Question about AT&T Blackberry Curve 8300 Smartphone
Phone keeps timing out and the hourglass symbol appears each time I try to do anything with the phone and I am dropping calls at an alarming rate and losing coverage in areas to where it has never happened before. I have to remove the battery several times a day to get any performance out of the phone.
  • Joseph Fikes Oct 02, 2009
    This was a replacement phone from AT&T and just is not performing as well as the phone that it replaced.
    President:
  • 1,462 Answers
Your memory might be low, which can cause your BB to run slower.
To check your memory and to free up space please follow the steps below
You can significantly increase the available memory by uninstalling various things from the Pearl.Third party apps installed: Googletalk, Googlemaps, newsclip, spider solitaire, freecell, klondike, operamini, quickplayer, and RSAsecuretoken.
It's best to do this when upgrading the device to a new OS. For example, if you delete preloaded pictures (see step 5, below), they still show up as 0k files in the pictured folder. If you delete them when you reinstall the entire OS, they won't.
Not all of these steps need be followed, picking and choosing will work too. Where I say to delete a file below, it's probably better just to copy it into a new folder so that you can restore it if necessary. Whenever you want to implement the changes, simply run the apploader.
Back up your device first.
No need to modify your .alx file, simply follow the steps below.
(1) If you have a media card, go into the options in the media app and change "reserved pictures memory" to 0M. Even if you don't have a card, consider lowering the number to conserve memory. Savings = up to 10 MB.
(2) Delete the unnecessary language files. You can do it through options> advanced>applications, but the better, cleaner way to do it is through the apploader. When a new OS is installed on the PC (not the device) the .cod files are contained in the java folder at (for OS .69) program files/common files/research in motion/shared/loader files/8300-v4.2.0.69_P2.2.0.40.
There are approx. 400 files, if you only want english, delete any file with the following at the end of the file name: __pt, __pt_BR, __fr, __it, __de, __nl, __en_GB, __es, __es_MX, __ca, and __tr. Also delete all files with dynamic_ling (except for the English files). For os .69 there are a total of 186 language files totaling 12.4 MB that can be deleted in this manner. Plus, delete the .cod files for korean and semitic language support.
(3) Delete the .cod files with any themes (net_rim_theme_...) you don't use. BUT DO NOT DELETE THE ZEN THEME. By deleting the Cingular theme and the dimension icon theme I saved another MB.
(4) Delete the preloaded video, by deleting the .cod file: net_rim_bb_medialoader_video.cod. Savings = 2.4 MB.
(5) Delete the preloaded pictures by deleting the files: net_rim_bb_media_240x260_b.cod and net_rim_bb_media_100_240x260.cod. Savings = 3.5 MB.
(6) Delete the preloaded ringtones by deleting the file: net_rim_bb_profiles_tunes_tunebundles_tunes8700g.c od. Savings = 280k.
Total memory savings is about 30MB. If you don't use PTT on Cingular, delete those .cod files as well (they say ptt in them). If you don't play brickbreaker delete it. If you don't use the maps application delete it.
Keep in mind, however, that some strange things can happen when certain apps are deleted. For example, I deleted the memo pad and tasks on my 7130 and BBcorrector wouldn't work. It's probably best to follow these steps one at a time, so that you'll know which step to undo if a problem arises. Obviously, by messing with the OS files, you could turn your device into a nice Christmas tree ornament, and I take no responsibility if you do that. In discovering all of these steps, I bricked my device twice. However, I simply undid my previous step (i.e., restore some .cod files) reran the apploader and everything turned out fine.
Pleaes leave me comment,if you need furthuer assistance
RNJ VINODKUMAR
Posted on Oct 02, 2009
  • Vinod Kumar
    Vinod Kumar Oct 02, 2009
    Have you tried all the steps i mention?
    If your phone doesn't work after performing the steps i mention, then you have to exchange the phone
    RNJ VINODKUMAR
How to adjust date and time free of charge
You did not specify the phone you using.
To set date and time on your nokia phone
Select Menu > Settings and Phone > Date and
time.
Select from the following:
Time - Enter the current time.
Time zone - Select your location.
Date - Enter the date.
Date format - Select the date format.
Date separator - Select the symbol that separates days, months, and years.
Time format - Select the time format.
Time separator - Select the symbol that separates hours and minutes.
Clock type - Select the clock type.
Clock alarm tone - Select the tone for the alarm clock.
Alarm snooze time - Adjust the snooze time.
Workdays - Select your working days. You can then set an alarm only for working day mornings, for example.
Automatic time update - To update the time,date, and time zone, select On. This network service may not be available on all networks.
Regards
Jun 30, 2011 | Lands Phones
Setting Armitron Watch model WR330
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ARMITRON watch manuals. Rate me, please.
Mar 14, 2010 | Watches
When i go to facebook.com, a page of symbols appears
What you are seeing is CODE. I have had that happen several times on different websites. I serious doubt that it is anything that you have done. ( UNLESS YOU HAVE HAVE CHANGED A SETTING THAT ASKS YOU "VEIW AS HTML" )
Regardless the easiest way to fix this is to call facebook 650-543-4800
Sure hope this HELPS !
RSMITH972278
P.S. PLEASE DON'T FORGET TO RATE ME !
Oct 17, 2009 | Computers & Internet
Samsung Tocco - Alarms won't save in "off" mode
The SGH-F480 will indicate if the alarm is on or off by the Bell Symbol which appears on the top right hand side of the screen. The on or off function will automatically default to the on setting.
Oct 05, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Calls keep dropping
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Apple iPhone Smartphone
Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Mar 03, 2009 | Bulova Watch
Slow loading time
you need to update the software on your phone you can as an over the air update which i do not recommend or you can do at T-Mobiles website the easiest way to find is to go to blackberry.com and search for the version 4.6 curve update
Feb 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Bellum fight drawing the hourglass
It needs to be figure 8 you draw, don't draw it back wards (lot's of us do!) so try starting at a different point. Also it does not have to be huge - just think of writing the number 8 as answer to a math question on the DS. Just keep trying different ways, I sometimes had this problem with the Frog symbols, it's just a matter of triggering the right spots in the touchscreen.
Your game is not faulty.
Nov 17, 2008 | Nintendo The Legend of Zelda: Phantom...
Constant hourglass symbol-draining battery
Hi, this is called the hourglass of death, the device is stuck in a reboot cycle.
You will need to reload the applications, but you can't use Desktop manager because the device resets and the connection drops.
First make sure the BB is unplugged, then go to Program Files > Common Files >Research In Motion > AppLoader and run loader.exe. Click next, it will say port : COM PORT 1 now is the tricky part you have to plug in the BB and COM 1 will change to PIN: UNKOWN , when this happens you have to quickly click next before it reboots again, then it will ask for pin and now has an connection with the device so you can go ahead and re load all the apps.
Good Luck
Apr 16, 2008 | RIM BlackBerry 7250
AOL Hourglass
Download and install "Registry Mechanic" then do the updates prior to running it and removing anything for the first time. This will get rid of all your current Registry errors.
Try AOL again.
If AOL is still not working...
Un-install AOL.
Shut down completely for at lest 30 seconds, then restart.
Then do a search for all AOL files and folders with the options "Search system folders", "Search hidden files and folders" and "Search subfolders" checked. Delete all of those found.
Restart then run Registry Mechanic again.
Shutdown restart.
Reinstall AOL.
Sep 11, 2007 | Computers & Internet
AT&T Blackberry Curve 8300 Smartphone Logo
73 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
