Question about 2wire (1000-400108-001) Router
Access router settings - 2wire (1000-400108-001) Router
    President:
  • 1,884 Answers
You can access the router settings provided you know the administrator password. Go to Start->Run. type telnet 198.162.1.1 and press enter. A black window will open asking ID. admin Passwd - default passwd is admin unless you have changed it. And if both are correct, then you get a menu. Follow it.
Posted on Oct 02, 2009
Please I cannot connected to internet
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
May 26, 2011 | Computers & Internet
How to set up password on my wireless router ?
The answer to this depends on WHICH password...... Router access, or wireless access. Run the install wizard from Edimax....but here are the highlights of what should be set:
Wireless Router
It is usually easiest to run the install wizard from the manufacturers' website, usually for free, but be sure to be ready to set the items listed below.
To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your internet browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page before you leave it, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping this information to bottom of the router. (Physical access is usually not the security issue.)
4. Check that your router is set to broadcast its' presence.
5. Change the channel of the wireless to 11, and avoid conflict with landline cordless phones. (Big issue, even the neighbors can interrupt).
There are more secure settings available, all the way down to only allowing certain MAC addresses to have access. A MAC address is a digit unique to each and every network card. Like a fingerprint. Most users do not set mac address limits
Apr 24, 2011 | Edimax BR-6226n nLite Wireless Broadband...
How do I access my router settings using the http://192.168.1.1? I set it up on another computer and always accessed it from there, Now I cannot access it from my laptop
hey,
you need to connect your laptop to the wireless router over wireless or wired connection and then access the page.
if you intend to change the settings, then its preferred that you have a wired connection to the router.
BTW, keep the routers admin password handy..
Cheers!!!
Feb 21, 2011 | Linksys Wireless-G WRT54G Router
How do I secure my wireless connection?
The exact access and setting procedure can be found at Belkins web site.
Disconnect all cables to the router, then, in essence you connect to the router, usually via direct connection and direct your browser to the address specified (somthing like 192.168.1.1) and log into the router. Things that you want to change are ssytem ID, router name, Router access password (RECORD IT!!!!) and set up wireless security. An easy access password would be your home phone or cell phone number. if you make a cryptic password, tape it to the router, as you will forget it when a guest visits and needs access.
Another setting to check is that your router broadcasts it's presence, usually set to yes, but not always, by default.
SAVE settings on EACH PAGE or they do not save, as you go from page to page changing settings.
Oct 14, 2010 | Belkin Computers & Internet
Setting up an access point to have same settings as the router?
It seems like it is the issue with the router's firmware. Upgrade or reflash the router's firmware. This will definately solve the issue
Jul 24, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
What is a ssid# and where do i find it
Service set identifier, or SSID
Service set identifier, or SSID, is a name that identifies a particular 802.11 wireless LAN. A client device receives broadcast messages from all access points within range advertising their SSIDs. The client device can then either manually or automatically—based on configuration—select the network with which to associate. The SSID can be up to 32 characters long. As the SSID displays to users, it normally consists of human-readable characters. However, the standard does not require this. The SSID is defined as a sequence of 1–32 octets each of which may take any value.
It is legitimate for multiple access points to share the same SSID if they provide access to the same network as part of an extended service set.
Some wireless access points support broadcasting multiple SSIDs, allowing the creation of Virtual Access Points, partitioning a single physical access point into several virtual access points, each of which can have a different set of security and network settings. This is not yet part of the 802.11 standard
Feb 20, 2010 | Airlink AR430W Wireless Router
I used set up disk, set up SSID and added Key but laptop won't access SSID/router.
In order to access ther router wirelessly, you must first connect via cable to router. Using IE, go to http://192.168.1.1 and look in the Wireless section. Set the Network Name (SSID) you want - it can be almost anything you want - and after that you can choose what sort of Security you want to use, and set up your access passcode. Once this is all done, and access to Wireless is verified (using the passcode to access the SSID you chose) disconnect the cable. You now have control of router wirelessly.
Dec 16, 2009 | Gateway Wireless-B Router (wbr-100)
I do not know have to set up wireless without using USB to access internet
do you have any computer connected to the router ?
If not then you will need to connect the computer to the router?
you will need to access the router set up.
Change the wireless settings of the router.
And try to connect to the wireless network on the computer.
Click Here to know how to check the settings of the router
Nov 20, 2009 | Arris SURFboard SBG900 802.11g/b...
Comcast technician misspelled the name of my wireless connection. how can i fix it
You will need to access the router set up.
Do you have any computer connected to the router ?
If not then you will need to connect the computer to the router with the Ethernet cable.
Then access the router set up. Under wireless settings you will be able to change the name or also called as SSID.
Click Here to know how to access the router set up
Nov 19, 2009 | NetGear WGR614 Wireless Router
Hi, i wanted to know how i can get a new passphrase so that its not private anymore and i can use my wireless netbook?
To check or change the settings on the router, you will need to access the router set up.
Do you have any computer connected to the router with the cable ?
If not then you will need to connect 1 computer to the router .
On this computer you can access the router set up and if you want to change the settings , you can.
Click Here to know more about how to access the router set up
Nov 18, 2009 | Motorola Computers & Internet
2wire (1000-400108-001) Router Logo
294 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
