Question about Water Heaters
Bradford White LP water Heater Power vent ,flame keeps going out
I have a Bradford White LP water Heater Power vent. I reset the unit and it fires up and everything works for a while, then the flame goes out and the power vent runs continuously. I had a similar problem a year ago and had to replace the sensor on the vent, but this seems to function properly, what else could be the problem?
  • 119 Answers
Flue is overheating make sure outlet is not obstructed outside and if not that you feel a good air flow coming from it
Posted on Nov 15, 2009
I have a ecosense tankless water heater #rtg-74pvn-2 how far can i take the vent
Feb 2013
1) Rheem/EcoSense tankless product manual does not have specifications for length. Error 11 will let you know if venting is improper.
Often, tankless are installed outside because unobstructed venting is key for combustion of the amount of gas coming out of 3/4" gas line.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Copy following link for Bradford White venting: Exactly same as Rheem, but more installation detail. No maximum lengths given.
For lengths greater than 5 feet, a condensate trap must be installed. Acidic water from hydrocarbon combustion will damage metal, and destroy heat exchanger inside tankless if water drips back into unit.
http://hometips.me/Tls/Venting-Bradford-White-tankless-gas.pdf
3) Copy following link for tank-type power vent tables:
Generally, the longer distance requires larger vent diameter, and there is max number of elbows and/or air-flow restrictions.
http://hometips.me/Mar/Bradford-White-Power-Vent%20-tables.pdf
4) Otherwise call Rheem/EcoSense, and add comment saying what resources they offer.
Mar 06, 2013 | Water Heaters
Have 75 gallon gas water heater. Can I run 90 PVC off top power vent without vertical PVC first? Have Richmond unit.
1) I believe you can immediately elbow the PVC pipe.
There is a limit for how many elbows can be used between blower and termination, and limit is determined by diameter of PVC pipe.
2) Copy following link for venting resources and typical Rheem and Richmond power vent manuals, and diameter-elbow pdf from Bradford White.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#venting
3) Richmond is Rheem. Product manual will show specifications for venting.
Product warranty is voided if installation does not follow specifications shown in manual.
Feb 20, 2013 | Rheem Richmond 75 Gal Natural Gas 6 Year...
Reset button on water heater keeps tripping
Need a new thermostat to keep the unit from tripping
Feb 13, 2013 | Bradford White CF-50-6 50 Gallon - 119,000...
I have a Bradford White water heater (model# MITW50L6LN10) that started making noise yesterday. Tonight when the family got home we started a bath for the kids and surprise surprise no hot water left in...
Probably cheaper to fix existing water heater.
The problem might be the power vent, or the power vent might be short cycling because the gas control valve is bad, or vacuum switch has gone bad.
Call Bradford White and get their recommendation for your specific model.
http://www.bradfordwhite.com/contact.asp
http://www.bradfordwhite.com/supportserv.asp
http://www.bradfordwhite.com/findaserial.asp
Bradford White is very good brand of water heater
Rheem, Richmond, GE are good.
I prefer the AO Smith, American, State, Reliance, Craftmaster. Kenmore, Whirlpool brand since air intake screen is located on bottom of unit and can be inspected and cleaned without removing burner.
Feb 09, 2013 | Water Heaters
What should the gas pressure be on pilot?
Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Bradford White posts service manuals: Both before and after introduction of ICON (Honeywell) gas control valve
http://www.bradfordwhite.com/documentation/residential/gas.asp
Don't forget to clean air intake locate under combustion parts, using instructions in service manual. Or compressed air. Ample air supply will ensure that combustion chamber does not overheat because of slowed venting of hot combustion by-product that will trip the FV system.
And remove heat trap inserts if water pressure has problem or water heater is humming or whistling
Post question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Nov 28, 2012 | Bradford White MI40T6FSX 40 gallon LP gas...
How do you test a safety magnet on a robert shaw gas valve
Bradford White:
Bradford white service manuals:
Depending on age of water heater, The air intake may need to be cleaned.
Remove combustion parts and use compressed air to clean arrestor screen located bottom of combustion chamber.
Get more fresh air to unit.
Check gas pressure.
Check color of flame, should be clear blue and not lazy yellow.
Install new gas control valve.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Aug 28, 2012 | Water Heaters
I have a Bradford White model# MITW50L6CX10, serial# TA4176718-130-131, 48 gal., gas, power vent. The vent is running constantly, and when the burner lights it burns erratically even going all the way out...
1) First suspects include Honeywell icon gas control valve, loose-or-bad wiring, and dirty burner parts.
2) MITW50L6CX10 blower number is 239-39785-00. Blower is working, but communication between blower and gas control valve are suspect.
Water heater has 6 year warranty
Water heater was manufactured January 1999.
3) Typical service manuals for M-1-TW-50 TTW series show how to test and replace Icon gas control.
Multimeter is required for testing.
Also shows how to clean burner parts and combustion chamber and air intake to catch up on regular maintenance.
http://www.bradfordwhite.com/images/shared/pdfs/manuals/46238-A.pdf
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 09, 2011 | Fasco Bradford White Hot Water Heater...
Bradford White LP water Heater Power vent Will not stay lite. I took off the pipe to the power vent and it will stay lite for a little while. Then it turns off and turns back on. The pipe is not pluged....
does the fan come on, if not there is a problem with the circuit board, if it does then there is a problem with the gas valve or a wire from the gas valve to the fan , if the fan doesn't come on the gas valve is told not to open to light thru the circuit board,
May 03, 2009 | Water Heaters
Water Heaters Logo
394 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
