Question about Frigidaire Dryers
The door on our Frigidaire dryer Model #AEQ7000ES1 is not closing right. There seems to be a problem with the hinge on the door. Can you tell me how to fix it?
I took the door all apart and found that there was a bolt that had wiggled loose from the hinge. I tightened it up, & it works just fine now.
Posted on Oct 04, 2009
No heat to the dryer. Everything else seems to function properly. Frigidaire AEQ7000ES1. Receiving E9 Error code.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101]][
Jul 18, 2011 | Frigidaire Electric Dryer
The door is bent a bit and now won't shut right unless slammed just right. I doesn't look bent but must be. I know I have trouble opening it after a wash where it seems stuck and I am sure the previous...
That model has 2 hinges on the door, and one or both of the hinges are probably bent, not the door. The good news is that they are pretty cheap to buy the hinges, and it only involves 8 screws, its an easy fix. After you do that, if you still have problems with the door lock, then it probably got damaged from the door closing when it was bent, and you would need to replace either the door lock or the door strike if the strike on the door is broke. I have replaced many of these hinges for this problem, and havnt come across the door lock getting damaged in the process, but have had to replace a few broken door strikes. hope this helps, good luck.
Oct 23, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Frigidaire electric dryer aeq7000es1 low heat only code e4a store
this is a door switch issue make sure the door switch is not broken
Sep 14, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Model gltr1167oaso\ door hinge seems bent
Are you sure someone has not used their knee to push the machine back into positon and have distorted the front panel.
Worth putting a straight edge across the front of the machine where the lower bit of the door gasket stops to see if there is a dip there
Jun 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Dryer door/casing is loose on hinge side of door
you can go to repairclinic.com and enter your model number. It will list all the parts. Find your hing and screws and your set.
Apr 13, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Beeping from refrigerator about once a minute.
If this is listed under the right model, then the only thing it could be is some models have a
door alarm,that will beep if the door is not closed. You could check and clean the gasket.
Or it the switch that tells the fridg that the door is closed. Check if there is a top door adjustment to bring the door closer to the fridge where the door hinge is. This might apply or push on the switch more.
Mar 29, 2009 | Samsung RF265AA Bottom Freezer French Door...
Dryers Logo
183 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
