Question about Lexmark X83 All-In-One InkJet Printer
I get a paperjam error messasge and the printer won't print. The cartridge carrier is hung up on the right side of the printer asyo face it. The paper won't be passed through the printer. When I open the printer door, the cartridge carrier doesn't move to the center. I also can't manually print
SOURCE: Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Posted on Apr 13, 2007
hemantraj
  • 638 Answers
SOURCE: carrier jam
your encoder strip(a transprent strip behind the carriage) is either broken or loosed up and so it is not able to get self aligned.kindly fit the encoder properly or change the encoder if neccessary.encoders are usually very cheap.wish u luck!!
Posted on Jun 04, 2008
JJacobs320
SOURCE: Carrier jam Lexmark 4300
I had this same problem, I found a long skinny thin plastic strip had fallen off & caused the problem for me. The plastic strip has slits at each side to attach to the inside back of printer, on the left side is a down ward facing arrow, the plastic strip feeds through the back middle of the cartridge carrier and then the slits are to be inserted to the metal tab like pieces on the back sides inside the printer on the right side (facing printer) it will look like a small rectangular hole with a longer metal tab like piece sticking out & on the left is a smaller squared like hole with a flat smaller metal like tab which will line up if the plastic strip is feed through the back of the cartridge carrier properly. This should allow the cartridge carrier to glide properly & work as it should, with no more banging! Sorry my tech. terminology isn't good, I am not Knowelegable with this sort of thing, just sharing my experience :) HTH!
Posted on Nov 14, 2008
  • 461 Answers
SOURCE: My ink cartridges won't move to the center when I open the printe
Be sure the printer is powered on as it needs power to move the cartridges - this is a common mistake.
Posted on Dec 19, 2008
Ajkill
  • 2035 Answers
SOURCE: Lexmark X5495,Error 1203, Says Clear Carrier Jam
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 7 Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
Posted on Apr 15, 2009
I have a four in one Lexmark x5630 printer and have replaced cartridges with brand new black and colour 36 & 37xl. The printer won't even print a test page - just says that cartridge error co
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Try to contact the store where you bought the new cartridge(s) and have them replace it. You may also contact Lexmark Technical Support Center for assistance (especially if you're using genuine cartridges).
Feb 14, 2012 | Lexmark Office Equipment & Supplies
How do I remove the ink cartridge from my HP 2410 printer so that I can replace it with a new cartridge?
Hi milsyr, 1. switch on the printer
2. Lift the blue/gray latch on the cartridge carrier and remove the cartridges you need to
replace.
3. Remove the pink tape from the new cartridge.Hold the cartrige so the label is face
forward,and the words are facing you.
4. Slide the new cartridges into the print carriage.
- The color cartridge goes into the left side of the carriage and the black
cartridge into the right side of the carriage.
5. See that you slide the cartridge underneath the metal bar and then push it down
into place with your fingers.
6. Close the cover on top of the cartridges and make sure the latch is secure.
7. Close the printer carriage door.
8. Press ok on the front of your printer.
- An alignment print will follow.
THANK YOU AND GOOD LUCK!
Sep 04, 2011 | Office Equipment & Supplies
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
May 15, 2011 | Lexmark X4650 InkJet Printer
When printing it starts to print then the cartrideges slam back and forth then it errors
Open the printer cover and access the cartridge area. Remove the cartridges. Check the transparent strip(encoder strip) and make sure it's not unseated from its position. If it is, - Switch off the printer. - Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right. - Place an index finger on the encoder strip on either side of the cartridge carrier. The encoder strip is a clear strip running the length of the printer, above or behind the cartridge carrier. - On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot. - Then lightly press the strip first to the rear and then forward, if necessary.
Try to print again.
Apr 26, 2011 | Lexmark Z600 InkJet Printer
How do i install the ink cartridge in my lexmark z35 printer
Select the ink cartridge specific to your printer. Canon inks are versatile, so your selection may be as simple as choosing between black, color or a multi-pack with black and color cartridges.
Turn on your Canon printer. The switch is generally located on the top right hand side of the printer. Open the printer's lid.
Wait a moment. The cartridge carrier will automatically disengage.
Put your hand behind the existing ink cartridge and pull the cartridge towards you until it pops out. Dispose of or recycle the used cartridge.
Carefully pull the tape off the new cartridge.
Position the new cartridge into the cartridge carrier. Make sure it is facing the correct position.
Press the cartridge carrier gently until it clicks into place. Some cartridges have indicators to demonstrate that they are properly positioned.
Close the printer's lid. Print a test page to ensure everything is working properly.
Oct 31, 2010 | Lexmark Computers & Internet
How to load ink catritridge #4&5
plz follow the steps below:
Step 1 Locate the "On" button located on the top right side of the Lexmark 2600 Series Printer Scanner. Turn the unit on by pressing and releasing the "On" button one time.
  • Step 2 Raise the scanner unit until it locks into place. Allow the print cartridge carrier to move to the loading position. Wait for the print cartridge carrier to stop moving.
  • Step 3 Locate the color print cartridge in the carrier on the right. Release the empty color print cartridge by pressing down on the cartridge carrier latch. Raise the cartridge carrier lid. Remove the empty color cartridge by pulling it straight up. Place the empty cartridge in the plastic bag and set aside for recycling.
  • Step 4 Remove the new color cartridge from its packaging. Remove the protective tape from the nozzle and connector on the back and bottom of the color cartridge. Dispose of the protective tape.
  • Step 5 Install the new color cartridge into the right cartridge carrier slot. Close the cartridge carrier lid. Press down on the cartridge carrier lid until it clicks into place.
  • Step 6 Raise the scanning unit slightly. Release the scanning unit support. Close the scanning unit.
  • If u find this post helpful, then plz vote it.
    Thanks
    Apr 27, 2010 | Lexmark X2600 InkJet Printer
    Cartridge error 1203
    First of all, please verify each cartridge carrier has an ink cartridge :
    1. Check to make sure the left cartridge carrier contains a black or photo ink cartridge.
    2. Check to make sure the right carrier contains a color ink cartridge.
    3. Remove each cartridge and examine it to make sure the protective tape has been removed from the contacts and the print head.
    4. Replace each cartridge in the proper carrier.
    Step 2 :
    Wicking the cartridges and cleaning the contacts on the back of the cartridge should be performed if the nozzle clean was performed and the quality was not satisfactory.
    Wicking the Cartridge
    1. Ensure the printer is powered on.
    2. Lift the scanner unit.
    3. Open the cartridge latches and remove the cartridges from the carrier (Figure 1).
      Figure 1: Removing the Cartridges from the Printer
    5. Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back (Figure 2).
      Figure 2: Proper Cleaning Direction
      new_note.jpg Note: Never wipe the cartridges from side to side, as this causes cross-contamination in color cartridges.
    Cleaning the Contacts
    1. Turn the cartridge so that you are looking at the contacts on the back side of the cartridge (Figure 3).
      Figure 3: Turning the Cartridge To View the Back Contacts
    3. Using a clean dry cloth, wipe the contacts in the direction shown (Figure 4), so that no dust or other contaminants are visible.
    4. new_note.jpg Note: Do not use the same cloth that was used to clean the cartridge nozzles. This may cause more contamination on the cartridge.
      Figure 4: Cleaning the Contacts on the Back of the Cartridge
    5. Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
    6. Replace the cartridges in the carrier and close the scanner unit.
    7. Print the document again.
    8. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times as needed.
    Dec 19, 2009 | Dell 924 All-in-One InkJet Printer
    I am getting a cartridge error. The cartridge is not a new one and it had not been removed. I followed the insructions in the book for cleaning the copper colored contacts but to no avail. I have turned...
    OK, If the printer has 2 or more print cartridges, then certain cartridges must be inserted into the correct carrier. Make sure you have not mixed / switched the cartridges into the wrong carrier..
    ALSO, What printer model number? And, what is the cartridge number?
    Nov 20, 2008 | HP Office Equipment & Supplies
    Jan 14, 2008 | Lexmark P4350 All-In-One InkJet Printer
    Printer Error-->
    I just moved to Alaska and shipped this printer up and had the same problem. What I found was that when I start up the printer, the carrier that holds the printer cartridges would not move all the way to right side of the tray. You can see this if you open up the top portion of the scanner glass carrier.
    Turn off the power and remove the electrical plug from the back of the printer to be sure no power is feeding the printer.
    If you closed the top of the printer, the part where the scanner / copier glass is at, open it back up.
    Reach into the printer and manually move the piece of plastic that holds the print cartridges to the left.
    Directly underneath where the print cartridge carrier defaults to on the right hand side of the printer you will see a piece of white plastic on the bottom. It will probably be sticking up. It is hinged. Push it down gently so that it rests down inside of the indention where it is supposed to be.
    Plug your printer back in and turn it on. The printer will go through its self test, and if this was the problem will work correctly for you.
    Spencer
    Dec 06, 2007 | Epson Stylus CX7000F All-In-One Printer
    Lexmark X83 All-In-One InkJet Printer Logo
    13 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
