Question about Kenmore Washing Machines
Kenmore HE2 front loader. The discharge pump
Kenmore HE2 front loader. The discharge pump keeps runnning and will not shut off after all the water is pumped out. Have F-21 code. I cleaned out discharge pump and housing as well as all hose assemblies as they pertain to discharge. What is causing the pump to run and not shut off?
  • 6,784 Answers
This error occurs if the touchpad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the touchpad/LED assembly and Central Control Unit (CCU).
4. Plug the unit back into the appropriate socket. If you continue to experience abnormal actions with the pump, replace the (CCU)
Posted on Oct 02, 2009
5d error code kenmore he2plus
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Apr 26, 2013 | Kenmore Washing Machines
What does F33 mean- its the code on my front loader washing machine
"F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch. The flow meter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Thank you !!
Jul 15, 2010 | Kenmore HE2 Plus Front Load Washer
Where is the pump/filter located on my Kenmore Front Loader Washe
It is just behind the lower panel. Remove the 3 screws from the lower panel (the panel just below the door), the screws are on the lip on the bottom of the panel facing the front of the machine. Pull down and toward you to get the panel off. The filter and clean out are in the center. Unscrew the cap to remove and clean out, but have lots of towels ready, there will be water coming out.
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore front loader does not go into the spin cyclr and water is left in the drum
Most likely either the drain pump or hose is clogged or perhaps the drain pump is not working. Machine will not spin with water still in the drum.. Check all connections.
Mar 12, 2010 | Kenmore HE2 Plus Front Load Washer
Getting rid of a horrible stink in my washer kenmore HE2
The following link will give you some tips to try in order to minimize odors and mildew in a front loading washer:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Following a good regiment of routine cleaning of the door bellow, followed by leaving the door open when not in use (at a minimum) can go a long way towards preventing odors in a front loader. Since the doors on these washers are water tight when closed, it is importnant to leave them open when not in use to allow the drum to air out. There is a small amount of residual water that remains in the drain lines and pump that will sour if you don't. I personally own a Kenmore Elite and have never had problems with mildew or odor in the 9 years I've had it by following this routine.
In addition, it is a good idea to periodcially check the drain pump reservoir to ensure there is not dirt or debirs clogging the pump and becoming stagnant. The following link explains how to access and clean the drain pump (if necessary):
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
The drain pump reservoir collecting debris, along with small articles of clothing getting caught in the folds of the door bellow are the two main causes of odors in a front loader.
Read through the links provided and let me know if you have any questions. I hope this helps you.
Feb 05, 2010 | Kenmore HE2 Plus Front Load Washer
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
I have an HE2 Plus Front Loader. When it drains,
Sounds like there might be something in the pump that got past the button trap. You will have to remove the pump to check it.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
Regarding the kenmore he2 plus front loader washer.f-21 keeps coming on.actually worked for a couple loads today but f-21 started coming on again after i started washing a 3rd load of colored clothes.seems...
There is a strainer on the drain pump that is clogged. The manual does not mention this at all, it merely states the drain hose is kinked or clogged.
Under the front door there is a panel that is the width of the machine and is held in place by two screws, one on either side.
When you remove that you will see the pump and the the strainer attached to it. Unscrew the strainer (put a small pan under it to catch excess water) and remove to remove the junk accumulated.
Also, attached to the panel is another manual that refers to the error codes you are seeing.
Dec 20, 2009 | Kenmore HE2 Plus Front Load Washer
My Kenmore HE 2 Plus front end loader washing machine has a load and when I open the door water pours out. It will NOT spin
since front loader wont spin till its empty
id be willing to b et you have a clog in the pump
get a few towels
and spread em out in front of the machine
take off the fron toe kick 3 T-20 screws on front lip bottom
you should see the trap cleanout dead center
turn the handle 1/2 tun and pull straigt out...
be advised the washer will dump
you now have the sump in your hand ensure it and the pump inside are clean
reassemble and test
use 1 tablespoon of soap no more
suds will mess this machine up
Oct 06, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
88 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
