Question about Cameras
Digital camera pictures come out white streaked
Digital camera pictures come out white and distorted - thick white lines/streaks are seen when the picture is viewed back on the camera - even though when the picture is taken, everything looks normal. My settings are ok.and to be sure, are set to the 'intelligent-auto' mode. The fault occurs
under different light conditions, indoor, outdoor and with or without the flash.
this fault still occurrs regardless of how the white balance set - i know a little about techy stuff and this is not a 'have you swiched on or enabled the....' type fault
  • 188 Answers
SOURCE: Pictures are all white when using the flash
it seems that the shutter of your camera is having a problem with. normally whin it gets stucked fully open it creats such problem. you need a help of a repairer.
Posted on Nov 06, 2006
SOURCE: Casio Exilim s500--horizontal lines in picture and autofocus creates blurry pics
It appears this problem is due a failing CCD device in many brand cameras. All the manufactures use the same source(s). I have not persued Casio as yet, but other companies are offering a recall to replace the CCD for free. I plan to use this approach with Casio. Search the web for "failing CCD in digital camera", it describes exactly what we are observing.
Posted on Dec 02, 2007
  • 244 Answers
SOURCE: White pictures and lines across pictures
Try this to isolate the problem.
Switch on the camera in auto and put it into full optical zoom. Now turn the camera to face you and angle it so that you can see into the lens without reflection. On full zoom the internal lens will be right up to the outer lens. Now press the button to take a picture. You should be able to see the shutter cover the inside lens and then open again. Did it completely cover the lens? It should do. If not then you will get an over exposed picture or a picture with lines across it.
Email me for more info and how to solve. daveward712@aol.com
Posted on Feb 28, 2009
zohail
  • 1223 Answers
SOURCE: Sony DSC-W30 white's out/streaks pictures
BAD CCD !
Just call Sony if u dont have warranty in that case they will also do it free of charge i am pretty sure this is the problem thousands are facing in different brands for ur reference i am giving u a link as sony has issued service advisories like this for this type of problems dont worry if u are not on list insist they will still do it free of charge !!
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
kindly rate me Fixya fo rhelp !!
Posted on Apr 08, 2009
SOURCE: Image flicker when viewing pictures in playback mode
You have the camera in Highlights mode.. while in playback use the up,down,right,left pad press it up and it will go through different displays like what settings you had the camera in when you took the picture then there is a graph screen... after that one is the highlights display which is what you have it on. Push up one more time to have it on regular playback mode. The manual explains this much better than I just did. If you have the manual you should check it out if my instructions dont help.
Posted on Apr 19, 2009
Nikon coolpix s710 pictures have a streak
I think your picture has a bright light source in the frame. In digital cameras this phenomenon is common that in some angle these streaks of lines are produced with very bright light sources. be careful not to include bright light source while taking pics. But if u have these streaks and line in all the frames, then better check your camera with the service centre.
Aug 22, 2014 | Nikon COOLPIX Cameras
How to fix olympus fe-340 streak and peaks verticaly when picture taken
Not sure you can fix this, but most of the time the stripes are produced in a dark environment with one or a few bright lights. The streaks start on the bright light. Most of the time if you shoot the picture the streaks are not on the picture.
You could try to switch the camera to the automatic, or perhaps night scene.
If the streaks are there in normal light, I think your camera is defect.
Jul 27, 2014 | Olympus FE Cameras
Streaks like little roots or little tree branch on my pictures
is this not a problem with your lens rather than PC - best was to check is to take two separate BLACK (if white marks) or vice versa, pictures and see if the "tree" is on exactly the same place on all pictures
good luck.
Jan 30, 2013 | Kodak DCS 14n Digital Camera
Yellow black and white lines streaking across the screen
tyr to factory reset device on advance settings
with out the memory card
Apr 29, 2010 | Casio Exilim EXZ75 Digital Camera
Picture pink tinted and with streaks
It is known problem of ccd imager chip failure in canon A95 camera. CCD imager chip will be replaced to fix this issue.
Canon offers free of cost repair of ccd imager problem in A95.
Click Canon CCD Imager Advisory for details.
Thanks.
Dec 19, 2009 | Canon PowerShot A95 Digital Camera
White horizontal streaks
This sounds like some kind of lens flair. Make sure there are no bright light sources at about 45 degrees to the lens and it should correct this problem. If it is not that then there may be a problem with the CCD, the part that receives the exposure. Without knowing if this is a point and shoot or digital SLR this is the best answer I can give.
Oct 05, 2009 | Cameras
White streaks on photos
Light leak, definately a light leak. You need to change or add foam around the chamber to prevent any light from entering.
Jun 15, 2009 | Canon EOS-AE-1 35mm SLR Camera
Gray cloudy spot in center of photos;distorted light streaks
Time for another. Sell yours to a repairman in an ebay auction, keeping your accessories, and buy a working used on without accessories cheap.
Or this may be a good time to either buy another TZ3 refurb w/warranty(90 days I think) or a new one one Ebay. They are very reasonable since being replaced with the newer TZ5.
Oct 12, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Blue streaks across picture
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
Jan 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Cameras Logo
79 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
