Question about Garden
Heater is not working fan runs but no fire. - Garden
My 40-FAC heater will not ignite and run. The igniter has been replaced. What should I check next?
These models require electrical power to run the blower fan.
When you connect the electrical cord, the fan should turn on, then you should be able to start / ignite the propane. if the fan does not turn on when you connect the power cord, you will not be able to ignite the propane.
Dec 09, 2014 | All-Pro Propane Garage Shop Heaters - All...
How do I disconnect heater for 2004 Toyota Highlander?
bypass the heater core. 2 small hoses run from the firewall to different locations on the engine (one should be the thermostat housing. dissconnect one hose from fire wall end, and reconnect it to where the opposite end of the other hose is located, creating a loop that does not include the heater core. The remaining hose (one end still attached to the heater core at the fire wall) should be connected to the opposite connection at the fire wall so it can be re-engaged next winter.
Actual problem seems to be the heat damper valve, which restricts water flow into the heater core, easiest fix is reattach the actuating cable to the valve arm (if this was detached) most costly is replace valve assemble/heater core assembly....
Oct 04, 2014 | 2004 Toyota Highlander
Why is this Pool heater making a very loud whistle sound after heater is fired up.
sounds like a leak in the air stack or if coming from gas valve need new gas valve
Aug 28, 2014 | Sta Rite Pool & Spa
I have a All-Pro 115,000 btu multi fuel heater. When first plugged in fan runs, fuel sprays out the nozzle but heater won't fire. Any suggestions?
You probably have already checked this but is the ignitor trying to fire or not working at all ? Just curious. Thank you
Dec 17, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
Will not turn on when set to automatic. when switched to on position no hot air comes out of vent.
If you are talking about the switch on your thermostat, "On" and "Automatic" refer to the fan. In the "Auto" setting, the fan only runs when the furnace is running, in "on" setting, it runs the fan constantly. Your furnace is not firing for some other reason, the on/Auto switch is working properly.
Dec 16, 2009 | Goodman GMS90703BXA Heater
I have a max e pool heater (400k)btu's,when I start the heater,the burners runs for about 20-30 sec.and then trips off,I have jumpered most saftey controls (temp) and have replaced the control mod. and...
You may have a problem with your air pressure switch. This is located in the exaust pipe I beleve. (not positive) But the heater will fire and if the draft is not right it will shut the heater down. Be sure that the heater is fireing not just the fan running.
Oct 04, 2009 | Sta Rite Sta - Rite Max - E - Therm Hd...
Heater fan workiing intermittently
Check your fuses. That would definitely be my first guess. Take one out for the wipers or something time being and pop it in and see if your fan doesn't fire right up.
Jan 14, 2009 | 2003 Buick Century
'92 Lincoln Town Car Heater Fan won't run!
Replace heater blower resistor.located on the passenger side fire wall.I had same problem.New ,$200. wholesale (dealer only)I bought mine off an auto savage for $20. !!!Fan now works fine !!good luch !!
Oct 27, 2008 | 1992 Lincoln Town Car
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
