Question about HP Office Equipment & Supplies
Printer won't power on.
I have a 7310 all-in-one. Last evening I got a low color cartridge message, this morning the printer is not working and I can't get it to come on.
I have checked to make sure that it is plugged in and that the power strip is active.
  • ednan1224 Oct 02, 2009
    O.K. This worked, but I don't know for sure why. After I plugged into the wall, and it worked, I replugged the printer into the same power strip and it worked there also.
    Could it be that the power cable is failing and the cooloff period may have caused it to start
    working again?
    In any case, thank you. You saved me from having to buy a new printer.
    Scholar:
  • 112 Answers
I know you've checked the power strip, but can you please plug the printer directly into a working wall outlet as a test? Also, make sure the printer end of the power cord is secure.
Posted on Oct 02, 2009
7310 All In One - running windows 7 64k OS problem: error blinking msg: error remove and check color cartridge. This is a fairly new cartridge, I have removed color cartridge rubbed it on a damp cloth -...
you need to change it, maybe you damaged it while trying to get it working. the clearly shows a faulty cartridge remember it can be faulty even as new or from the box
Oct 27, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Remove and Check Color Cartridge keeps appearing. I have changed color cartridge and message still appears.
is a non-original or defect color cartridge. ask for change cartridge to original. If still continues, ask for a new printer the cartridge bruned your printer board.
Jul 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Message says problem with tri color cartridge
I don't think the date on the cartridge is the problem. It might be the electronic on your color cartridge. If there is an orange light flashing and the printer won't pull the paper to print, in 99%, the problem is one of the cartridges. Try removing the color cartridge and gently wipe out the electronic with a dry cloth. Put it back in and try to print. If that doesn't help, try removing the color cartridge and print (I am not sure if that will work, because all in one printers usually need both cartridges in order to print, but you can try that too). You can also try scanning something and see what the message on the printers display tells you. If there is an E an the color button is blinking, I think you should replace your color cartridge.
Apr 04, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Color Cartridge Has Stopped Working...Lexmark Z45 Printer
i think this a firmware issue of the printer..
try to flash a new compatible firmware .
May 12, 2009 | Lexmark Color Z45 InkJet
Remove and check color cartridge
the internal circuit of the printer which connects the colour cartridge is gone faulty so this error.that internal circuit needs replaCEMENT.thanks
Dec 11, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Will not print color
later it would not print at all.
I replaced the printer with a new one
Sep 07, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Align cartridges error
This means one of the cartridges is defective, they cant align if they cant print.  What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center.  When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in.  I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black.
Basically you align the cartridges and then swap them so the printer thinks they are still aligned.
The color still doesnt work and it is probably a defective color cartridge.
Sep 04, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Hp 7310 all in one
First check that printer is not set to print B&W. Open an application to print a page, for example Word. Chose print command from the file menu on top bar , the print window will open.
In the print window press the 'properties' button, and check tha printer is set for color printing.t
Once you are sure printer settings are not in B&W, read the following.
Even if it shows color at 75, the printer color level may had not been reset since the cartridge had been replaced, in this case the cartridge may be empty.
If the cartridge is not empty it still can be faulty (eg. ink insid is dry).
In either case replace color cartridge with new original one.
If after you replace the cartridge it still does not print colors, then color head is faulty, at this point consider having the printer repaired by a technician.
Jul 22, 2008 | HP Officejet 7310 All-In-One Printer
7310 won't print magenta
Either you are out of magenta ink or your cartridge is dirty. Just because you've run a cleaning job doesn't mean the printer will fix the problem. The best thing to do is take your cartridge out and use a paper towel to gently clean the head (where the ink comes out). Once you wipe away the gunk you should still get the three colors on each pass of the paper towel over the head. If you only get two colors (yellow and cyan) then your magenta is empty or dried out (happens with ink cartridges used past their expiration date). The only thing you can do then is get a new in cartridge.
Nov 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
14 people viewed this question
Seeker5211
Seeker5211
