Question about HP PSC 1610 All-In-One InkJet Printer
Loud noise a few seconds after turn on.
When turned on, the carrage will go the right end and try to keep moving.  At this point it makes about four loud clunking noises like its jumping gears.
Then it settles down and prints normally.
This also happens every time it gets a new page to print.
Thanks for any help.
John Schneider
Arius
  • 446 Answers
SOURCE: HP 8150 gear noise
chances are there is a defective drive gear inside you need a tech to resolve this prob.
see if the gear tooth are smaller than before, if there is any sign of powderized palstic all around then gears need to be changed no amount of lubrication can corrrect this.
also check the orientation of gears, for any sign of mechanical binding this can also cause grinding and unusual sound
cheers
Posted on Aug 28, 2008
SOURCE: When printing, the printer makes a loud sound
I first guess that it is the drum going out. If you have changed the drum......it is more than likely your fuser. Have you ran a supply check to get the status on your supplies?
Posted on May 08, 2009
  • 489 Answers
SOURCE: Color Laserjet 2550 Loud Noise when starting up and printing
Remove toner cartirdge and check gears on cart as well as all of the gears you can see inside the unit for any signs of wear. You may also need to remove the fuser assembly and perform the same task with the gears back there. MAKE SURE THE POWER HAS BEEN TURNED OFF AND THE PRINTER UNPLUGGED FOR AT LEAST 30 MINUTES BEFORE ATTEMPTING TO TOUCH THE FUSER. IT WILL BE HOT!!! Most frequently these kinds of noises from the printer are due to gears slipping. Sometimes simply reseating the fuser assembly or toner cartridge will fix it. If there appears to be excessive wear on any of the gears, you will need to replace them.
Posted on May 29, 2009
  • 26 Answers
SOURCE: HP Deskjet F4240 Printer & when I turn it on loud clicking noise
Try the steps given in the below document.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00587637
Also try the following resets and check
Perform a partial reset
A partial reset will return user settings to factory defaults. On some models, language and country/region settings are also reset. Perform a partial reset of the product by following the instructions below.
* Unplug the power cord from the unit.
* Reconnect the power cord into the unit.
* When the lights begin to flash, press and hold the On/Resume and Paper Size buttons.
* When only the On/Resume light is flashing, release the buttons.
* When the On/Resume light is steady, the reset is complete.
Wish
Posted on Aug 01, 2009
  • 241 Answers
SOURCE: Loud clicking/clacking when paper feeds
Your rollers may be worn and when they are trying to pick up the paper they are not able to . Buy taking your printer to an authorized technician for a maintenance cleaning this should resolve your issue.
Posted on Jun 08, 2010
I had a paper jam , now i have a loud clicking noise left , red light screen says door open . ive checked all doors taken toner out and put back in removed paper drawer and replaced still nothing
THE LOAD CLICKING NOISE COULD BE THE CARRAGE JUMPING IN AND OUT, DUE TO THE CARRIAGE BEING JAMMED,SWITCH OFF POWER AND TRY MOVING CARRAGE ALONG SLIDE, REASON FOR THIS ANSWER IT HAPEND TO MY PRINTER AND I CLEARED IT BUY DOING AS ABOVE
GOOD LUCK
Sep 22, 2016 | Samsung ML-1910/SEE ML-1910 Mono A4 Laser...
Loud humming noise from under my Tahoe. 2WD
The noise is your fuel pump which should hum, but not buzz. It is going bad & will need replaced soon.
murf427
Aug 02, 2012 | Chevrolet 2001 CHEVROLET TAHOE Chassis...
Loud knocking/banging inside dash/glovebox
We had the same issue on our 2009 Flex. The problem was the motor or the gate (I can't remember which) that switches where the air comes out for the climate control. Took it to the dealer and had it replaced under warranty. It didn't take long (maybe 30min - 1hr).
It seemed like the system had a built-in fail safe that shut the motor down after a few seconds when the gate didn't make it to the desired selection. If you change the blower around when the fan is running (e.g. switch from floor to bi to dash to defrost), you'll probably hear the thumping come back as the gate tries to move, but can't.
May 24, 2012 | 2009 Ford Flex
My 924x4 make a loud noise at the front end when turning right on unevenground
Check engine mounts, Check the hub that retains the wheel bearing and hub assembly to the steering knuckle to make sure the bolts are tight and have not backed out.
Then inspect the front suspension for worn bushings, broken anti-sway bar links, and broken springs and or shock mounts.
Also look for damaged CV joint boots. Especially the inner plunge/Rzeppa joint. If a boot is damaged, remove it and clean/inspect/replace as needed. The outer as well. but check the inner for excess play and inspect half shaft for damage or straigtness.
Feb 06, 2012 | Toyota Cars & Trucks
Growing noise in front end of Volvo s60
sounds like a wheel brg, if the noise lessens when you turn to the left while driving more than likely it is coming from the right side, but a brg makes more of a roaring noise.
Jan 09, 2012 | 2002 Volvo S60
Hp 2200dtn prints fine but makes loud friction noise
Old age printer, Remove right,left, back & top doors. check fuser assm screws tighten or slacked? if its slacked use more lengthy screws for tighten the fuser.Apply grease for the gears to avoid the friction. Open main motor assembly clean entire gears, lubricate & fix it back..Check any gears are warn out, replace it if possible...Best of luck..
Jan 04, 2012 | HP LaserJet 2200dtn Printer
New to expresso machine - Cuisinart EM100c
This is a very loud machine. Here's the normal operation: You turn it on, and wait a few minutes for it to heat up, at which point the heating light will go off. Then make sure the function knob is turned to coffee, and it will start brewing. At first, it will make a short (loud) sound and then stop for a second. The purpose behind this is that the machine is pre-wetting the coffee, so that steam can more easily shoot through it in a couple of seconds. Then the loud noise will start again and run continuously until you turn the function knob back to the center. So, the sounds you were hearing were normal. There is a delay between when you hear the sounds and the water starts flowing out. If the coffee is pressed down (tamped) too hard, that delay will be longer. Hope this helps. You made a much better choice purchasing this machine rather than the more expensive EM-200, in my opinion.
May 10, 2009 | Cuisinart EM-200 Espresso Machine
HP 755 CM CARTRIDGE MISSING ERROR
This normally points to a worn ribbon on the carrage. Make sure the ribbon where the cartrige makes contact is really clean, if cleaning make sure the plotter is turned off. Sometimes a build up of ink can cause problems. The bad news is that if the ribbon on the carrage is worn it firstly comes with the carrage as a unit, and secondally the carrage is no longer available from HP
Jan 13, 2009 | HP DesignJet 750c plus InkJet Printer
Cartridge jam won't clear HP 5610v
I had the same problem and just got it to work. go to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&lc=en&dlc=en&cc=us&lang=en&rule=22243&product=441125
go to the section "Moving the carriage" turn on printer and then unplug power. If you still cant move the carrage then remove both toner cartridge and all the trays. Then completely disconnect printer and stand it upright (so paper feed and cartridge tray is on top) Look thru the paper feed area to the left side of toner carrage and you will see a little plastic tab around the bottom back of the carrage. That tab is suppose to be inside a track on the bottom of the carrage. I think that when we put in or took out toner we must have pushed it to hard and that piece jumped out of the track and has "locked" the carrage. I just pushed the carrage up carefully and used a letter opener to move the plastic tab back into place (tab is spring loaded) print working fine now. Hope this solves your problem
Jan 03, 2009 | HP Officejet 5610 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
18 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
