Question about Denon RC-8000 LCD Touchscreen Remote Control
I need to fix the ENTER button.. I've removed the case screws anf do not want to damage the seam with a screw driver. Is thier some other catch or tang I'm missing.....THNX...Patrick
    Problem Solver:
  • 4 Answers
To fix this problem with the malfunctioning " Joy Stick", and or selection or enter button, you must seperate the Remotes halves. There are no springs or other parts that will come flying out when the halves are split. Do Not use a screw driver to separate the seams the best tool is a tool used by manicurist on cuticles or make your own. Squeeze the bottom half while moving along the seam. Once you have two of the plastic catches released, the others will come apart. Then remove the three philips screws that will allow you to remove the board and attached LCD screen. The LCD screen is attached with a ribbon cable. To remove this cable, first back off the cable pressure locks! What looks like the end of the cable is only a pressure lock and stays with the main board. Do Not get in a hurry with this ribbon cable! Use a magnifying glass to have a close look! Turn the board over and remove the " button boot", this will allow access to the joy stick. The joy stick button is a friction fit and can be removed with equal upward pressure. Now you are at , what is a five way switch. Study the switch with your magnifying glass and a good light, you will see how the metal bracket holds the switch together. Bend the catches back on only one side of the bracket. This will allow you to remove the joy stick and see the five small concave metal discs. These discs are tempered to make contact and return to there concave shape. The center disc on mine was not concave, but near flat. These small parts will want to get lost!! Move slowly! I removed the middle disc and used a gold plated RCA plug that was rounded just enough to match the concave design of the disc. A few light taps and the disc conformed to operational shape. Putting the small disc back into the switch was testy. Reassemble the unit slowly, pay attention to the RF antenna, you do not want to break the solder connections. Clean the LCD and be sure you have the ribbon cable seated all the way into it's clip.
My RC-8000 now works and fixing this pesky switch cleared up a few other odd things going on in my 5803.
Patrick J Horan
Posted on Oct 04, 2009
Instructions to remove keyboard from compaq laptop
Remove the Power Cord, Remove the Battery. Close the LCD Lid then turn the laptop over. Look inside the battery case to see if there are any screws in there, if so remove them. Sometimes the keyboard might have screws inside the battery case too. If that's the case normally you will see the keyboard icon next to the screw. The purpose of removing screws in the battery case is there might be some that hold the strip that is above the keyboard in place.
You can look at the rest of the screws on the bottom of the laptop to see if you see any that might have the keyboard icon next to it. if so remove that screw. Also sometimes there might be a screw that holds the keyboard inside the memory slot or any of the other slots so just look for them. If you'd like you could just remove all the screws from the bottom of the laptop.
Turn the laptop back over after the screws are removed, then take a small flat head screwdriver and pry the strip that is above the keyboard aloose. Normally this strip has the power button on it. Be careful removing this strip because there will probably be a cable attached underneath it.
Once the strip is removed there might be screws that hold the keyboard in place a the top of the keyboard, if so remove them. Now you can just lift the keyboard out but be careful because there is a keyboard cable underneath the keyboard that has to be removed. If the keyboard does not just come out then more than likely there are little catches that help hold it in place either at the top or on the sides, just work with one side to pry it from the catches then you will be able to get the keyboard out.
Apr 23, 2012 | Computers & Internet
Tip
How to Take Apart Your Xbox 360?
1. Insert your index and middle finger into the memory slot holes, place your thumbs on the bottom of the Xbox (for leverage), and pull the face plate off with a steady force. It should come right off. 2. Break the Microsoft seal off. (Note that this will void your warranty.) 3. Now, flip the Xbox on its side and take a close look at the holes located on the top and bottom of each side. If you look closely, you can see that some of the holes are filled in. This is because the filled-in holes are keeping the grey plastic pieces on the top and bottom of the Xbox in place. 4. To remove the top and bottom grey pieces, use a small pointed object. Locate a grey plastic tab by peering into the holes, then use your pointed object to carefully push down and lever out the grey top/bottom cover. Both pieces have three tabs/clips per side, with a total of six per piece. To remove the top grey piece, you will have to remove the rubber pad. This is the only rubber pad you will have to remove. 5. With the grey pieces removed, take a close look at the back side of the Xbox. On the right and left side there are small notches that will require closer inspection. You again will need a small screw driver or narrow probe. 6. Using the probe, start on the left side (near power plug socket) and push the catch a bit into the Xbox until it clicks, then use a screw driver to keep the two sides apart. Once the left side is done, start on the right side and do the same thing to the rest of the catches. 7. Once they are all separated, the bottom of the Xbox will lift away. At this point slide it around to the front side and undo the four catches, keeping the case together. 8. Now grab your Torx driver set. You can use a T10 and T8 to do the job. You do not need a T12. 9. Unscrew the six T10 black screws, then use the T10 to unscrew all the silver screws. Finally, unscrew the black screws with your T8 driver . 10. Carefully flip the Xbox back over and remove the DVD button arm assembly to keep it out of your way. You just need to pry it off the black plastic guide. 11. Next, remove the top cover. Watch the DVD button latch. 12. Disconnect the SATA connector and power connector from the DVD drive and lift it out of the case. 13. To remove the white plastic air guide, locate the notch on the top outward side, insert your probe/small screw driver, and leverage the air guide out. It should lift straight out very smoothly. 14. Disconnect the power for the cooling fans. Now, use your probe/screw driver to pry the fan catches out from the metal guard. This will allow you to remove the fan device from the Xbox case. 15. Look at the front of the Xbox on the RF module, and remove the white plastic power button. It is held in place by a clip on the top and bottom. 16. Remove the three screws from the front circuit board (RF module). 17. Once the screws are removed, you will be able to slide the front circuit board off the Xbox with a slight pull. Notice that it is connected on the lower left side. You should now be able to pull the entire circuit board right out of the case with relative ease. Be careful not to touch any exposed circuits. 18. The next step is to carefully lift the motherboard out of the Xbox case. With the motherboard removed, flip it over and locate the two X connectors on the bottom. These are what hold the heat sinks on the processor. You can remove this; just be careful. It takes a little bit of force, which could destroy your Xbox if not applied properly.
on Jul 22, 2007 | Microsoft Xbox 360 Console
Fin inside dryer drum loose and rattles can it be
get to out side of drum and tighten screws
Apr 25, 2010 | Dryers
Button worn and stuck
There are a series of molded plastic "hooks" on the top & bottom case running along the handle seam. Once you get the 6 bottom screws out, carefully (!) work a large flat-blade screwdriver between the case halves as it opens, working toward the handle. With careful application of pressure, the handle seam will pop apart. These hooks were only in the very first from production Carousel 4xxx & 5xxx and the Ektagraphic III series. Now you know why they were removed - - it's a pain to get the projector open !!!
Dec 09, 2008 | Kodak Carousel 4600 Slide Projector
How can I get the case of my Singer Featherweight II open?
To remove the cover of the Singer model 117 Featherweight II sewing machine:
Referring to the diagram below:
1.Remove the face plate by removing the single screw fastening it to the left end of the chassis.
2.
To make things easier, remove the presser foot (raise the presser foot and release the presser foot from its holder by pressing the black plastic foot release found at the rear of the foot holder, the foot will fall off.)
3.Remove the plastic see-thru slide plate that covers the bobbin. Remove the bobbin, and remove the two screws that secure the needle plate.Lift off the needle plate.Don't mess with the feed dog screws( Look closely at the" bobbin case assembly" and note how it is installed. The black thing you are looking at is the assembly. The chrome thing that looks like a hook is a fixed "bobbin case stop plate" , the case assembly fits under that and is supported by the hook race. Approximately 180 degrees from the fixed stop is a spring stop- note that the bobbin case assembly is free to rotate/ wiggle approximately 1/8" between these two points, and it is seated evenly in the hook race.Remember what you see so you can reinstall it later)Remove the bobbin case assembly with your fingers.
4.Remove the detachable tool case from the front of the machine by sliding it to the left.
5.The face cover is fastened to the chassis with four screws- two on the bottom which also pass through the bottom of the rear cover, one behind the face plate just above the lower thread guide, and one on the front of the machine behind the tool case. Remove the screws on the front and the left end, and loosen the two screws on the bottom ( if you are planning to remove the rear cover go ahead and remove the bottom screws completely.) There is no need to remove the screws that hold the auxiliary leg bar.
6.The screws are out- HOW DO I GET THE COVER OFF!?!
There is a hidden locking tab located just beneath the mylar seal that warns you to disconnect the machine before servicing and to close the cover before operating the machine. It is located just to the right of the needle plate and directly over the seam that separates the front and back covers. Don't remove the seal just slice it with a razor blade or utility knife right along the seam, make sure you cut all the way through the seal.
Working from the needle plate opening, take a medium sized flat-bladed screw driver and slide it under the rear cover just behind the seam (see photo) carefully twist the blade in a manner that both separates and lifts the rear cover off the front cover- it takes quite a bit of force and it will let loose with a loud snap. After the locking tab is loose the front cover is easily separated and lifted off the chassis.
unlocking the case:
a closeup of the tab on the front cover
7.The rear cover is held on by three screws. There is one through the back at the handle recess, and there are two screws accessible from the front after the front cover is removed. Lower the presser foot lever, pull the screws and the rear cover will come off easy. Good luck with your repairs.
Nov 10, 2008 | Singer Featherweight II 117
Xbox 360 freezes with HDD
Your X box needs to clean most important the fan,below an instruction how to open...
DON'T FORGET TO RATE;
Aug 17, 2008 | Microsoft Xbox 360 Console
Philips 50PF9631D menu panel
The control panel is fairly straight forward to get at.
Reove the stand from the tv, and lay the tv, screen down, on a flat surface. You should lay a cloth of some kind to prevent scratching to the casing.
Remove all the screws from the central metal plate on the back. You will need a torx T10 driver for these screws.
Carefully remove the plate. Note any cables which may be attached.
Remove the screws from the outer back casing and remove the casing.
The control panel is held in by two screws. Remove the screws and re-position the control panel. If the control panel is damaged it can be replaced.
Jan 30, 2008 | Philips 50PF9630A 50 in. Plasma Television
Playstation 2 doesnt work
You are posted in the Big PS2 section, so I hope you got a Big PS2, not a slim. If you do have a slim, I think your motherboard is shot. If you do have the big PS2, you need to open th case up and Disassemble it to find out whats wrong.  Your probably have a SCPH-50001 and when you dropped it some of the plastic inside broke.
You need to remove the 8 screws on the bottom, which are hidden by square screw covers. You can pop the screw covers up with a knife blade.  Remove the Warranty label on the cases seam next to where the power cable hooks in. Lift the case from the back slightly and pull it forward just enough to clear the CD drawer. Then roll the over cover counter clockwise being carfeul not pull reset/eject button cable loose. In this motion lay the case cover to the right side upside down.
Now remove the little screws holding the cd Drive cover on.  Yo may ned to use a screwdriver to put in the rectangle holes and pry outward to release the catch at the back of the CD drive cover.  See if you see any damage and write back a comment here . Hope this helps.
I can fix it for a reasonable price for you if you're in the USA.  www.playstationclinic.com
Oct 21, 2007 | Sony PlayStation 2 (PS2) Console
Dewalt DW911 jobsite radio
Got mine open.
There was a fuse inside - Replaceable - fixed the problem.
There were no hidden screws, none under stickers or in the battery box like suggested by others, and the 2 magic release screws not so. There are several deep screws requiring a long philips, but the entire seam is glued (why?) so to open the radio I had to hit the body near the seam with a rubber hammer to crack the seam loose once all the screws were removed, comes right apart. Put it back together without glue, just the screws, it will be fine.
Sam. DesertSolutions.net
Sep 06, 2007 | Dewalt DC011 AM/FM Radio
How to open case of Acoustimass module
Just a bit more info...a bit more detail
Remove the two screws from the case at the back.
Sit the unit in normal upright position. Use a good torch and look at the back of the unit along the top seam where the plastic case joins the main body - there are three latches to disengage along this seam.
1. The thumbwheel which turns to the left & exposes the tab. This disengages a simple Tee'd section on the wheel which stops the case sliding down. As long as you can see the tab this is disengaged.
2 & 3. On the far left & far right of the seam are simple lever latches which must be pushed back towards the main body to allow the rear case to slide down. Push these in then the case will slide down quite easily.
Sep 01, 2007 | Bose Acoustimass 15 System
Denon RC-8000 LCD Touchscreen Remote Control Logo
198 people viewed this question
Top Denon Televison & Video Experts
Jonathon summesfield
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
