Question about York / Cam-stat Anti-short Cycle Timer 2ac04700324a
Blower won,t shut off until I tap it.
I am just going to replace the part.
Posted on Oct 03, 2009
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
A/C Blower won't shut off
Depending on the make model and year, there may be a blower relay that has stuck on. You should be able to unplug the relay, or the blower fuse until you can get it checked out.
Dec 10, 2012 | Cars & Trucks
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
My heater/ac fan sometimes won't work. What do I check first?
$24the AC light does not light until you turn the fan on, that is ok, the issue with your fan only working sometimes is more than likely a faulty blower motor, in some cases it is the switch, when the motor does not turn on try tapping it and see if that makes it work, if it does then it is the motor.
the switch at autozone is part number SW295 and is $16
the motor at autozone with the blower wheel is part number PM136
cost is $24
Sep 29, 2012 | 1998 Pontiac Grand Prix
2000 Monte Carlo blinkers work some time have to tap /hit dash board by hazard switch to make them work. Control switch on heater blower not working light out. I have to put the fuse in on passenger side...
For the blinkers you need to replace the hazard switch.This will take care of your problem.For the blower,if this is what you mean by heater won`t shut off.You need to replace the blower motor resistor.This will fix your blower not shutting off.The light for the knob you will have to remove the control panel and replace the bulb if it is replacable.Some of these models you have to replace the control panel to get the lights to work.I hope this helps Heidi and let me know if you need anymore help.Good luck.
Sep 10, 2010 | 2000 Chevrolet Monte Carlo
Need to remove ac blower to find out why you have to hit to get it to run,
If you have to tap on the blower motor to get it to run then you'll most likely need to replace it. What I usually find is that there is a bad spot in the armature or one of the brushes and when you tap on it what is happening is that the slight jar that tapping on it causes is just enough to get the motor off of the bad spot and it will run until it shuts off in the same place again. You could have a bad connection right at the blower motor but I almost always find it's the motor itself that is failing. Good luck, hope this helps!
Aug 11, 2010 | 2005 Dodge Caravan
Blower motor does not turn on until I tap box by
That sounds like you have bad connection to the blower motor or the speed control resistor or the blower motor itself.
If the motor does not run with the heat control at maximum then your blower has worn out brushes, which needs replacing, may be easier to get a blower motor from a breakers yard and replace the whole blower assembly. Check the ocnnectors first.
Jan 30, 2010 | 1990 Geo Prizm
York / Cam-stat Anti-short Cycle Timer 2ac04700324a Logo
149 people viewed this question
Top York Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a York Hardware and Accessory Expert? Answer questions, earn points and help others
