Question about Singer Inspiration 4210 Mechanical Sewing Machine
I am trying to get my Inspiration 4210 to just sew a straight stich & I can't understand the manual
  • 27 Answers
SOURCE: Singer sewing machine model 2001
The camstack is not changing the stitches inside because of lack of lubrication
Posted on Jan 10, 2009
SOURCE: I have a quantum cxl.
The needle shaft sticks to the curved arm and won't come down because a piece of plastic, about an eighth of an inch thick had broken from age. It prevented the shaft from staying up on the needle arm. Open the cover, try to stitch decorative stitch and see what I mean. Purchase a package of 4-10 by 1/2 nut and bolt pack. Screw the nut all the way onto the bolt. Using needle-nosed plyers, Carefully bend the curved arm slightly, and place bolt into the hole on the top of the needle shaft. Nut will keep it in place. Lowering the needle shaft using wheel, carefully bend arm back in place. Try decorative stitch. It should work. It does for me.
Posted on Jul 02, 2009
  • 244 Answers
SOURCE: need a instruction manual for the Singer 4605 (sewing machine)
http://www.singerco.com/pdf/4228_4220_030707.pdf , try this link; should help with your problem.
Mike.
Posted on Nov 17, 2009
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Posted on Mar 21, 2010
  • 6 Answers
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
How do I put a bobbin holder securely back in a singer 4210?
it just drops in place and sits there like any good bobbin might
Jun 24, 2015 | Singer Sewing Machines
How to remove the bobbin plate?
Download the user's manual from the Singer site, www.singerco.com. It is a free download. Look on page 34, and it will show you how to remove the plate and clean underneath. There are two levers that must be set to release it.
Aug 11, 2014 | Singer Inspiration 4210 Mechanical Sewing...
Singer inspiration thread wraps around bobbin seat while sewing
it sounds like you need a new bobbin case. and it would be a good idea to have the machine serviced
Mar 30, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Singer manual 4210 in english
Go to http://www.singerco.com/accessories/instruction-manuals/search and enter 4210 in the search box. You can download the manual to your PC for free in Adobe reader format.
Jun 22, 2011 | Singer Inspiration 4210 Mechanical Sewing...
When I try to use my Singer 4210 with the feed dogs covered the cover plate pops off.
I was just looking at page 27 of your manual, and was wondering if one of your pins is broken off and that is why it won't lock in place. Take a look at it and your manual and see if that is the problem. Then call Singer at 1-800-4singer and see if they will send you another one. If, it is the first time you tried to use it, I am sure that they will help you for free. It probably was damaged when you got it.
Nov 20, 2010 | Singer Inspiration 4210 Mechanical Sewing...
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. What is causing this? Is the bobbin case in wrong? How is it supposed...
Nov 14, 2009 | Singer Inspiration 4210 Mechanical Sewing...
Singer Inspiration 4210 Mechanical Sewing Machine Logo
64 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
