Question about Sewing Machines
Juki DNU 241
Was working fine and now will not pick up bobbin thread, not to long ago had a thead mess around the bobbin but none visible around the carrier or around the bobbin now. any help would be much appreciated!!!!!!
thanks Gary
  • squaw2007 Jan 03, 2008
    my kenmore 15343was working fine and now will not pick up bobbin thread, not to long ago had a thead mess around the bobbin but none visible around the carrier or around the bobbin now. any help would be much appreciated!!!!!! I have tried looseing the bobbin tension but did not help
  • 323 Answers
SOURCE: Juki DDL 8300
You need to do a tension test.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn't do this you ned to rethread it through the tension discs and make sure the thread is between the discs.
sewman7
Posted on Oct 11, 2008
rylee_smith
  • 8619 Answers
SOURCE: my Juki DL 5555 won't pick up bobbin thread
It is possible that you have the bobbin in backwards. Try inserting the bobbin so that the thread pulls in the opposite direction than it currently does. Also, sometimes you have to really push the bobbin case in to make sure it snaps into place. Other than that, you may have a dull needle...try replacing it, or it just may need an overhaul.
Posted on Jan 30, 2009
  • 3 Answers
SOURCE: Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Posted on Mar 07, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
ladydijjmp
  • 9 Answers
SOURCE: Top thread keeps getting wrapped around bobbin case on LX-3125
You should hold the end of the thread coming through the needle until the thread has grasped the bobbin thread.
Posted on Jun 30, 2009
When I rewind my boobin, the thread is too loose. How do I adjust it on a JUKI DNU 1541-S?
You're saying the thread on the bobbin is loose/sloppy? That would be a result of the tension placed on the bobbin during winding. Make sure you are using the correct threadpath to wind the bobbin, or the winding tension needs to be adjusted.
https://www.sewingpartsonline.com/juki-dnu-1541-parts.aspx
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwiikseM2J3XAhUE72MKHSV2Bg8QFggmMAA&url=http%3A%2F%2Fdanreetz.com%2Fjuki%2FJUKI_DNU-1541-S-7EM01_SERVICE_MANUAL.pdf&usg=AOvVaw250Npk5Blb-ZBGHGIFqwyy
https://www.manualslib.com/products/Juki-Dnu-1541s-3329212.html
Nov 01, 2017 | Juki Sewing Machines
Juki dnu-1541 S hard to turn
indicates needle thread tension not tight enough
the jamming may be from thread and fluff wound tight around the bobbin shaft an locking it up
remove any threads and other material from the bobbin shaft and bushes
take it in for a service
Nov 19, 2016 | Juki Sewing Machines
I have juki 1541 industrial machine needle want pick up bobbin thread??
Is your needle inserted correctly? Try taking it out and inserting again. Is your bobbing threaded correctly? Try taking it out and re-threading. You might also try cleaning the bobbin area. The only other think I can think of is that you may have the wrong needle in.
Feb 13, 2015 | Juki DNU-1541 Industrial Walking Foot...
Why does my Juki 1541S not pick up the thread from the bobbin when it is supposed to?
hello Zipporah
please see attached, hope it's helpful for what you are asked about.
best regards
May 20, 2014 | Juki DNU-1541 Mechanical Sewing Machine
Why does my thread keeps breaking when backstitch on Juki DNU-1541?
you didn't say if the top thread was breaking or the bobbin thread
here are some suggestions
May 04, 2014 | Juki Sewing Machines
Juki ddl 8700 my machine was sewing fine I put in a heavier (jean) thread. Now it wont pick up the bobbin thread to sew at all? Help?
try changing the needle to one that will work with heavier thread
you may have to change the bobbin to heavier thread also
try adjusting the tension also
Sep 25, 2012 | Juki DDL-8700
Juki, DNU-1541S: thread was not picking up the bobbin thread. The hook shaft is not moving... After trying to move the needle in a reverse motion... Now the hand wheel will not move it is frozen in place.
You've got something binding in the bobbin area. Open up the entire bobbin/feed dog area plates so you can really see. Get your magnifying glass out and really examine the area for threads wound around things. DO NOT unscrew anything if you can help it. If you unscrew the wrong thing you can knock it completely out of time. (which may be why couldn't get the bobbin thread up anyway.)
If all this is intimidating to you... take it for repair.
Sep 09, 2012 | Juki DNU-1541 Mechanical Sewing Machine
Need threading instructions for JUKI DNU1541S Threading Diagram
I also have a Juki DNU-1541S and I'v had nothing but problems. My bobbin will not feed out thread. The Pressure foot needs a wrench to lift it, the knee pad will not work due to the pressure foot being so stiff. YES, I've turned the knob at the top so much it's near comming off !!
The so-called "Instructional Manual" appears to be a "UNITED NATIONS" resolution in all languages. The English portions is barely enough to fit 1/4 page. A Manual ?? A JOKE is better.
Jul 16, 2011 | Juki DNU-1541 Mechanical Sewing Machine
Juki dnu-1514s The machine is threaded and and the bobbin is loaded. When I sew, the machine does not make any stitches. It's as if the machine is not threaded and I'm just running fabric...
Your bobbin system isn't engaged. this can happen for several reasons, mostly when things are a little out of whack.
The 1541 has a 'clutch' it located near center on the bottom surface and is a silver circle below the 'arm'. Bring the needle all the way down, now push the clutch and hold while you turn the wheel back (top away from you) eventually the clutch will click when everythings aligned and engage the bobbin system again.
Jul 14, 2011 | Juki DNU-1541 Mechanical Sewing Machine
Sewing Machines Logo
325 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
