Question about Samsung SCX 4521F All-In-One Laser Printer
Shows a message error opening overheating....the printer is brand new
    President:
  • 2,306 Answers
Warranty should cover that problem for you, but when that happens you need a new fuser assembly and also the power supply PCB, or it will just melt the new fuser again.
Posted on Oct 02, 2009
3 Suggested Answers
myob247
  • 1342 Answers
SOURCE: Brand new Canon MP210 wont print at all
Try going into Control Panel, Administrative Tools, Services and make sure that the print spooler is set to automatic.
Also make sure you have the latest drivers.
Click Here To Go To Canon Support
Posted on Sep 08, 2008
  • 37 Answers
SOURCE: Technical Black Imaging Unit Replaced,Error message still shows
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Posted on Dec 04, 2008
How do I clear a B200 error. I have turned printer of but error is still there
B200 error on a Canon Printer generally means a permanent failure of the print head caused by overheating (running out of ink and ignoring the message and printing further).
A costly mistake.
In the future, do not print after the first message to change an ink tank. Simply replace it as new heads are very pricey.
But a new head is still cheaper than a new printer, so if the rest of the printer/Scanner still works well (or I should say that it did before the B200 error, as that is a "show stopper!", and the printer will not operate further once this error is detected. Only a new head will restore the printer to working), buy a new head.
Sometimes the head is damaged, but no fault error is generated and the printer simply prints nothing on the paper, (or missing one colour or some Pixels and cleaning does not help), but thinks it is. I am sure that this is just that the fault detection is simply not sophisticated enough to detect some errors.
For example, it can detect a shorted head element, but not an open circuit problem for example!! Just guessing though!!
Canon keeps the actual reason for many errors secret, I personally do not know why.....this is one of those errors.....
By the way, second hand heads on ebay are generally a waste of time unless you can go there and test the head before buying, which is very unlikely.....Only buy Brand new Canon heads, with a guarantee and still sealed in the original bag, check at purchase time....from a reputable dealer.anon printers showing this error with
I have fixed several Canon printers with a new head. MG5xxx for example, but I cannot guarantee the fix for simply any printer, its only my limited experience that has been tested....
Best of luck.
Dec 09, 2014 | Canon PIXMA MP540 All-In-One InkJet...
Error 5200 shows when trying to print. Not listed in the user manual.
I found a few answers http://www.uktsupport.co.uk/canon/bj/s400.htm
error 5200 indicates print head overheating. You might try printing 1/3 of document, pausing for cooling then print second 1/3, pausing for cooling then print final 1/3 as a work around.
Looks like thr repair cost is more than a brand new Multifunction printer/scanner
Aug 09, 2010 | Canon Office Equipment & Supplies
Kodak 5300 shows "color ink cartridge needs replacing",even with new cartridge,and new printhead..Ink level display shows color cartridge empty,and its brand new..
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Sep 23, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
Showing drum error and replace toner low message all the time
Open the cartridge cover
push "option"
and push "00"
wait until the word "accept" then close the cover,
after that should be working perfectly.
May 21, 2009 | Brother MFC 7420 All-In-One Laser Printer
Sep 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
661 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
