Question about HP Deskjet 6940 InkJet Printer
Poor paper feed with large printings - HP Deskjet 6940 InkJet Printer
    Guru:
  • 1,049 Answers
This is a known issue, the printer is not designed to do large volume. A thicker paper helps a little, as a rougher paper. If you have to use the old plain glossy white typing paper then using "rubber renew" or some other similar product on the pickup rollers helps in the short term. Just keep in mind that inkjets like this are really designed to print a couple pages or to make hard copies of photographs, not for large jobs.
Posted on Oct 02, 2009
How does new paper go in
fold the paper about half inch down and feed in along fold
Mar 14, 2016 | Casio HR-100TM Two-Color Printing...
Epson C86: paper not feeding and prints at an angle
try feeding the paper through manually if you cant do this then try printing a blank page and see if this still wrecks the paper if it does then it does sound like something is jammed on the roller the best way to clean this is with a blast of air from a compressor this is the only sollution as it will cost more to replace the parts than it would to buy another printer if it is still under warranty they should replace it for you if not you could take it to a computer repair shop where they will strip it down adn rebuild it for you this is a paper feed problem but im sure their must be somethig sticking in the way or maybe the paper feed has come lose at the one end sorry i couldnt help you any more ........................................
Oct 31, 2007 | Epson Stylus C86 InkJet Printer
My Konica Minolta bizhub C250 seems prints about every 10th page crinkled and crooked. I can hear it going through the machine and crushing a crease in the paper as it prints. The printed also seems to...
The paper may not be feeding straight out of the paper tray due to poor stacking of the paper in the paper cassette. try another paper tray or check the paper in the paper tray for folded over papers usually near the bottom. Also try feeding paper from the hand feed tray on the left side. This uses a different paper path.
Dec 07, 2010 | Konica Minolta bizhub C250 All-In-One...
Poor paper feed.
It seems that the paper feed mechanism is dirty. please clean it with a moist soft cloth/tissue. NOT WET but MOIST. As regards printing goes, reinstall the printer drivers as per the link below. Installing Devices on PCs and Laptops
May 17, 2010 | Epson Stylus CX4700 All-In-One InkJet...
Will not print text from computer (paper feeds
PGBK cartridge was totally blocked. Deep cleaning did not resolve block. Replaced ink cartridge (large black).
Feb 07, 2010 | Canon PIXMA MP160 All-In-One Printer
My printer will not feed paper, when it tries to
the rubber rollers that feed the paper might be dusty so the paper slips
May 17, 2009 | Canon Pixma MP500 All-In-One InkJet...
Won't feed paper
empty out thr paper supply, check the paper feed area for debris, blow out area with compressed air (Computer Duster), fan paper carefully and re install.
retest machine
Ed
May 04, 2009 | HP PSC 1610 All-In-One InkJet Printer
I have an okidata 320t that is loading wierd. The alarm light is on when I put a paper in the top feed the alarm light goes out, but the paper doesn't load untill you push the SEL button and then when you...
1st try the easy stuff is the leaver set as paper feed or tractor feed if that is set correctly then you most likley have a gear problem and they need to be replaced.
open up the printer replace all the gears on the right side and the large gear on the left
they cost about 8 euros each and if it does not park correctly just clean out the bits of paper stuck under the paper load leaver the leaver is small black and bobs up and down if it does not bob up and down it means that there is a bit of paper stopping it. (to do this you have to remove the large black roller that feeds the paper)
thanks Hackeridis
Apr 16, 2009 | Okidata 320 Turbo Printer (Remanufactured)
Hp 1350 all-in one psc
your paper feed problem may be due to the feed rollers or due to the fact the mecanism that raise the paper doesn't function properly. Normally if you clean the rollers that should work
Jan 25, 2009 | HP PSC 1350 All-In-One Thermal Printer
I have a Dell 946 printer that is a couple of years old. It has started printing crooked on the pages. I have done the alighnment and that did not fix the problem. Can you help?
probably no much you can do the correct the problem because The problems that users encounter while using a Dell printer
varies with the model. However the common problems all Dell printer models suffer from are their slow speed and faulty paper feed mechanism. Quality of prints varies from one model to another, but most of the models do not produce prints having very fine qualities. A Dell printer is particularly notorious for its poor and faulty feed mechanism. They tend to cripple the papers or take in large number of papers at a time and print parts of documents on each page. They keep on generating messages indicating lack of paper, no matter the paper is being supplied or not. Such a problem makes the printer absolutely useless
Nov 20, 2008 | Dell 946 All-In-One InkJet Printer
HP Deskjet 6940 InkJet Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
