Question about Sony Playstation 3 (PS3) Console
Playstation 3 turns off for every ten seconds and I can't update!
My Playstation 3 turns off for every ten seconds I turn it on. I have a 60GB with a 40GB HDD. I tried installing 3.01 in the PS3 with a 2.70 firmware. However, I received the error code 8002F14E when I installed 90% of the update. Now it won't detect any other firmware under 3.01 and I can't send the PS3 to Sony since I am fixing this myself. What should I do?
  • 6,784 Answers
HI. You will need to Clear Any Failed system updates that cause the console to error. Use this procedure to acheive this .
  • With the console off, press and hold the sync up button (the small white one)
  • While holding the sync button press the power button to turn on the console
  • Continue to hold the sync button until the Console has booted up completely.
  • During the boot process the console should clear any failed updates, allowing you to use it normally.
Posted on Oct 02, 2009
  • 3 more comments
  • Michael Masters
    Michael Masters Oct 02, 2009
    If none of the above suggestions work, contact MS customer support get get a support ticket started. If your console is still under warranty DO NOT attempt to open it and fix it yourself. MS will fix it promptly and for free and if you open it you loose the free support.
    Check the documentation that came with your Xbox 360 for contact information.
    In the US Customer Support can be reached at 1-800-4-MY-XBOX (1-800-469-9269)
  • Michael Masters
    Please excuse the above post. Your issues, clearly, involve the PS3 console and not a XBOX 360. The actual solution will still apply, but the procedures are quite different as you know. You will need to clear the firmware update that is causing this error.
  • Michael Masters
    OK, from what i have gathered, Sony is not aware of this flaw at this time. the best advise here is to try to back up the system by restoring the original firmware update that was installed before you tried to upgrade to the 3.01. Apparently, there are many issues and complaints that are being flied at this time that concern the nature of this new update.
  • Michael Masters
    The majority of these issues are most likely coincidences. Every major firmware release seems to Shutdown a lot of consoles, but when my original PS3 shutdown, it was randomly during the DMC4 install. The likely scenario is that those that shutdown were going to fail soon anyway, and it just took something relatively taxing like flashing the firmware or installing an upgrade to push the Hard drive and core to the edge. You stated in your post that you are not able to send the unit in for repair, but this may be your only choice in this matter. The is a possible hard disk issue.
  • izzahmed Jun 10, 2011
    where is sync up button located?
Ps3 60gb freezing
Try this use your vacuum to suck out any dust that is in machine from front and back. Use compressed air (duster used on electronics) and spray the cd area and back area again, vacuum out. If this doesn\'t help then Call Sony PlayStation for replacement of machine.
Jun 25, 2013 | Atari Tales of Graces f - PlayStation 3
Hello, i started up my 60gb playstation last night and it ran fora few minutes then turned itself off. Turned it back on and it would stay on for a few seconds and turn off,repeatedly. Did it this morning...
If its an unwanted christmas present, I'm guessing its still under warranty, so call sony. They'll fix it for free. Your problem sounds a bit...irregular.
Mar 25, 2011 | Sony Playstation 3 (PS3) Console
Won't turn on, won't eject disc
best thing to do to eject disk is
1.power of the console
2. hold the eject button and the power button down at the same time
3. then reach around to the back of the console and put the switich on
4. hold for ten seconds and thhe disk should come out
hope i could help!
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Re: Playstation 3 Console (60 GB) - Freezing I've had my 60GB PS3 for around 24 months and it has been fine. Recently, it has started freezing in two ways: 1. Either just leaving the playstation doing...
I seem to have a very similar problem to yours on the 60GB as well. I am curently doing the total reformat but it takes a long time to do it and i have to go to work while it is reformating. So anyway if it works i will let you know. me e mail george_masono@hotmail.com
Dec 29, 2009 | Sony Playstation 3 (PS3) Console
My Playstation is turning itself off after about 30 seconds. This has only happened since the most recent update. The red flashes and carries on flashing. It's an original 60GB, relase day playstation. I...
There's nothing you can do. Some firmware updates will brick your machine...especially if you update with a disc inside the machine. It's Sony's fault, but since you're the consumer you're gonna have to pay. Right now there is a class action suit against Sony for very similar reasons. You can add your name to list but the bottom line is that you'll have to contact Sony for repair.
1-800-345-SONY
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Broken DVD & BR player
it sounds like your lazer is gone
Aug 14, 2009 | Sony Playstation 3 (PS3) Console
Update won't finalize even though I press PS button
try holding the power button down for 5 sec with the ps3 on this will put the ps3 back to default setting ....
Feb 27, 2009 | Sony Playstation 3 (PS3) Console
Ps3 turned off when doing update
1) Make the light on the front red
2) hold the front power button until u hear a double beep
3) You will get some type of message, I got a HDMI message, others have gotten a usb message...either way just follow the prompts to the end & it should reset.
4) If you dont get it the 1st time keep trying. Mine worked on the 1st attempt but I have read that others have taken more.
Dec 30, 2008 | Sony Playstation 3 (PS3) Console
PS3 60GB
Try removing the HDD via the little door on the left side of your PS3? Try an boot without the HDD then see what happens? I am up to my second HDD after my first one caused similar problems (60GB model). I hope that this helps?
Nov 13, 2008 | Sony PlayStation® 3 (60 GB) Console
Sony Playstation 3 (PS3) Console Logo
265 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
