Question about Thorens Audio Players & Recorders
Looking for dustcover hinge for Thorens TD166
Looking for dustcover hinges for Thorens TD166 series turntable. Any info? Thanks.
SOURCE: Hinges for dustcover of Technics SL1300 turntable
i have dust cover hinges for a sl1300. I bought them on e-bay a few months ago thinking they were for a sl1200.  my email is pauldrumsfunk@sbcglobal.net
Posted on Apr 26, 2008
djproaudio
  • 515 Answers
SOURCE: TECHNICS SL-B280 DUST COVER W/ HINGES
All parts are discontinued for this model. The SL1200MK2 dust cover will not fit this turntable. You can actually have a dust cover made rather simply and cheaply (depending on where you live). Just take the dimensions to a PLEXIGLASS or even a GLASS shop. You can even purchase the Plexiglass yourself, cut it, and glue it together. I would suggest getting it professionally done. You can use any high impact plexiglass. Get something that is resistant to scratches and discoloring.
- DJ PRO LAB
www.DJPROLAB.com
Posted on Apr 30, 2008
THENTHEREWER
  • 131 Answers
SOURCE: td-146 part need
http://audiotools.com/oldlp_z.html
hey arr69,if you will go to the site listed above & scroll down to thorens it has many links for parts & imfo(this should get you started in your search)good luck & hope this helps.thanx for using fix-ya!!!
Posted on Nov 29, 2008
  • 124 Answers
SOURCE: kenwood turntable cover hinge replacement
Yes they can be replaced.
Contact the store you purchased it from or ask where they have repairs done. They should be able to order the parts for you.
Posted on Sep 12, 2009
djredskyy
  • 670 Answers
SOURCE: I am looking for the power supply which I managed
Radio Shack and Music Store maybe even Best buy
Posted on May 20, 2011
Is the dust cover on the Technics SL-B101 , the same as the Technics Sl- D303?
Charles,
It took me about an hour to find this info for you. Problem is that you'd be taking someone's word for it. The answer came from a turntable forum where another person asked what other dust covers fit the pictured turntable (model SL-B303) Several people responded and if you click on this link:
http://audiokarma.org/forums/index.php?threads/technics-sl-b303-dustcover-hinges.348163/ , look at the bottom right hand corner of every response on that page.(they are numbered) and you'll see that #1 has the question about the cover for the SL-B303. Scroll down to response #6.
This person says that the SL-B101 and the SL-D303 use the same cover.
Where did he get his info from? It's a risk but if you find another person that says the same thing, chances are it's the right answer. Wish TECHNICS had some sort of official release so that everyone could see what covers fit which turntables.
Good luck
Jun 22, 2017 | Technics Audio Players & Recorders
Which ports do I use to connect a Thorens TD166 turntable to a VSX D511 reciever, and does it require a pre - amp
Turntable plugs into an RIAA pre amp, (if not fitted within the turntable) then to a line level input on your amplifier.
Mar 27, 2017 | Thorens Audio Players & Recorders
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    Where do I get set of hinges for dust cover of AKAI AP-X1 turntable
    Check on ebay for that tt and maybe someone has parts listed. Or try the manufacturer but if a unit is more than ten years old parts are usually no longer available.
    Nov 22, 2015 | Audio Players & Recorders
    Does anyone know where I can but a hinge replacement hinge that holds dustcover on a Vestax bdt 2600 turntable?
    Vestax went out of business in 2014. I have found a website called Virtual Sounds Technology. They are the largest suppliers of their parts going. They say "if we don't have it, it either no longer exists or can only be pulled from a used unit".
    So your best option is to ask them!
    Mar 28, 2015 | Vestax Audio Players & Recorders
    Dustcover will not stay up. how to adjust? where to find service manual?
    You will probably need a set of Allen Keys. One should fit in the bracket which will tighten up the hinge.
    Aug 22, 2013 | Numark TT100 Turntable
    Td-146 part need
    Nov 28, 2008 | Thorens Audio Players & Recorders
    See: http://djparts.net/technics-parts-replacement-dustcover-with-hinges.html
    Has a dustcover w/hinges... :o)
    Mar 06, 2008 | Audio Players & Recorders
    313 people viewed this question
    Top Thorens Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Ben Armstrong
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a Thorens Audio Player and Recorder Expert? Answer questions, earn points and help others
