Question about True GDM-26 Refrigerator
Have a true ttp67 that freezes when turned on after 2-3 hours instead of cooling!
    Novelist:
  • 112 Answers
Do you mean the product freezes or the coil inside of the box freezes?
If it's the product check the thermostat setting - should be on 3 to 5. Most of my customers use a setting of 5.
If the coil is freezing up it could be the thermostat or a refrigeration problem that would require a tech to check pressures.
Posted on Dec 12, 2010
  • 25 Answers
If it was off over night the fan comes on you should feel air coming from the inside vent the condensor fan may be bad or the blade is loose
If you feel air then it freezes it's a Classic example of low freon gas.
Posted on Oct 02, 2009
The temperature keeps on rising. everything inside is melting. does not freeze anything. fan and light is working.
Turn it off, defrost it for a couple of days """""with the door open""""", restart it with door closed and see if it starts freezing again after about 2-3 hours, if so, then the draw unit works, that indicates the defrost cycle needs to be reset or one of the defrost elements has failed causing the rest no to do anything. Any probs call me on 08 9523 0552 Russ
Feb 27, 2011 | True 31 cu. ft. / 878 liter Upright...
My thermostat is set on 72....but shows it is 76 in the house. I shut it off yesterday in case it was freezing up. 2 hours later, turned it back on and it cooled great the rest of the evening. I woke up...
it sounds as thought the coils on the unit need to be cleaned, make sure it is draining, if it still freezes up after cleaning coils and checking for draining then the unit has a leak and needs to fixed/charged. Hope this helps tim
Sep 12, 2010 | Heating & Cooling
Lumina (Aldi) ice cream maker instructions
Before using the first time:
1. Remove all of the packaging.
2. Wash the parts. (the paddle & the bowl only)
3. Eight hours in advance, place the inner bowl into a freezer.
4. Prepare the ice cream or sorbet mix (see recipe ideas)
Allow the mix to cool in the refrigerator.
FYI, I freeze the inner bowl overnight instead of the eight hours as stated in the manual.
Dec 29, 2009 | Ice Cream Makers
My freezer will freeze for about 2weeks then it starts to get warm when I turn it off for about 6hrs it will refreeze
It sounds to me like the defrost isn't working somewhere.It freezes for 2 weeks until the evaporator coil freezes over and you lose your airflow, hence, your cooling. Then when you shut the unit off for 6 hours it thaws out enough to get you cooling again for 2 weeks.Check your defrost timer and see if it is going into defrost and if your defrost elements are good. Both will be located on top of the unit. Good luck!
Nov 12, 2009 | True 23 cu. ft. / 651 liter Commercial...
Freezes up after long term use quits cooling
Turn central on fan only and let it run. You probably have a leak in the coils. It will defrost after a couple of hours and start working again. My ac man said turning it on fan only instead of turning it off will help it defrost faster.
Jul 26, 2009 | Heating & Cooling
Gm dex-cool vs prestone anti-freeze...
yes,your guy is right,a lot of gm cars have the int. gasket problem because of dex.
Feb 23, 2009 | 1995 Pontiac Grand Prix
Kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
My True beer fridge is freezing inside.
call repairman sounds like low on freon or thermostat problem either way better to have pro do it hope this helps
Sep 05, 2008 | True Refrigerators
True GDM-26 Refrigerator Logo
251 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
