Question about NetGear DG834G Router
Dell laptop will connect to netgear wireless router DG834GT but cannot access the internet with security WEP applied
  • 30 Answers
That might be because you didnt configure ip address.try resetting the device.
Posted on Oct 02, 2009
    Guru:
  • 1,049 Answers
Do not use the passkey, use the hex key that it generates for you.
HOW DO YOU CONNECT A BLACKBERRY PLAYBOOK TOA NETGEAR DG834GT ROUTER?
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 15, 2012 | Computers & Internet
How do I rename the netgear connection and make it security enabled? I have WG602v2 router
Please follow steps to make your network secure and change network name.
1. Connect the computer to 1ST Accesspoint using a Ethernet cable.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the Accesspoint (usually http://192.168.0.227).
4. Login to the Accesspoint (Username = admin Password = Password unless you have changed it).
5. click on Wireless Settings in the left hand side menu under Setup.
6. Change the network name SSID to (any name) and click apply.
7. Click on Security Settings in the left hand side menu under Setup and select Security Type as WEP.
8. Select Authentication Type as Open System.
9. Select Encryption Strength as 64 bits.
10. Under Security Encryption (WEP) Key in the Key 1 box enter the same 10 digit key that was used on the router before.
11. Click Apply.
Hope this will resolved your issue
Thanks for using Fixya
Jun 12, 2010 | NetGear WG602 54Mbps Wireless G Access...
Need to find the wep key #
You will need to access your Routre configuration.
For this, open an Internet Explorer windows and navigate to http://192.168.1.1
enter admin for the username and password for the password
under wireless, select security and copy or change the key
you should avoid WEP, it's not really secure, use WPA or WPA2 if your wireless clients support it.
Feb 15, 2010 | NetGear WGR614 Wireless Router
Need a securty code
Regarding your concern, please note that in order to get the network key/password on the NETGEAR router (MODEL_NUMBER), we need to login to the router's web interface using any computer which is physically connected to the router.
Please follow the steps on a computer connected to the router using an Ethernet cable in order to find the network/security key:
1. Open the browser (like Internet Explorer, Mozilla Firefox, or Safari).
2. Access the router, usually by typing 'http://192.168.1.1', 'http://www.routerlogin.net' or 'http://www.routerlogin.com' in the address bar.
3. When prompted for Username and Password please enter Username as 'admin' and Password as 'password' (please note that both Username and Password are case sensitive).
4. Click on Wireless Settings' under Setup from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the pass phrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the NETGEAR router's wireless network.
In some cases, for security reasons the pass phrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
Feb 07, 2010 | NetGear WGR614 Router
I have two routers Netgear DG834Gv3 and Thomson SpeedTouch TG585v7. I want to create a wireless bridge between these two routers, so that I can have internet on the Netgear router. The main router/Access...
I am sorry but I am not so familiar with the Thomson Device but I can give you a clue on how to set it up....you can skip the security settings first just make sure they work then you can set it later...Check it out!
- Thomson as "Master Router" connected to modem set up as follows
-- 192.168.1.1
-- Set up wireless access point as you normally would in Wireless Settings, muine are "MY_SSID",Channel 2,b+g mode,
64-bit WEP with hex key (rather than pass phrase)
--- Enter any laptop wifi MAC addresses in the "Client Access List" here to allow them and make sure it's set to restrict
them
-- Set DHCP range to 192.168.1.10 to 192.168.1.127 (my preference) in "Lan Settings"
-- go to Wireless Bridging and Repeating menu option
--- Set "Enable Wireless Repeating Function"
--- Set as "Wireless Base Station"
--- DO NOT check the "Disable Wireless Client Association" if you want to be able to use laptop wifi
--- Enter the mac address of your "Slave Router" here
Make sure all of the above is applied and has stuck, i had a habit of setting some things then clicking to a sub-menu
before clicking apply, always scroll down and click apply before drilling into sub options!
DG834G V3 : "Slave Router"
-- Get latest firmware as earlier v3 firmware doesnt support WDS
-- 192.168.1.2
-- Enable Wireless Settings and set to exact same as "Master Router" including 64 bit WEP key and MAC access list for
laptops etc
-- Disable DHCP in Basic Setup (I think)
-- "Advanced Wireless Settings" menu option
--- "Enable Bridging and Repeating"
--- Select the "Wireless Bridge With Client Association" (or similar) option
--- Enter the "Master Router" MAC address here
Again, double check everything has stuck, that the "normal" wireless settings for both routers are identical and reboot
both (in either order worked for me but booting the Master first is probably best practise)
GOOD LUCK!!!
I
Oct 26, 2009 | NetGear DG834G Router
I dunno ow to secure my connection with my edimax router
You can read more about WEP and WPA in the following links:
This article explains how to configure WEP/WPA-PSK/Access list on NETGEAR Wireless router (also applicable to access points).
Note:
  • You can configure WEP or WPA. But you cannot enable both at the same time.
  • You can configure Access list and also enable WEP or WPA for additional security.
  • After you enable wireless security features on the router (or access point), you must configure your wireless clients (wireless computers) with matching settings. Your wireless clients will not be able to connect unless you configure matching settings.
  • Its recommended you enable these wireless security settings from a computer wired to the router (or access point).
Configuring WEP:
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  4. Under Security Options, Select WEP (Wired Equivalent Privacy)
  5. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
  6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
Apr 27, 2009 | NetGear WGT624 Wireless Router
Netgear locking
I'm assuming we mean wireless security?
Run your internet browser - Internet Explorer or Firefox type the router address in the address field (usually http://192.168.0.1)
Default user name of admin and default password of password
Click the Wireless Settings link in the main menu of the DG834GT firewall. There are a number of options available with WEP the most basic. For basic protection select WEP, put in a passphrase (anything you like) and the router will provide you with 4 keys based on your passphrase - take a note of the keys. When you try to connect to the router wirelessly (laptop, game console, etc) the router will require you to input one of these keys to verify your access and that should be it.
For further information to go the netgear website and have a look at the manual - http://kbserver.netgear.com/pdf/dg834gt_manual.pdf
Feb 26, 2009 | NetGear DG834G Router
Netgear wireless router DG834PN wireless access local only I can get internet on my desktop which is connected to the router via ethernet but I can connect to the router wirelessly on my laptop but only...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To start with plug the LAN cable, type 192.168.0.1
into your browser, a netgear window should come
up name is (admin) PW is (password) default.
goto to wireless settings.
Tick Enable Wireless Access Point
Tick Allow Broadcast of Name (SSID, give it a name
Under security options, Tick none
Hit apply and exit
Setup your laptop up with no security to start with, the laptop
Should now see the Netgear SSID name you made.
After this find out your laptops MAC address, log back onto the
Netgear unit, add the MAC address to the allowed list, hit apply
And exit, now only your laptop will be able to get a wireless connection.
Hope this helps
Have a nice day
Aug 14, 2008 | NetGear WGR614 Wireless Router
NetGear DG834GT
Are you sure you are entereing the correct passphrase, or is it a network key (usually entered in Hexadecimal). Is your Netgear router set up to use WEP or WPA or equivalient security?
Have a look at this thread. That may offer some insight.
http://discussions.apple.com/thread.jspa?messageID=6168599
Mike
Jan 05, 2008 | NetGear DG834G Router
Wireless not working with the router
k once u log in to router u need to click on w/l settings and
Wireless Settings   Wireless Network Name (SSID): Region: --- Select Region --- Africa Asia Australia Canada Europe France Israel Japan Mexico South America United States Channel: 01 02 03 04 05 06 07 08 09 10 11   Wireless Access Point Enable Wireless Access Point Allow Broadcast of Name (SSID)   Wireless Card Access List   Security Encryption (WEP) Authentication Type: Automatic Open System Shared Key Encryption Strength: Disable 64bit 128bit   Security Encryption (WEP) Key Passphrase:   Key 1: Key 2: Key 3: Key 4:
and if u want security password type any 10 digit no which u can easily remember one>and click apply do not hit generate>rate me solved if its helps
Oct 16, 2007 | NetGear WGR614 Wireless Router
NetGear DG834G Router Logo
129 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
