Question about Frigidaire FEF375E Electric Kitchen Range
Model FEF375BHBB Heating Element Problem
The double element isn't working correctly. The smaller inner ring element won't come on.
2 Suggested Answers
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
  • 55 Answers
SOURCE: Front left dual element on a Frigidaire ceramic
open the door and look under the top remove the screws and the top will lift
Posted on Jun 23, 2009
0 characters
1 Points
Kenmore 790.9641* free-standing electric range: The "single" (inner) part of the dual radiant element is not working. When the knob is turned to the single side, the ELEMENT ON indicator lights, but
The inner ring or center part of the element is burned out. You will need to replace the entire element, as it is not possible to replace just part of it.
Dec 19, 2014 | Kenmore Kitchen Ranges
Model 790.96009601 I replaced the heating element that burned out. New heating element does not work.
The replacement heating element could be defective, not burned out. Also, the replacement element could have been installed incorrectly.
Oct 29, 2014 | Kitchen Ranges
Inner 6-inch element on the 12 inch/6 inch Dual Radiant Element cycles off too long
Sounds like the file is corrupted. That doesn't mean the footage is irretrievable. I believe the file type is .mov on that camera? You need to find a .mov repair program, there are lots out there. I don't want to give you a link since I haven't used any of the .mov ones and don't want to accidentally give you malware, so I'll leave that part up to you. But you should be able to get your file repaired, just google ".mov repair."
Nov 15, 2013 | Whirlpool Kitchen Ranges
The oven heating element won't turn off
I would thing if you called an appliance service store or retailer and gave them the make and model number of the stove they can sell you one and maybe install it if you need them to but I would thing it would be called the oven switch
Jul 24, 2012 | Kenmore 91112 / 91114 / 91117 Electric...
The Schoot Ceran top on a Solitaire range has cracked through the left 2 elements. Can this be repaired? If so, where can I find a reapirer in Normandy, France?
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Jan 08, 2012 | Kitchen Ranges
Oven won't heat, all burners work
I suggest that you remove the upper and lower heating elements to the oven, turn the oven switch to on, then use a good digital voltmeter, and check the plug that the lower heating element was in. If you have good (200 volts or more) then purchase and install new heating elements. Turn the oven switch to Broil setting and check the same way for the top heating element.
May 09, 2011 | Maytag Kitchen Ranges
My broiler and range work but my "bake" option will not produce any heat??? Please help!!!
If this is an electric range, it sounds like you have a bad bake element in the oven. The broiler and bake features each have their own heating element. Thats why the broiler still works. The following link explains how to replace a heating element in an electric range:
If the model range you have this question listed under is correct, the part number for a replacement element is WB44K5012. It lists for about $25 at
If you have questions, or if the model number is not correct, please post back with your information so that I may be able to provide you with better assistance.. I hope you find this information helpful.
Oct 15, 2009 | Hotpoint RB757 Electric Kitchen Range
Heat element from range
turn of power 2 screws hold in element on back wat, unplg and replug new element. assuming model correct FEF336BC bake element part number 316075103..TURN OFF POWER ALWAYS LIVE!!!!!!!
Oct 30, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Need lower heating element for Model #JBP66C)K2CC.
If this is a GE electric range, the part is listed at Just type in your model number in the Search menu and the part is listed on the first page as item #820921, Bake Element. I hope this helps you. If this is not correct, please double check your model number and post back. If you need guidance on how to replace the element, please let know as well.
Apr 01, 2008 | Kitchen Ranges
Frigidaire FEF375E Electric Kitchen Range Logo
77 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
