Question about Miele WT945 Front Load Washer / Dryer
The clothes are drying complelty, what is wrong, i dont want to call in the techincal people because they want to charge 100 pounds...the close are always damp when they come out of the dryer, even when i put the selection on extra dry! please help -student without clothes!
    President:
  • 1,304 Answers
Check where you dryer exhausrts too
sound like you have a clog in the exhaust line
Posted on Oct 03, 2009
Batteries and card are in and will not come on???
Still when nothing works, you should check the battery (batteries) first.
When you use AA or AAA batteries, never use AA manganese (Zinc-Carbon) batteries.
Always use the same batteries. Make sure you charged all batteries. The best to charge them al in the same charger at the same time.
Also check contacts in the battery holder of camera and the contacts of the battery. Nothing is allowed in the holder, then the batteries. Make sure you did not put in a battery the wrong way around.
When you need to clean contacts, only use a dry cloth. Never ues sharp tools in or close to a camera.
Feb 06, 2014 | Cameras
I have a Kenmore Elite dryer. It is not drying the clothes properly. It takes a lot longer to dry the clothes. One time it dries fast the next time it takes forever. Any ideas??
it sounds like your dryer stat real name t.o.c. you will need a engerneer to do this the job should cost no more then £40 pound ring a round for a call out the cheapperst is not all ways the best ok so make sure you ring 4 to 5 guys just tell them the problem and they should say the same if they dont get back to me and i will try for you see if i can get some one to help you in your area ok
Feb 03, 2011 | Kenmore Elite HE4 Electric Dryer
My usb ports won't work at all is there a way to fix this??
Hi if doing this dont help Settings --> System Settings --> Restore Default Settings
if changing the settings dont get them working then this will mean the usb ports will need replacing sony charge $100 for this fix so its not cheap, i repair them for 25 pound plus parts but im in UK so probably no help to you.
how ever you can charge your controls on your laptop or pc so you can still charge them and use them that way without paying out for the repair.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 19, 2010 | Sony Playstation 3 (PS3) Console
I had a Heating and Air Conditioning Service my A/C unit in my home. I was wondering what is the going rate fro the Freon per pound?
A 30lb bottle or R22 Refrigerant your cost would be $650. As a Licensed Refrigeration Mechanic, I would charge 4 hour minimum for leak check and repair. The hourly charge is $75 and the Refrigerant which is extra to the price is $35 - 40 per pound. As the price of R22 Refrigerant goes up in price as it is being phased out per Government Regulations, you will see $75 - $100 per pound +. As for my pricing, my fellow workers say I charge too cheap. If you take $650 and divide it by 30, it would be $22/pound, but it can only be delivered to you and charged into your unit by a Licensed Refrigeration Mechanic...then the labor comes into effect for all of this. So in an nutshell, if you were charged $30 - $75 / pound , I think you did well.
I hope this clears it up.
Jul 14, 2010 | Whirlwind FH-778 Air Conditioner
The camera won't turn on. I have two batteries, both are charged.
Make sure or check out following thing :-
1) Direction of your battery might be wrong, Check out and put it again.
2) Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust)
3) Check whether Memory Card/Battery Cover is properly closed. 4) Load new or fully charged battery.
5) Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 06, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
The dryer is constantly cold and does not dry clothes. What could possibly be wrong?
On the inside of the drum there is a heater .It sounds as if it has gone. depending on model and age the price and some dryer repairers dont charge a call out free. but always check. They will ask for the model and serial number located on back or in the door. hope this helps.
May 12, 2009 | Dryers
Kenmore HE4 Dryer leaves clothes wet
From the techincal document found in the dryer bottom panel
TEST #4a Dryness Level Adjust
NOTE: If the customer is complaining about the clothes being damp and the moisture sensor passes TEST #4 "Moisture Sensor Test- step 3, then the total dry time can be lengthened by changing from a "Lo" for short auto cycle to "Hi" for longer auto cycle.
1. Activate the Diagnostic Test Mode. Press the following button sequence: MORE TIME ~ LESS TIME -+ MORE TIME --+ LESS TIME - all within 5 seconds
1. In diagnostic test mode, press and hold the Auto Dry Level key for 5 seconds. The dryer will beep and the current auto cycle mode will be seen on the display. The factory default setting is "Lo".
1. To select a different auto cycle mode, press the Auto Dry Level key again. The dryer display will flash and show either "Hi" or "Lo"
1. With the display flashing the selected auto cycle mode press the Start key to save the setting and exit diagnostics (the Start key in this mode does not start a drying cycle). The result will be stored in EEPROM of the control board.
SO EASY JUST TOOK ME 3 YEARS TO FIND IT
Ross
Feb 28, 2009 | Kenmore Elite HE4 Electric Dryer
Water Damage
strip ur phone complelty and let ie dry near heat, clean it with a old brush like a toothbrush, put it back 2 getheragain
Jan 26, 2009 | Samsung SCH-a870 Cellular Phone
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Dryer runs but with little heat
Generally whilpool dryers heat of dont heat.. output should be around 150 .. i would check hose to make sure not clogged or just run without hose and see if that makes a difference... post if need more help
Oct 29, 2007 | Whirlpool LER4634J Electric Dryer
Miele WT945 Front Load Washer / Dryer Logo
202 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
