Question about Electrical Supplies
Breaker will trip but switch does not always kick over to off posistion
  • 73 Answers
It won't go to the off position, it always stops in the middle. you have to click it to off the flip it back on.
Posted on Oct 02, 2009
How to fix double starts from points kicking the breaker
If the breaker is tripping you need an electrician to check wiring, pressure switch shouldn't be a problem. Don't try to work your way around electrical, always remember the unit will last longer if electrical is running properly to unit.
Aug 31, 2014 | Goulds Pumps Goulds RGS2012PA -...
Breaker keeps tripping when water pressure switch kicks in
I don't know what the pressure switch operates, but I suspect when the pressure switch is actuated, it turns on a pump or a similar load. The breaker is reacting to the load after the pressure switch - not the the pressure switch itself. The switch doesn't make use of electricity - rather it stops the the flow of it, or sends it to something that makes either heat, light or magnetism (as in a motor).
Look at the load that is supposed to start or shut off when the pressure switch "kicks in" There is likely a problem with it - anything from a jammed pump, shorted winding in the motor, water in the motor, crushed / shorted wire, etc.
Nov 17, 2012 | Prime 10 Amp Circuit Breaker
Titan SCR4 tankless water heater. Breaker on water heater itself keeps kicking. Not in breaker box. I have 2 double breakers, 50 amps each in box, no problem there. On the water heater there are 2...
Breaker trips when heat on wire exceeds amp rating, or when breaker is bad.
Most breaker are slow acting, and do not trip immediately.
Shorted elect could cause problem.
http://waterheatertimer.org/Water-heater-is-tripping-breaker.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 15, 2017 | Water Heaters
The thermostast kicks on the fan bu the compressor does not kick on
Most of the time it will be your contactor outside in your condensing unit. It could also be your thermostat sometimes they click but the switch inside stat is not making connection. Also check your breaker panel and make sure breaker is not tripped it could be something as simple as that.
Be careful the A/C is 220 volts if you work on it make sure power is off. If your fan is working on the unit outside but the compressor will not come on you will have to install a superboost which are easily installed and about $30. they dont always work but its your last ditch effort to getting the compressor started.
May 09, 2011 | Heating & Cooling
Owohotpoint 7kg aquarius condenser dryer keeps tripping the power when i switch it on have emptied and cleaned all filters water drawers
is it kicking the breaker if it is check to see what amp it is, if it is a 15 amp breaker you will need a 20amp breaker
Aug 24, 2010 | Dryers
Everytime my central air unit kicks on my circuit breaker trips. It didn't do this last year or even earlier this year
A circuit breaker 'tripping' everytime the AC unit kicks on 'most always' indicates a direct short (somewhere in the condensing unit), although it is possible that the breaker itself is bad - (but not likely).
Usually the cause of this 'short' will be - either the condenser motor in the condensing unit (outside unit) or the compressor - also in the condensing unit.
If you're mechanically inclined - and "very careful" around electricity - there is a fairly simple way to find out which component is causing the short.
Step 1 - Make sure the condensing unit (outside unit) is completely disconnected (electrically) , i.e. pull the fuses/turn off circuit breaker on outside unit and turn off thermostat.
Step 2 - disconnect the condenser motor (this is the outside fan motor). Note: when you disconnect the wires of the condenser motor "be sure" you mark/write their location, and wrap them in electric tape.
Step 3 - start the AC unit. If the breaker trips again you can pretty much rest assured it's the compressor that is shorted.
To prove it (without a doubt) - go to next step.
Step 4 - "be sure circuit breaker and thermostat is turned off" - and - 'reconnect' the condenser motor - and - then disconnect the compressor wires (mark wires and tape them).
Step 5 - Start AC.
If breaker doesn't trip - you know it's the compressor that is shorted.
If breaker 'does' trip again - then it's possible the breaker itself is bad (not likely) or there is a 'short' in the condensing unit's "wiring" somewhere (not likely).
My guess is that either the condenser motor or compressor is shorted.
Hope this helps.
Good Luck!
Jun 10, 2010 | Heating & Cooling
Heat pump kicks breaker outside in main breaker panel
the start capacitor is bad. Motors develop what is known as lock rotor amperage. requires alot of torque to turn the motor until it reaches iits rated or run load amperage. the motor is not able to overcome the lock rotor amps which is usually 5x the rated amperage and always more amps than the breaker. this is usually not a problem because the start capacitor helps overcome the LRA so quickly that it doesnt trip the breaker. If the capacitor is round and bad it will be bulged at the top, if it is oval shaped then the rupture disc on top will be blown letting all the dielectric fluid out which cools the capacitor
Dec 10, 2009 | Haier Energy Star ESA3183 Air Conditioner
I have 60 amp circuit breaker on my electrical a/c heater with a 45 amp fuse. I had the unit for 7 years with no problem. This month the 60 amp circuit breaker keeps tripping when the heater goes off. The...
You're unit is a 31/2 ton according to the numbers.Normally, breakers will only be in a half way posistion when tripped. Yes, under most conditions, the fuse will blow before the breaker trips. I have seen this many times, the breaker may be weak, burned, loose wires and so tighten wires, check the condition of the breaker.It sounds like the breaker even though it is 60 amps, is the problem and you should replace it with out hesitating. This will solve you're problem. When you pull the breaker out, look at the metal clips that snap in on the buss bar to see if they have been overheating.And the buss bar its self. You will know. I am sure this will take care of you're problem. Good Luck,
Shastalaker7
Dec 07, 2009 | Goodman CKL42AR42 Air Conditioner
Our washing machine will kick the breaker after sometimes 2 minutes of washing, other times it will go completely through the cycle. Another time it went 13 minutes and then kicked the breaker. Not sure...
What value breaker are you using?
Its also worth noting whether it is a 'B' type breaker or 'C' type.
For example you should have a breaker that says B6 or C10..
This could be different as Im in the UK but my sockets run from a B32 breaker.. 'B' Rated 32 amperes (amps).
I've noticed that the washing machine is a steam washer, so I'm assuming it has quite a big element inside to create the steam.
Now I'm not sure if this is tripping your breaker because its going over the maximum load for your breaker or if its tripping to to the inrush current.
The letter that goes before the fuse rating of your breaker (B or C) signals what surge the breaker can take when the equipment or machinery is switched on. If the surge is greater than the rated breaker it will trip.
B types are most commonly used in houses but a C rated breaker could be used if it kept tripping from the inrush current (the sudden surge when machinery is switched on or a heating element kicks in).
If you know any electricians I would get their opinion and see what they say, uprated breakers are quite cheap approximatly £5 in the UK.
It could be a few things but it doesn't sound like a fault on your washing machine as it should blow the fuse in the plug first..
I hope that helps
Mike
Nov 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
When my compressor tries to kick back on, it bogs down and trips an internal breaker switch.
When finding a home for any compressor you need to take a few things into consideration. Extention leeds can create a voltage drop. for a standard compressor you will need at least a 40 amp trip switch at fuse board the draw of first start up could be a higher rating than your current breaker
Mar 12, 2009 | Air Tools & Compressors
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
