Question about Amana Dryers
The drum on my amanda dryer is making a noise as it go around.
The drum on myamanda dryer is making a noise as it go around.
  • Amana Master
  • 7,482 Answers
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Posted on Oct 11, 2009
How to install stall drum belt Amanda gas dryer ngd700tw
generally: take top off, take front off, slide belt over drum and then around tensioner and motor drive.
Nov 27, 2015 | Dryers
Why does it sound like a ball bearing rolling around?
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Apr 25, 2015 | Dryers
When cloths are in the dryer, drum squeaks every time it goes around. Is there a way to grease or oil, or does it need a belt? It is model no 417.94702300.
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Sep 28, 2014 | Dryers
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Drum Bearing
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 | Dryers
Drum not turning, just belt spinning around. Drum making noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 05, 2011 | LG DLE2532W Electric Dryer
The dryer is making a thump/thud noise as the drum turns. The dryer works fine but the noise sounds like something hitting everytime the drum goes around. Could this be the belt going out?
heatman101
Asker
Jan 02, 2011 | Kenmore 83142 Electric Dryer
The dryer is making a loud noise when running. the drum is turning. almost sounds like something is rolling around under the drum.
heatman101
6565ggf
Feb 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool Dryer making a rubbing or jingle noise when running
there are wheels under the drum to support it take the front panel off and check those
Jun 24, 2009 | Whirlpool GEW9200L Electric Dryer
GE dry is making a noise like loose change is rolling around
There may be change rolling around in it.
Remove the top. Take the screws out of the drum baffles and remove the coins from inside the dryer drum baffles.
When replacing them, tighten them well to help prevent coins from getting in there.
Mar 23, 2009 | GE Dryers
Dryer Making a Grinding Noise
The grinding noise is probably a worn out roller or the central bearing in the back. The center of the drum in the back has a part called a bearing which screws onto the back of the drum and has a stub which sticks out. The stub then goes into a bearing hole in the back panel of the dryer. If you are handy, you could try to replace yourself. I did it once. While you are at it, check the drum belt which goes around the drum and makes it spin. Replace it if looks like it has wear.
Feb 01, 2008 | Kenmore 63942 Dryer
Dryers Logo
104 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
