Question about Photography
Cable releases will not operate shutter of Pentax A3
I have three cable releases of different lengths. All fit the tapering thread, but will not operate the shutter
    President:
  • 1,653 Answers
Take one of the cable releases and press the thumb pad and extend the release probe. Lock the release in the fully extended position. Try inserting the probe into the shutter release hole and see if it works. If not then try using a thick needle from the head end and see if the release actually works on the camera. If it does then measure the depth that the needle goes to in order to work the shutter and compare to the exposed length of the release cable. You may find that it is not long enough although I would have thought unlikely.
Posted on Oct 02, 2009
My quad had a NGK D8EA spark plug. I only have a DR7EA will that do as I live 120km from town
the critical details of a plug are
the thread diameter
the thread length
the method of sealing---copper washer or taper seat
when in a bind any make of plug that conforms to those three requirements will work
the d indicates a 12mm thread size
the e indicates a 19 mm reach--thread length
the r is resistor type
the a is the construction type
the 8 or 7 is the heat range --both close to middle of the range
Feb 04, 2017 | Motorcycles
What happens if you put wrong spark plugs into a car?
if the thread is too long, combustion material will settle in the threads exposed and will strip the threads out of the head when removing the plugs
if the thread is too short , combustion material will fill up the threads in the head making it impossible to fit the correct plugs
if the thread is too long there is a possibility that the end of the plug will hit the piston top
you can have the correct length but some plugs have a taper seat to seal and others have a copper gasket
the plugs will not seat properly and will be difficult to keep tight or sealed off
if you mean by "wrong plugs" the wrong being different makes or numbers on the plugs there will be nothing wrong as all that matters is the thread size and length and seat seal
Jan 02, 2017 | Cars & Trucks
How do I make the spindle chuck stay in the quill of my model FDM 16 SPC drill press? I have forced it down on a block of wood. It will stay for a while that fall out.
16 speed should have a Morse taper
for the std drill chuck
to fit a different chuck the morse taper needs to be emery sanded
and the replacement chuck should stick
after using the wood block pressure press method
if not you need a new morse taper for that spindle chuck
hint
i had my drill accuracy and off center spin tolerance down to one thou
with stretched old belts I got more speeds than 16
for special jobs
my 16 speed used a morse taper two for the drill chuck
this picture says its a spindle chuck
26313356-3kt1rk2qq1yye1uaamrjudob-5-0.jpg morse taper
Oct 16, 2016 | Drills
How do I change the oil pressure sensor on 2007 Avalanche
Remove the cable from the switch and unscrew it using a socket spanner , fit a new switch, it has a tapered gas thread , do not over tighten.
Feb 25, 2015 | 2007 Chevrolet Avalanche
Long exposure? how dp you acoomplish this using the pentax k-1000
You will need an external shutter release that locks. Connect the shutter release, then on the camera set the shutter dial to B (bulb). With the shutter release cable fire the camera and lock the plunger, or hold it down. Using a shutter release cable you are less likely to cause camera shake. Of course have the camera on a tripod or something steady.
Jan 27, 2014 | Pentax K1000 35mm SLR Camera
Rmz 250 09 model with new clutch cable fitted must be adjusted fully out to get clutch to operate
Compare the old cable to the new cable. The outside casings should be the same length and the Inside cable should also be the same length. The dealer may have supplied you with the wrong cable. If the cable is the correct one then check the positioning of the clutch release cam.
Mar 30, 2011 | Suzuki RM-Z 250 Motorcycles
What size npt thread is the adaptor
Common American National Standard Pipe Taper Threads
  • NPT - National Pipe Thread Taper
  • FPT - female (internal) National Pipe Taper threads
  • MPT - male (external) National Pipe Taper threads
  • NPTF - Dryseal American National Standard Taper Pipe Thread (ANSI B1.20.3)
For NPT threads a sealant compound or Teflon tape must be used for a leak-free seal. For NPTF no sealant is needed for a sealing.
Characteristics of NPT (also known as ANSI/ASME B1.20.1 Pipe Threads, General Purpose):
  • tapered thread 1o 47'
  • truncation of roots and crests are flat
  • 60o thread angle
  • pitch is measured in threads per inch
Note! Pipe sizes do not refer to any physical dimensions. The outside diameter of a pipe or fitting must be measured and compared to a table for size identification. A 3/4" NPT pipe thread has an outside diameter - OD - of 1.050 inches.
Each thread size has a defined number of threads per inch - TPI, or pitch. The 3/4" NPT pipe thread has 14 threads per inch. Both the TPI and OD of the thread are required for positive identification of thread size because more than one size have the same TPI.
NPT - American Standard Pipe Thread Taper 1) Pipe Size
(inches) Threads per Inch
TPI - pitch Approximate Length of Thread (inches) Approximate Number of Threads to be Cut Approximate Total thread Makeup, Hand and Wrench (inches) Nominal Outside Pipe Diameter
OD
(inches) Tap Drill
(inches) 1/16" 27 0.313 1/8" 27 3/8 10 1/4 0.405 R 1/4" 18 5/8 11 3/8 0.540 7/16 3/8" 18 5/8 11 3/8 0.675 37/64 1/2" 14 3/4 10 7/16 0.840 23/32 3/4" 14 3/4 10 1/2 1.050 59/64 1" 11-1/2 7/8 10 9/16 1.315 1-5/32 1-1/4" 11-1/2 1 11 9/16 1.660 1-1/2 1-1/2" 11-1/2 1 11 9/16 1.900 1-47/64 2" 11-1/2 1 11 5/8 2.375 2-7/32 2-1/2" 8 1 1/2 12 7/8 2.875 2-5/8 3" 8 1 1/2 12 1 3.500 3-1/4 3-1/2" 8 1 5/8 13 1 1/16 4.000 3-3/4 4" 8 1 5/8 13 1 1/16 4.500 4-1/4 4 1/2" 8 5.000 4-3/4 5" 8 1 3/4 14 1 3/16 5.563 5-9/32 6" 8 1 3/4 14 1 3/16 6.625 6-11/32 8" 8 1 7/8 15 1 5/16 8.625 10" 8 2 16 1 1/2 10.750 12" 8 2 1/8 17 1 5/8 12.750 14" 8 14.000 16" 8 16.000 1) The taper is 1/16 inch in an inch, which is the same as 3/4 inch in a foot (angle 1o 47')
NPT threads are not interchangeable with NPS - National Pipe Straight - threads.
NPT threads may look similar to ISO 7/1 threads. However, ISO and NPT threads should not be mixed. ISO threads have 55o taper angle versus 60o for NPT. The NPT root and crest configurations are also different from ISO. For ISO threads pitch is usually measured in millimeters (may be expressed in Inch). The pitch are different.
Feb 28, 2011 | RTO 1 1/4" Drop Pipe Bronze Pitless...
Nikon-d40 (shutter relese problum)
Can you explain more please ?
The Nikon D40 does not have shutter release or as known cable release, but does have a wireless remote control release.
If the shutter is not working properly....
Remove the battery and reinsert.
Remove the memory card and try again
Check the lens is correctly fitted.
Is the lens a compatible fit
Dec 14, 2008 | Panasonic NV-MD9000EN Mini DV Digital...
Shutter release cable for panasonic fz18
There is no cable release for this camera--the belief seemed to be that the timer function would be sufficient
Oct 31, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Photography Logo
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
