Question about HP Office Equipment & Supplies
I can't install a new cartridge in my printer.
I am trying to install a new black and white cartridge on the printer for my computer. When I turn on the printer and open the top of it, the cartridges move at a rapid pace. There is no way I can get them to stop so I can remove the existing cartridge and install the new one. How do I get the cartridges to stop moving so I can remove one and install another one in its place?
Also, can I buy ink for the cartridge, and since my cartridge has obviously run out of ink, install the ink in the cartridge? What kind of ink do I buy, where do I find it, and how do I install it in the cartridge? Thank you.
Turned computor off, and only printer on. Carriage stopped right in the middle to allow installation!
Posted on Oct 03, 2009
I had been out of color ink for a few months, so just printed using black&white mode. I installed a new color cartridge, and the computer is not acknowledging that a new cartridge is in. It will only...
Start, control panel, printers, your printer, printer preferences, advanced. Uncheck the complete-a-print boxes and also check to make sure the print in black & white box in unchecked.
Rick
Sep 12, 2011 | Dell 926 All-In-One InkJet Printer
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
Only prints black and white,it has two new cartridges hp deskjet d4260
You could try to do a power down reset and reinstall your cartridges.
First turn off computer
remove the 2 ink cartridges,
press power to turn off printer
unplug printer from ac outlet
wait 3 minutes
plug back printer
turn on printer
wait until printer stop
reinstall both cartridges
turn on computer
Dec 03, 2009 | HP Deskjet D4260 Printer
I suffer from white streaks and light printing. A new samsung black cartridge was installed, same problem. Colour printing OK. Machine is only on it's second black cartridge.
Clean your printer head and nozzle with printer utility software. Hope it would solve your problem, if not, open the black cartridge and fit it again and try to print again. Though, not work, perhaps problem in you black cartridge, so purchase an original cartridge. Thanks.
Oct 31, 2009 | Samsung CLX-2160N All-In-One Printer
Printer will not print in color
If there isn't a specific accessible program for the settings of your printer, open my computer and right click on your printer. This can also be done by opening the "Control Pannel" and selecting either "Hardware and Sound" on Vista and "Printers" an Vista classic view or Xp. There you should be able to find a colour managment setting. It sounds to me that your printer is set to "Black and White Only Default" or your colour managment is set to "Text Colour Only"
Hope this helps
Sep 07, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Doesn't copy
Is it working perfectly while printing? Have you try to install a new cartridge?
Try to turn off and reinstall the cartridge again. Also shutdown the PC. Then power on PC & then Printer.
Sep 28, 2008 | HP Photosmart C3180 All-In-One InkJet...
Installed black print cartridge will not print now?
nope, there should be no tape on the cartridge. This is preventing the ink from coming out.
Jul 30, 2008 | Lexmark X6170 All-In-One InkJet Printer
Printer not working!
Usually black is provided by the black cartridge only. You might be able to setup the printer through the control panel using black and white printing until the color cartridge is replaced. That might turn the color cartridge off allowing you to print.
Jul 27, 2008 | Lexmark Z1300 InkJet Photo Printer
Tri Colour cartridge inserted is not intended for use in this printer msg
Try to clean the print cartridge contact points with a good rubber eraser and clean the printer side cartridge contacts with good lint free cotton cloth. Then first insert Black cartridge and then colour cartridge. Use some more pressure while attaching the cartridges.
Apr 22, 2008 | HP PSC 1315 All-In-One InkJet Printer
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
