with a voltmeter, test for voltage across the terminals. If you have voltage present, replace the fan. You can buy replacement fans at a local appliance parts store, internet parts suppliers, even ebay.
Jan 29, 2010 | GE Refrigerators
Hi, the fridge side of my lg is not cooling enough. The freezer is fine. The black compressor in the back is extremely hot to the touch. What can I do?
If the evaporator fan stops that is next to the compressor that will cause this. The compressor being so hot does indicate that the compressor is under a load and possibly the fan or the start relay is causing the compressor to cut itself off too many times. I believe you have a sneaky condenser fan stop during its job and causes the compressor to overheat.
Sep 19, 2009 | LG LSC26905TT Side by Side Refrigerator
Samsung RS2545SH refrigerator just stopped making ice. any advice?
Samsung Fridge  RS2545SH stopped cooling. The fridge section is about 50/55 and freezer is around 45. It wont go below. At one point, there was rumbling rattling sound from the compressor. Icemaker also stopped woprking.
Jul 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge is not cold
Side by side cooling units usually have 2 compressors, one for the freezer and one for the refrigerator. The refrigerator compressor may be bad, or not pulling enough power, or there may have been a leak in the tubing that the compressor uses to cool the unit with. To diagnose the problem, be aware of the noises the unit makes, and check to make sure it is a 2 compressor unit. If you only hear one compressor running then your compressor is bad, if you hear one running too often, then your tubing is bad, if the back of the refrigerator side is warm but the inside is not cooling down, then the compressor is not drawing enough power. Keep in mind that the radiant heat from the operational (presumably) freezer side may cause the refrigerator side to appear warm. (usually there is a type of wire backing with tubes running along it, these tubes should be mildly warm.)
Jun 15, 2009 | Samsung RM255LASH Side by Side...
Freezer is cool but not freezing or making ice - fridge not cold
If there is frost on the back wall of the freezer, then the compressor is running. Another (maybe) good thing is the fan is running.
The problem could be -
1) Bad defrost heater
2) Failed defrost sensor
3) Failed defrost timer or refrigerator controller board.
There are diagnostic tests to determine the problem, but require skill at using a multimeter and possibly reading a schematic/wiring diagram.
You can temporarily make the refrigerator run again for awhile by unplugging, opening the doors, and defrosting for 6-8 hours (store food in coolers.). Then plug it back in. Note, water may come out of the freezer as a result of defrosted ice.
Jan 15, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Frigidaire side by side fridge
Power to compressor must be off (about 5 minutes) before a restart should be tried. Some of these relays are thermal and must cool down before power is reapplied.
Sep 04, 2008 | Frigidaire FRS26R4A Side by Side...
Fix it fridge
the compressor does not properly run ,motor valve weak ,test w/ amphere meter if does not match w/label amphere , comp. motor problem.
Dec 31, 2007 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
103 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
