Question about Canon Powershot SD450 / IXUS 55 Digital Camera
Batteries discharge quickly even if the camera isn't being used. I have three batteries and two are over one year old.
  • 2,200 Answers
Hi
It is recommended that if batteries are not going to be used for long periods they should be removed from the camera altogether during that time.
If you are referring to rechargeables the ability to retain charge is effected both by the age of the battery and the number of times it has been recharged.
Canon cameras are generally one of the better cameras in terms of being economic on power. It is likely that this problem is battery related and not camera related.
As it is also important not to mix old and new batteries together - I would recommend that you purchase new rechargeables. Three new rechargeables batteries in your Canon should resolve your problem and give the best results.
Thanks for using FixYa.
Posted on Oct 02, 2009
My battery comes dead really quick is there a way to boost it?
check the mhr on the batteries you use
they should be re-chargeable batteries as alkaline batteries do not have what it takes and run down very quickly
the re-chargeable battery should be around the 2000 mhr rating
Mar 30, 2015 | FUJIFILM Cameras
Battery Uses
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 31, 2012 | Olympus SP-310 Digital Camera
Batteries drain very quickly
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 06, 2012 | Fuji FinePix S9500 Zoom Digital Camera
Hello. The batteries on my speedlight discharge
if you are using regular batteries I can't help you, but if your using rechargeable batteries then the cause is old batteries, after many charges they don't charge well anymore. and you need to replace them
Mar 19, 2011 | Nikon Speedlight SB-800 TTL Flash
I keep getting a message 'change battery', even with new batteries. Camera is now two years old.
what kind of batteries are you using? are they disposable or rechargeable. if they are disposable the screen lcd will use it very quickly. buy some rechargeable batteries with high ma
Mar 06, 2011 | Canon PowerShot A430 Digital Camera
I have not used the headphones for at least three days. Even though the headphones are on "off" they continue to keep charging and have been for a couple of days. What is the reason for the...
My Sennheiser HDR 140 headphones charge whenever you hang them on the charger. The charger will "trickle" charge them to keep the batteries fully charged. If you find when you use it the batteries discharge quickly it's time to replace them.
My batteries are about 2 years old and I still get about 8-10 hrs of use before needing to recharge
Jan 04, 2011 | Sennheiser Audio Players & Recorders
I HAVE 2 BATTERIES AND THEY WILL NOT STAY CHARGED. THE CAMERA IS ONLY 2 YEARS OLD. DO I NEED TO REPLACE THE BATTERIES?
This might indeed be the case if you had the batteries for a while, and have recharged them several times. Unfortunately, even rechargeable batteries don't last forever, and need to be replaced. You can actually shorten this life of rechargeable batteries if you don't "discharge", or, "charge" them up correctly when first purchased, strange as that might seem.
Hope this helps. :)
Oct 02, 2010 | Sanyo VPC-E760 Digital Camera
Wont turn on
Only use Ni-MH or AA-size alkaline batteries. Do not use Ni-Cd (nickel-cadmium) because the heat emitted can damage the camera.
I would suggest using e2 batteries from Energizer.
In the manual, on page 80 there is a description and procedure for discharging Ni-MH batteries (but NOT regular batteries, so don't do this with regular alkaline batteries) AND do not do this when the external power is connected.
Moving on... The discharging of the batteries procedure should happen when:
  • the batteries last for a short time after being charged normally
  • the batteries have not been used for a long period
  • the batteries are new.
Follow these instructions:
  1. Press the menu/OK button to display the menu on the LCD monitor
  2. Press the "left" or "right" on the pad to select "SET" OPTION and then press "up" or "down" to select "SET-UP".
  3. Press the "MENU/OK" button to dipslay the "SET-UP" screen.
  4. Press "right" or "left" to move to option 5 and then press "up" or "down" to select "DISCHARGE".
  5. Press "right"
  6. Press "left" or "right" to select "OK".
  7. Press the "MENU/OK" button.
The screen changes and discharging begins. When the battery level indicator blinks red and discharging ends, the camera turns off.
Remember to not have the camera external battery plugged in so the battery can discharge on it's own.
Then, at this point, recharge the battery using the external battery charger. This helps to "renew" the battery. This is because Ni-MH batteries will remember the last place where they recharged, and too many times, the memory "bookmark" gets marked to low and has to be reset, done by the recharge.
It may be necessary to repeat these steps multiple times. This effect is not because the batteries are deffective. This is a normal side-effect of Ni-MH. This is the reason the camera comes with a discharge feature.
I the batteries are old and don't function even after performing the discharge procedure as part of the normal operation of the camera (like of the year or two), then the batteries may have reached the end of their service life.
Hope this helps, if so, please rate FixYa! ThankYa!
Nov 04, 2007 | Fuji FinePix A360 Digital Camera
Battery
As you have probably already figured out it sounds like the battery is damaged. Due to the potential fire hazard I would immediately remove the battery even if the laptop is off and discontinue its use until you are certain it is working correctly. Laptop batteries are not safely repairable by users and most technicians. Other than inspecting for bent pins there isn?t much you can do. If the battery is less than a year old you can call Dell, tell them it doesn?t work and see if you can convince them to warranty replace it. Batteries should not become unusable by a normal 3-4 foot drop. If it?s out of warranty I strongly suggest you try to borrow an identical battery to see if it behaves normally, or if that isn?t an option purchase another. Let us know if you have any other questions and please don?t forget to rate this post.
Mar 30, 2007 | Dell Latitude CPX Notebook
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
78 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
