Question about Brother DCP-315CN All-In-One InkJet Printer
Hi, we have bad colour repruduction. Very blue. We have tried cleaning, but still bad. Our imac will not let us open utilities. Thanks.
Blue screen with colourful squares
nice image to consider. THanks
Apr 16, 2014 | Apple 24" iMac Desktop
Imac wont recognize my new internal hard drive
Yes, rem it is iMac, it has to be formatted for iMac, sorry there is a way, if you have alternative access, search box and type in formatting new had for iMac. Good luck.
Feb 08, 2013 | Apple iMac G5 Desktop
IMac G4 Mac Desktop: imac g4 wont boot up scree's just blue?...
If it only boots to a blue screen, try booting up in Safe Boot mode:
http://support.apple.com/kb/ht1455
If this does not work, boot from your install DVD and use Disk Utility to repair the disk:
http://support.apple.com/kb/ht2956
If this does not resolve the issue you may need to use your isntall disc to perform an Archive and Install:
http://support.apple.com/kb/ht1710
May 18, 2010 | Apple iMac G4 Desktop
Blueberry iMac with slot-loading CD rom drive will
It would be very difficult to open up the imac to retrieve the disc as the CD drive is totally enclosed and would probably result in it not be functional after removing the disk. Have a look at the following article on the apple website
http://support.apple.com/kb/HT3007?viewlocale=en_US as it does indicate that the slot loading imac does have a hole for paperclip ejection. You could also try opening up disk utility and and clicking on the icon of your disk under the left hand column then go up to eject button and click eject. Hope this helps.
Nov 12, 2009 | Apple iMac G3, G4 USB Keyboard 9224078
When i stert my g4 imac,s screen was became blue
try these articles:
http://support.apple.com/kb/TS1411 also boot to cd and run disk first aid. If it can repair the you have 3 options 1: try 3rd part utility program such as disk warrior or drive genius. 2: try to back up.. you can use target disk mode and hopefully you hard drive will mount, if you dont know how to do target disk mode do a search. if not drive saver can save data but it's expensive 3: erase and install
Jul 01, 2009 | Apple Computers & Internet
Red and blue lines across printouts
open printing preferences and click on maintenance. Run the print head alignment utility. Sometimes this will remove the horizontal banding. I had this same problem and had to uninstall the printer and reinstall just like it was new, running the alignment feature before it was corrected. Worked ok for a few days then started again. I assumed that the printhead is bad. To costly to repair and bought a new printer.
Jun 27, 2009 | Epson Office Equipment & Supplies
IMac G4 starts, but programs close with errors
open the applications folder go to utilities folder open program called disk utility select the main disk in the list on the left and click repair disk permissions if that doesn't work please send me the error message
Apr 06, 2009 | Apple iMac G4 Desktop
Lexmark x5470 printer printing blue horizontal lines on coloured documents
hi
try to perform maintenance of your printer
on the setting
and open your printer clean up the nozzle
use alcohol and cotton buds and then placed it back properly!!
Nov 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
INK
download the utility ssc service from the site ssc.com and use the power cleaning option
Aug 14, 2008 | Epson Stylus Color 640 InkJet Printer
Brother DCP-315CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
