Question about ASUS K8N4-E Deluxe Motherboard
NO DVI or VGA SIGNAL to MONITOR
I have a K8N4-E Deluxe it worked fine until a couple days ago,all I get is a message from my Monitor that says cannot detect DVI or VGA signal,any thoughts?
  • 3,153 Answers
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Oct 02, 2009
I have a HP LP20265 monitor, and it seems have problem, with signal detection.
well why not test it on another system
DT or LT
desk top or laptop.
why connect 2 data cables at once, this is SO wrong.
only 1 at a time.
Mar 09, 2017 | HP LP2065 Monitor
wow ,, why not test the monitor on any other PC or laptop.
see if its good or bad.?
this is the only way to find this, unless guessing works.
i got lost in your post.
try 2 machines
the post photos of what screen does bad, words never work for telling graphics./
Mar 08, 2017 | HP LP2065 Monitor
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
Hi - I have a shuttle xpc sxh57 core i7 model. A couple of days ago - it stopped sending a dvi signal to the monitors. I have replaced the video card, tried clearing the CMOS and cleaned dust. The fans and...
I suggest try the HDMI connection on your machine and see if its able to give display, since you purchase a new Video Card I assume it have a HDMI port. Or try different monitor with a DVI port if you really want a DVI connection, If it works it means the DVI port on your monitor is faulty.
Hope it helps.
Apr 20, 2011 | Shuttle Computers & Internet
Monitor remains blank and says there is no signal. Then it says it's going to go to sleep. It also says check DVI. What's that? The monitor worked perfectly when I installed it a couple of days ago.
Well, it not getting the video signals from your PC. Are you using VGA or DVI cable for the video connection to the PC. Does this monitor work OK with another PC?
Please post back what you find.
Jan 15, 2011 | HP Computers & Internet
I bought a new LG Monitor, W1946S, a couple of days ago. First time I used it after connection it worked fine, since then it is in Power Save Mode when switched on and stays that way. If I press the...
Firstly take it straight back and change it, if its a hardware issue then you want it changed sooner rather than later when it might run out of short term warranty.
Secondly, be sure that the vga/dvi cable is plugged in securely at both ends, it has to recognise the signal from the pc to turn its monitor on and start displaying. But change the monitor and fast!
Jan 07, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
Monitor reads - "no vga signal". Thus, I have no picture. It just stopped working
hi there, check the system if it is ok, if so, check your video cable, you have a video problem. try to see if there is a cold solder on video section, do some test. ty
Dec 25, 2007 | HP W22 LCD Monitor
No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Jan 11, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
ASUS K8N4-E Deluxe Motherboard Logo
250 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
