Question about Cobra Radio Communications
Im having prombems recieving what do i need to check? also they tell me im squeeling half way through the transmission.
2547 when turn on has a squeel thru the speaker in recieve mode
hi iff you remove the mic does this squeel disapear ,if so i recomend that you open mic casing and check for any lose strands of wire that could be shortening out ive seen this happen so many times with microphones you can get some switch oil and apply sparingly to switch this will also help in the long run ,,,,,goodluck with it
Feb 11, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
When I put the clutch down it squeals I am thinking it needs transmission fluid but can't find where to put it
I don't believe that you would need more transmission fluid if you have a squeel (but for future reference clutch fluid is located with the brake fluid and uses brake fluid DOT 3). Squeeling is usually a tall tell sign that your clutch or pressure plate is going out. Also for future reference the actual transmission fluid will be on the side of the transmission and should say oil, if not it is usually 3 to 5 inches from the lowest point on the transmission and may take a certain weight (80-90W, 75-90W, etc.
Aug 22, 2010 | 2000 Daewoo Nubira
I need to know where the speedometer sensor is located on the transmission. Thank you for your help Tim Bufford.
its most likely on the top half of the transmission if you look where your half shafts or drive axels come out of the transmission its probably right around there im not sure if the wheel speed sensor in the steering knucle tells the computer the speed and put its to the dash its either on of those
Jan 15, 2010 | 2005 Chevrolet Impala
Dryer making horrible squeeling noise
this is normally a problem with rollers that have gotten dry bearings , take the drum out check the rollers if they turn hard or act sticky you may clean them up and and oil with turbine oil , do not use wd-40 or 3in 1 as these will dry the bearing, check the idler pulley while you have this apart also oiling it if need be
Dec 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Squeeling when driving
Could you be aliitle more specific on where your squeeling is coming from??
Jul 28, 2008 | 1997 GMC Jimmy
Brother fax1020
start by inserting a document into machine and press the copy button. if come out ok then check your phone line to see if it's live and plugged into the right slot marked "L" and not phone. if still not able to fax try to call that number using a regular phone and listen for the high pitched squeeling noise.
hope this helps.
Thank You,
Mikey
Apr 03, 2008 | Brother FAX-1020 PLUS Plain Paper
Canon Fax L220
From previous experience it is a compatability problem stemming from propritary transmission modes. Not sure what model Lanier fax is but they can disable some optional transmission modes first. Otherwise if this person is important you can tell that person to force transmit to you at 9600bps.
May 11, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Radio Communications Logo
37 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
