Question about Cameras
Lens is stuck,camera wont stay on
It comes on and lights up for just a second but its like the lens is stuck
  • Cameras Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Oct 03, 2009
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
The lens is stuck inside and dosent come out
try taking the battery out and wait for 10 seconds and replace and see if that helps
Jul 14, 2012 | Canon PowerShot SD1300 IS IXUS 105...
My Camera just lost power, the lens is still stuck out, the battery was full when i used it, I also tried plugging in the charger now to see if it will restore power but it hasn't.. What should I do?
hi
usually camera doesn't lose power with lens stuck out, there must be external cause. But you should check first battery which actually is good or not.(using multimeter or to different camera that use same battery.) second with good battery is any light blinks momentarily. If any light blink then cause come from lens most case. But nothing happen then main pcb or power control pcb is the problem. Good luck with you!
May 22, 2011 | Olympus T100 Digital Camera
My daughter dropped our A520. The power comes on for a second and then shuts down. The lens is stuck open. Is this worth fixing?
I had this problem once. The lens was stuck open and the power would not go on. I took out the storage card and the lens retracted.
Aug 23, 2010 | Canon PowerShot A520 Digital Camera
Kodak Easy Share Z1275 stuck lens
**** a very common problem with most cameras. There hasn't been much of a solution for this problem except to try to wiggle the lens zoom while pushing and holding the power button.
Also make sure you have brand new batteries installed. Even the slightest dead battery will cause a problem.
Jun 02, 2009 | Kodak EasyShare Z1275 Digital Camera
Kodak easyshare c533 lens is stuck
after 4 seconds view screen pic melts and goes blurry
Oct 19, 2008 | Kodak EasyShare C533 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Kodak Z700
Tentative solution:
I had the identical problem. I went as far as disassembling the camera ... not recommended.
Instead of fussing with the lens cover, I pressed on the lens assembly (gently), the lens retracted and the lens cover closed.
My camera works now. It will be my last Kodak.
Good Luck,
Mike
Jun 08, 2008 | Kodak EasyShare Z700 Digital Camera
Lens stuck in the out postion
Contact customer support Repair cost will be heavy
Aug 01, 2007 | Pentax Optio M20 Digital Camera
Cameras Logo
130 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
