Maytag Neptune FAV6800AW Top Load Washer
Problem for Maytag Neptune FAV6800AW Top Load Washer
Locked rotor
By biggsrm on Oct 02, 2009
locked rotor
Best Solution
posted on Oct 02, 2009
Very Helpful)
dh1200s
Rank: Guru
Rating: 94%, 102 votes
Hello biggsrm,
All my comments are regarding troubleshooting for the FAV6800AW or FAV9800AW is that your machine model type? Sorry to keep asking this questions but many folks post different machine types in the FAV6800AW forum. If your machine is not one of those model’s disregard my post. I'm and owner of the FAV6800AW machine.
The Service Manual for reference. Sears Parts Direct for reference.
For the FAV6800AW the Lr error code = Locked Rotor: The machine has repeatedly tried to turn the motor. This could be caused by drive system binding, and failed Motor Controller, a failed Control Board, and a failed Motor. There could be loss of signaling to/from the Control Board from connector CONN P-25 on the Control Board to JP-4 on the Motor Controller and anywhere in between within the machines wiring harness. Without known good parts this could be a difficult problem for a DIY’er such as me or a repair tech to troubleshoot. I have all known good ebay major parts for this machine so it’s easy for me to troubleshoot. If you decide on a service repair call I would make sure the service tech call has all of the above parts.
But let’s check the washer drive system for binding no charge to do this;
Can you lift he lid of the washer and rotate the wash basket in the Counter Clockwise direction. The Wash Basket should rotate with one finger with what I call the pinky finger test with very slight rotational resistance in the CCW direction. I’m trying to get a feel for drive system binding issue. The wash basket under normal conditions will not rotate in the CW direction. What are your results?
If you have a measure of Wash Basket CCW rotational resistance it could be caused by the One-Way rusted roller clutch bearings, rusted Outer Tub Bearings, and the roller bearing located in the Spinner Assembly brought on by a slight leak with the Tub Seal. I’m not saying this is the trigger for the error we are doing non intrusive troubleshooting and we need to start somewhere. Do you detect any excess drive system binding in the CCW direction of the Wash Basket?
Assuming you can clear the Lr error will the machine let you do a Spin Only cycle with no clothes in the wash basket? What are the results?
If you can get into Service Mode try the Quick Spin Test on page 14. Do you pass that test? If not I would then try the Motor Control Board Output Test on page 15 next. You will need to remove the front panel of the machine and disconnect Connector JP4 on the Motor Control Board. If you feel you are not qualified to check 120VAC measurements on the machine then it would be time to call in a qualified Maytag FAV6800AW repair company. I would make sure they have hands on experience with the machine type to reduce misdiagnosis with troubleshooting and cost to you.
Post back if you have questions. Rich
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" thanks for the manual saved me " - biggsrm
Popular Solutions for Maytag Neptune FAV6800AW Top
Questions and Unsolved Problems for Maytag Neptune FAV6800AW Top
Do you recommend Maytag Neptune FAV6800AW Top Load Washer?
Answer
Answer
My clothes are stuck in my neptune. It won't drain and the door will not unlock. How can I restart... (More)
Answer
my top loader will not hold water it keeps draning out!!
Answer
my maytag washing machine stop working totally mid cycle. I'm not getting anything when I turn and... (More)
Answer
My Neptune TL is not completely draining. I've got the tub out but am having trouble getting the big... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machines Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
