Question about Verbatim 500GB USB Desktop 500 GB Hard Drive
Does not show on my computer - Verbatim 500GB USB Desktop 500 GB Hard Drive
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
Posted on Oct 02, 2009
    President:
  • 1,187 Answers
Verify that the USB cable is inserted fully into the drive and try every USB port on your computer.
Failing that, put your ear to the drive. If it is "ticking / clicking" repeatedly, then the drive is probably bad.
Further:
Right-click [My Computer]
[Manage]
[Disk Management]
See if your drive is shown on the list or the graph.
If not, the drive is bad.
If it is, right-click and check the properties.
You should know by now if the drive is good.
I can't get the drive to show up on my computer anymore, it was my F drive, simpletech model 96300-400001-001 what can I do I need my important info
Sadly external drives do fail . possibly a computer repair shop can access it and get your information back , but it is costly
Aug 21, 2017 | SimpleTech Computers & Internet
I have a PB6200 BenQ projector. When the computer starts up it shows the BenQ and then shows the windows computer startup screen until it finally fully boots up. Then the projector does not show what is...
There's a display "toggle" sequence on your computer to send the signal to your external post (VGA?). Look at the Function keys (top row) for a screen icon. Hold Fn key down and press that Function key (on Dell, usually F8). You should get an indication on your screen of which outputs are active -- look for BOTH.
May 28, 2017 | BenQ PB6100 Multimedia Projector
My lacie harddisk doesn't show up in windows XP. Power is ok. Light is on and he makes normal operating noise like always. I have another one for which I use the same USB-chord and that one is working...
1. right click the my computer
2. go to properties
3. click hardware tab
4. and click Device Manager
5. show the Device Manager and click disk drives
6. your hard disk is show or not.
7. it's show then go my computer properties
8. select manage and show computer management window
9. then click disk management
10. your hard disk partitionis show right click the partition add driver letter (ex: h:, i: ..)
11. after open the my computer the partition is show
thankyou
Sep 15, 2010 | LaCie F.A. Porsche (301177) Hard Drive
Apple ipod 8G Model# A1285 Shows songs when connected to PC, but when I disconnect it show 0 songs. Please Help.
i have ipod modle A1285 when connect on computer all data show but when disconect for pc no show song video and much more why please sulution me
Feb 27, 2010 | Apple iPod nano
My problem is with the HP Personal Media Drive
> When I unplug the media guide, then it doesn't show up on my computer.
That makes sense -- when _not_ physically connected, then it will not show up within "My Computer".
Try a different USB-port on your computer.
Or, connect it to another computer, to see if Windows will detect it, and will assign a drive-letter. If not, then try a third computer -- it could be "dead", if 3 computers cannot detect it.
Dec 14, 2009 | HP Computers & Internet
My Phone's memory card doesn't show on computer
Jun 19, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Files in player not showing up from computer
hey the music is on here but it wont play. basically when i plug it up to the computer the music on here plays btu it wont show on the ipod or i cant find the music on the ipod.
May 24, 2009 | Audio Players & Recorders
Sharp XR10X Screen size
depending on the age of your computer, some of the older video cards in XP only will allow you to show video in 600x800 resolution. When you want to show video go ahead and change both of your display properties (both the primary and the secondary) to 600x800. See if that works.
If that is not what you are refering to go right click on your desktop and look for the properties or settings of your graphics card. it may say graphics properties . In that area there will be tons of options like (when showing video only show it on the secondary monitor) play around with the different settings on your graphics card.
Good luck
Feb 28, 2008 | Sharp XR-10X Multimedia Projector
Only half of my music shows on a computer while the other half shows on another.
install winamp on your friends computer and see if they show up.
Are you saying the songs don't show up on the actual device on when you connect it to the computer?
Jan 08, 2008 | SanDisk Sansa c200 MP3 Player
Songs keep disapearing or not showing up
Check the ID3 tag options to see if you have selected "show as hidden" as a default
Feb 17, 2007 | SanDisk Sansa e260 MP3 Player
Verbatim 500GB USB Desktop 500 GB Hard Drive Logo
467 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
