Question about GE 168997 Deep Fryer
I need the heating element thermostat controller for a ge home deep fryer
Hi
I have come across a small business R.A. Colvin their knowlege of all heating products is second to none. if they don't they will find out. I came across their web sight by chance. www.racolvin.com.au
Posted on Apr 11, 2010
Where can i purchase this part ? heating element therostat controller for GE #PL 1215.
Posted on Feb 09, 2010
Tip
Will not power on, powers off, will not heat Pwr light out or goes out.
Like most of the problems listed on FixYa about this Deep Fryer ours worked fine the last time we used it, but we could not get the power light to come on again. I found that there is s SAFETY Micro-switch on the heating element control unit. This switch prevents the heating element from being turned on when it is not in the Fryer Pan. The accuator lever for the switch is located under the guide slides on the heating element control unit. It is a metal lever which is moved as you mount the heating element control unit on the fryer pan. You have to look closely under one of the guide ledges on the heating control unit to see it . The problem is that over time the adjustment of the lever changes as it flexes under use. I simply readjusted the lever by forming it with a pair of long-nosed pliers. CAUTION !!!!!!! You can bend the lever so far that the switch is closed all the time defeating the Safety Switch and create a hazard in that the unit will heat as soon as you plug it in whether inserted in the Fryer Pan or lying out on any surface. This might burn someone or cause a fire. Good Luck
X-IBM
on Oct 09, 2008 | GE 168997 Deep Fryer
I have 2 of these at home that have only been used a few times that will not heat up. There are no signs that they are getting power (no led). Any suggestions?
There is a safety switch that has to be made when the heating element is in place. Look for a small button it should contact. Hold the button in and see if it will work. Be careful of the elements getting hot when you push the switch in.
May 11, 2010 | GE 168997 Deep Fryer
I want to fabricate my own deep fryer. I know how to work on the body, except for the electrical parts
For the electrical parts you will need, a Temperature sensor, a Temperature Control Module, The Elements to be Controlled. probably one or two 1500Watt elements. Heat proof wire (Teflon coated.) Heat proof Connector Blocks.
Jan 29, 2010 | Euro-Pro F1066 Deep Fryer
AVAILABLE FROM:
-THE G.E. WEBSITE OR 1-800 NUMBER FOR G.E I'M SURE. AS LONG AS THE MODEL # AND SERIAL # ARE SUPPLIED.
- ANY HOUSEWARES DEPT, IN A BIG BOX RETAIL STORE THAT SELLS G.E., THEY WILL ORDER IT IN FOR YOU.
(SAME THING: SUPPLY MODEL AND S/N)
CHECK THE MANUAL FOR A ELEMENT PART # TOO.
THE MORE INFO YOU CAN GIVE, THE BETTER.
GOOD LUCK.
Oct 02, 2009 | GE 168954 Deep Fryer
Adcraft double deep fryer
its safety switch not functioning
Jul 03, 2008 | Adcraft DF-6L/2 Deep Fryer
My GE 168997 is not heating up enough..
call and complain. possibly ask for a now one
Jan 07, 2008 | GE 168997 Deep Fryer
Gaggenu VF 112-610 Deep Fryer
I just need a handle for the basket in my ultrex
Dec 30, 2007 | Gaggenau VF 230 Deep Fryer
Cuts off
X-IBM
Dec 16, 2007 | GE 168997 Deep Fryer
GE 168997 Deep Fryer Logo
312 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Sal DeAngelo
christian nielsen
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
