Question about LG LHT854 Theater System
LG LHT854 720p display with dvd's causes frequent blank screens
When the display is set to 720p and I play dvd's, the screen frequently goes black. I assume the unit is 'catching up' with translating a 480 format to 720; however, this happens so often it destroys the viewing experience.
  • 1 more comment
  • c3macgregor Oct 02, 2009
    I have an HDMI cable connected
    I just replaced the HDMI cable, in case that was the problem, and no effect.
    The TV is a 720p, which is the resolution I set it to.
    I just tried setting the resolution to 'Auto', and it appears to have fixed the problem.
    Actually, I stumbled upon the solution myself.
    Recommend adding it to your FAQ database.
    President:
  • 1,462 Answers
Can you please tell me, Using what cable you connect your DVD player and TV and What tv you have?
Please leave it as comment and we will solve your issue
RNJ VINODKUMAR
Posted on Oct 02, 2009
  • Vinod Kumar
    Vinod Kumar Oct 02, 2009
    HI,
    The two main reason for which the screen flickers while playing HD content through HDMI cables are as follows:
    1)Wires are faulty or loose it will not get signal.
    Try testing with some other HDMI cables, most of the HDMI cabls fail..If the other cable works fine then you should buy a new cable
    2)Other reason is the screen resolution .
    If its not adjusted to proper resolution then the screen flickers.Try adjusting the resolution to 720p and check playing .
    You may have accidentally set your DVD player on a resolution or output mode that your TV does not support.
    Also try swapping the HDMI cables to confirm you don't have a defective HDMI cable or HDMI input on the TV.
    if the wires are faulty then you can get it from
    www.radioshack.com
    please check these things and leave me comment, if you need further assistance
    RNJ VINODKUMAR
  • Vinod Kumar
    You have to set the resolution according to the output of DVD..But if you specify auto the TV will adjust automatically..
    Is your issue fixed or you still need assistance
    Please leave me comment,if you need further assistance
    RNJ VINODKUMAR
WOULD IT BE OK TO CLEAN THE SCREEN ON MY LG LCD SCREEN WITH DVD DISC CLEANING FLUID AND A SOFT CLOTHE
Soft dry cloth wipe frequently on LCD screen is the only way. Slightly damp cloth maybe use at your own risk of leaking water into the lcd screen and damge the tin oxide(turn black).
Sep 20, 2010 | LG 26LF10 LCD TV
My screen goes blank and my computer then
Hi, first of all check your AVI cord by changing it or check your settings if it's set on timing off at certain intervals. then after all said and done format your system.
thanks
Apr 06, 2010 | Computers & Internet
The screen goes black on my lcd but the voulme
Usually a bad AV, Componet or HDMI cable from cable box to TV.
If DVD player or game system works with no issues the Tv is not at fault. (Usually)
If not TV needs service.
Jan 09, 2010 | LG 42LG50 42 in. LCD HDTV
DVD plays audio but no video? The LG screens comes on but the screen goes dark and only the audio plays. I ran the disc cleaner.
NO NEED TO CLEAN LENS, YOU HAVE A MOTOR PROBLEM, IN THIS CASE YOU WILL BE ONLY ABLE TO PLAY AUDIO DISK AND NOT DVD. BECAUSE OF FREQUENTLY USED, DVD DISK MORE SPEED ROTATION THEN NORMAL CD, SO CHANGE YOUR MOTOR AND CHECK IT WILL WORK......
Oct 14, 2009 | LG DP781 Portable DVD Player
My lcd screen goes blank frequently on both my samsung phones,i have a Z720m and a U700.both my phones have this problem of the screen becoming black,i do recieve calls but with a blank screen.
Hi,, what you have to do is, replace your flex, ( the device which connects between top board and main board of your cellphone. Good lack,,,,,,,,,,,
Aug 15, 2009 | Samsung SGH-U700 Cellular Phone
Screen goes fuzzy and blank.
u need a new phone i ahda similar problem with my lg kp500
Aug 09, 2009 | LG Dare VX9700 Cell Phone
While playing xbox 360 in 1080p mod, the screen frequently blanks
Most TV's have problems doing 1080p over component. Dial the Xbox back to 1080i. Make sure the big switch on the Xbox AV cable is set to 'HDTV' not 'TV'(common problem) If the problem persists, try plugging into different hookups, use HDMI (if your console supports it) or buy one of the HDMI adaptors from PDP or MadCatz if your console doesnt. HDMI will reduce the clutter and will make 1080p a reality.
Dec 18, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Internal Display Frequently Blank
Replace the display stri. it will work.
Kerala Tourism
Jan 10, 2008 | Nokia 9300 Smartphone
LG LHT854 Theater System Logo
162 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
