My d7300 was working fine, I installed a second printer (fax/copy/print) and then uninstalled the second printer. Now my d7300 wont print
SOURCE: My printer won't print from the computer command; it will print fax or copy a paper.
MY PRINTER WONT PRINT FROM THE COMPUTER. IT WILL COPY A PAPER, BUT NOTHING FROM THE COMPUTER COMMAND.
Posted on Nov 11, 2008
yooperbud
  • 8637 Answers
SOURCE: My printer HP F4185 doesn't print but it scans and copies...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
  • 45 Answers
SOURCE: hp office jet 4255 printer not printing anything or copying
ok..first try to make a copy and check if it copies fine or not..
if it copies then hardware is working fine..
turn off the laptop and unplug the USB cable..
turn on the laptop and wait for 5mins and then connect the USB cable..once the USB cable is connected do not try printing..wait for the hardware to get installed..
and then go to the printers folder and check if the printer icon says 0 ready..if it says then try printing..that should work
Posted on Mar 09, 2009
False jam
Please try the below steps ..
  1. While the printer is ON, disconnect the power cord from the printer.
  2. Restart the PC
  3. Wait for 30 seconds.
  4. Plug in the power cord to the printer.
  5. Now try printing, it should work.
If issue still exists, uninstall the printer software, restart the PC and then re-install the printer software.
Aug 14, 2014 | HP Officejet 4620 e-All-in-One Printer,...
Everything works fine on my printer.... scanning, sending faxes, copying... but just recently, when receiving incoming fax transmittals, the phone rings... a connection occurs... then 30 seconds goes by...
First make sure you cheaked the printer connection. Second retriy it again.IF it not worked you need to see your enginer.Ask he or she he should help you to instal l another operating software computer
Aug 24, 2011 | HP Officejet Pro L7680 InkJet Printer
My printrer is properly installed ,it prints a test page lovely it copies beautifully , but it wont print a document in word , it keeps telling me no printer found , please add a printer
It is possible that no default printer is installed, go to printers and faxes and right click on your printer and select "Set as default" and check.
Else the simplest way is to uninstall and reinstall
Apr 24, 2011 | HP Photosmart 2575 All-In-One Printer,...
Lexmark z45 not working with windows xp. i installed a lexmark z45 on my laptop that has windows xp and it will not print
Check the printer status:
1 Click Start > Control Panel > Printers and Other Hardware > Printers and Faxes.
2 From the Printers folder, double-click the Lexmark Z45 printer icon.
3 From the Printer menu, make sure:
– Default Printer is selected.
– Pause Printing is not selected.
Check the printer port:
2 Click the Ports tab.
3 From the list of ports, select the USB printer port. If the USB port is not listed, uninstall and then reinstall the printer software.
4 Click Apply.
5 Click OK.
Make sure you have not installed multiple copies of the printer software:
Windows XP: From the Start menu, click Control Panel Printers and Other Hardware > Printers and Faxes.
In the Printers folder, make sure there is only one Lexmark Z45 printer icon. If you have installed multiple copies of the printer software, uninstall each copy. Then restart the computer and reinstall the printer software.
If the printer port is incorrect or you have installed multiple copies of the printer software, uninstall and then reinstall the printer software:
1 From the Start menu, click Programs or All Programs Lexmark Z45 Uninstall.
2 Follow the instructions on your screen to uninstall the printer software.
3 Restart your computer.
4 Reinstall the printer software
Oct 27, 2009 | Lexmark Color Z45 InkJet
Unable to add a functioning (second) printer, for greyscale.
Clicked on Start/Control Panel/PrinterI. Clicked Add a printer. Obtained (Copy 1) of my HP Photosmart C7280 all-in-one printer. Right clicked on (Copy 1)/properties. Opened Ports tab. Saw comment "Print to the following Ports. Documents will print to the first free checked port." A listed USB Virtual printer port, showed three printers -- my first printer, my copy 1 (& my fax printer) -- was unchecked. I placed a checkmark in this Port box. Both the original printer, and my copy 1 printer are printing just fine. *I have not checked to verify that my fax is functional.
I did rename the original "color". I renamed Copy 1 as "grayscale", and --under printer preferences, checked, under "color options", to print in greyscale.
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
Hp office jet 4255 printer not printing anything or copying
Feb 19, 2009 | HP OfficeJet 4255 All-In-One InkJet...
My comp. says my printer i s hook up put will not print the fax copy od scan works fine
check your print queue is empty, if not clear it (double click onprinter, select cancel all docs on printer menu. if that doesn't work, uninstall the software and drivers completely, unplug printer, restart computer then download and install latest drivers. plug the printer in when the software tells you to
Aug 30, 2008 | Lexmark Office Equipment & Supplies
Printer wont print
i just bought a different printer. the staples people immediately agreed to take it back after i told them the make and model. you should do the same
Oct 09, 2007 | Lexmark All-in-One Printer with PictBridge
Reformatted computer worked while now recives faxes wont print
Uninstall all of the software and go to this link http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:439:0:0 install the updated version of your printers software and let me know what happens.
Jul 19, 2007 | Lexmark X4270 All-In-One InkJet Printer
24 people viewed this question
jasbo
jasbo
