Question about HP Office Equipment & Supplies
I can fax using my printer - donot know how to
I can fax using my printer - donot know how to use his feature please help i do have a land line telephone
hp officejet 4315 all in one
Sorry I botherd you - I did not have the phone line in corrctly
when I figured it out the fax worked fine
Posted on Oct 03, 2009
It will not send fax. I receive my internet vi. telephone land line and it is EARTHLINK and have a maagicjack on line with a zyxel p-600 series rout.
your sending a fax from the printer using landline phone. is the printer plug in to the telephone line. if you have one phone line you can use it for internet or for faxing.
Feb 17, 2016 | Dell 946 All-In-One InkJet Printer
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Fax won't answer
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Sir, O/G FAX goes but i/C Fax not coomes Please
Have you pressed the button to enable incoming faxes on the keyboard of the printer? The button should have a light next to it so that when incoming faxes are enabled you know about it. Once you press that button the printer will allow them to come through.
You also need to confirm the settings in the printer under the fax catagory and choose the number of rings before the fax machine should pick up a call and whether an incoming fax should have a different ring tone than a regular phone call ect.
You can access these choices by using the software installed in your pc under settings. Or you can press the menu key on your printer and use the up and down arrows to scroll the features and press enter or ok when you find the one that you are looking for.
There should be two catagories for fax choices. One is usually called fax and the other fax - advanced ect. Try checking the features available in both to make sure all of your options are set that way that you want them to be.
You can also try press the start button when an incoming fax is on the line. This will manually start the printer to accept a fax that is trying to come through.
Sep 14, 2011 | Canon FAX JX210P All-In-One Inkjet Printer
I have a lexmark x5650 printer and I can send a fax but I cannot recieve a fax. Can you please help me?
Ensure that the telephone/fax line is plugged into the Line port on the back of Lexmark printer and not in the Phone port.
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Jul 26, 2011 | Lexmark X5650 All-in-One InkJet Printer
Can send faxes but not receiving them and yes there is paper in fax
Make sure the correct fax number is assigned on the printer. If you have an answering machine connected to the same line as your fax, configure it so that the answering machine picks up first then the fax. For more information, please refer to this article: Change Number of Rings on Inkjet AIO to Alleviate Issues with Answering Machines.
If you have a voicemail feature associated with the fax line, please disable the voicemail. Voicemail feature and the fax will not work together in the same line.
Jul 05, 2011 | Lexmark X4270 All-In-One InkJet Printer
Cannot get the fax to work... need to know correct hookup please
ok look on back and take your main phone line and install where it says line in. Take the next spot and put your land line phone cord and install it in line out. If you have dsl for internet get a "t or y" and put on line out. always make sure the fax has the first line in.
Jan 03, 2011 | HP Officejet 4315v All-In-One InkJet...
I am getting rid of my dedicated fax line and am adding it to my land line. I am told when I have a fax coming in I will hear a double ring which mean my fax line is ringing. How do I set my fax to...
There are two ways to configure a fax machine to answer the phone line. The first way is by pushing the "auto answer" key on the keyboard of the fax itself. When this key is used, the fax machine answers all calls that come in after a certain number of rings. The other way is to manually press the fax button when an incoming call is happening. You can set the number of rings for your machine to pick up by using the keys on the fax machine under the menu feature and then scroll using the up and down arrow keys until you see fax set up and then number of rings.
I have heard about the option that your speaking of, where they give you a separate phone number for your customers to fax when you own a business line but I don't know how the fax machine itself would be able to distinguish between the normal ring of a regular call and the double ring of the merged fax line call. I was told that when I set that up for my friends business recently, that the machine would auto recognize the double ring without any programming and to use the auto answer feature for all calls. He has not had any faxes yet (its a new business) so I can't say for sure if it works or not? I can say that none of his regular calls have been picked up by the fax so far though.
Nov 10, 2010 | Canon PIXMA MX310 All-In-One Printer
I donot know how to use a fax machine can u jst please explain me that
Make sure is connected to a phone line with filter if you have a DSL line. Dial the number you want to fax and press start. More Info "use your Manual" if you don't have it, find it on this link:(I could be take some minutes to load it in pdf file, be patient you may need to refresh the web page) http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_640CW_EN_242.PDF
Mar 26, 2010 | Brother MFC-640CW All-In-One InkJet...
Setting up fax feature
get a separate telephone cable and attach it to your fax, switch line over from phone to fax manually at the phone line input on the wall, it's the ONLY way I can manage that same problem. If you forget to "switch" your lines over, unplug the fax from the wall & answer your other house phone that's plugged into the wall. Works every time. It takes a little effort, but why pay for more phone lines when all you have to do is plug/unplug an extra phone line?
May 16, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
88 people viewed this question
Seeker5211
Seeker5211
