Question about Lexmark X4270 All-In-One InkJet Printer
What does error #1200 mean - Lexmark X4270 All-In-One InkJet Printer
I have a zanussi 6hg 1200 rpm it's flashing error code E 60 what does it mean
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Mar 24, 2015 | Zanussi Washing Machines
What does code: H4-00 mean
The H4-00 is a low temp error in the fuser. This can normally be reset by doing the following at the machine:
On the button panel hit
pound, star, C, star
then enter 14, hit start, then execute on the screen.
This should clear any one-off errors
www.equipmybiz.com EquipMyBiz
Aug 04, 2014 | Sharp MX-4101N Multifunction Printer Color...
Error 1200 what is this. I cannot locate my user's guide
Hello Sir, The error on this printer means that the AIO which is All-In-One is stalling or completely stalled. The repair procedure is given below. But you can reply me back clarifying that is it showing Cartridge error 1200 or Hardware error 1200. :--------- THE PROCEDURE:--------------------------
  • Turn the Printer completely off to turn off AIO.
  • Then check for any Paper inside.
  • After confirming that there is none then Un-plug the AIO from the Outlet located in the wall.
  • After 10 Min, replug and check function.
Also the problem can be on the Catridge ( Most Commonly ). In this case you need to check the Catridge socket for any obstruction and also check that the Cartridges are not stuck or misplaced.
Reply me for any further assistance on the Issue.
If the printer is only showing that error 1200 then take care of both the AIO and cartridges reset. Both have to be done.
Thank you Sir, Have a nice day.
Oct 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
What is error #1200 mean.
Hardware Error: 1200
The All-In-One is stalled.
1. Press Power to turn off your all-in one.
2. Unplug your all-in-one fro the wall outlet.
3 Check for paper jams.
4 Plug in your all-in-one
Cartridge Error: 1200
The cartridge carrier is jammed.
1. Turn off you all-in-one
2. Unplug the all-in-one form the wall outlet.
3. Open the control panel.
4 Open the cartridge access door
5. Make sure the cartridges are snapped in place in the carrier.
6. Check for objects obstructing the carrier.
7. Plug in your all-on-one
8. Press power to turn your all-in-one back on.
Hope this resolves your issues.
Oct 02, 2009 | Lexmark X4270 All-In-One InkJet Printer
My lexmark X4250 is showing an error code 1200.
It means that you have a paper jammed somewhere in the machine. Check in all the places where the paper moves for some scrap of paper that may be covering a sensor.
Aug 22, 2009 | Lexmark X4250 All-In-One InkJet Printer
What is error #1200
System error code 1200 means "The specified device name is invalid." This error code may also display as "ERROR_BAD_DEVICE" or as the value 0x4B0. ..
Aug 18, 2008 | Lexmark Office Equipment & Supplies
HOTPOINT ULTIMA 1200 WM72 Error Code
f30 code means there is a problem within the motor curcuit,check connections at the motor and check motor brushes are not worn.
May 05, 2008 | Hotpoint Ultima WF860 Front Load Washer
Bosch Excel 1200 wahsing machine, when trying to activate spin, it shows the normal 10 minutes, but then goes straight from 8 mins to 1 min and items arent properly spun
bosch exxel 1200 washng machine
has error message 04 and wont drain or spin
what does this mean?
can you help?
have lost instruction book
Mar 27, 2008 | Washing Machines
Lexmark X4270 All-In-One InkJet Printer Logo
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
