The quality of the printing is poor. Grey smudges
The quality of the printing is poor. There are grey smudge marks/lines (horizontal) across the page in 4 or 5 places.
headstrong
  • 233 Answers
SOURCE: Smudge marks on paper; otherwise normal
try replacing the drum/toner cartridge with another.
if that does not work it is the Fuser. this is assuming the marks are always in the same area on the paper
good luck
Posted on Jan 07, 2008
CowboysFanZ
  • 99 Answers
SOURCE: Dell 3100cn-smudge
The print toner cartridge has a small trap door that opens to let the toner adhere to the paper. Remove the toner cartridge and locate this moveable panel on it. This roller is VERY sensitive, and can scratch VERY easy. Use a soft LINT FREE cloth to GENTLY wipe the colored roller if you see any toner build up. If that does not clear up the problem you will need to replace your Fuser Unit which will need to be ordered from Dell or a 3rd party supplier. Its a pretty easy process, and instructions usually come with the fusers. If you have a printer warranty they will fix it for you. Thanks! //CowboysfanZ
Posted on Apr 24, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: Poor quality smudge and ink blotting marks in the centre of any printed document
Try performing a test by printing a test page from Tray 1 and open the top cover as soon as the paper is 60% inside. The paper would jam below the toner cartridge before it reaches the fuser. Remove the toner cartridge carefully and verify if the smudges occur. This would eliminate the fuser. If the print quality is fine, then you need to swap the fuser.
Posted on Oct 30, 2008
Inkworks
  • 87 Answers
SOURCE: HP Laserjet smudges across entire page
More than likely you have a bad toner cartridge.
Inkworks
866-381-0541
Posted on Nov 21, 2008
  • 43 Answers
SOURCE: Printing black smudges across the page at 10 cm intervals
Most likely cause by the drum unit. Replace drum or upgrade printer.
Posted on Jan 24, 2009
Unwanted colour lines on prints
It may be time for a new printer. Colored lines are often an indicator that the printhead is worn out. Dark smudges on the back of the print are likely just a need for cleaning the inside.
Sep 02, 2014 | DSC GESTETNER - DSc38u Color Printer
There is a horizontal line grey in color
If this a P2035 printer using a toner cart with a drum in it. The drum has been exposed to light or has a smudge on it. take the cart out and look at the drum. This is a round light blue tube located at the bottom of the cart. It is the drum because it is the only thing in the printer that will print a defect three times on the paper. You could also print about 0 black sheets of paper through the printer and it will go away. This is because the drum coating is in layers like an onion. You must get rid of the exposed layer to get to on that has not been exposed to light.
Apr 02, 2014 | HP P2035N LaserJet Monochrome Printer
I have grey lines across my prints
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside, which sometimes results in dots.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Jan 05, 2011 | Samsung ML 1610 Laser Printer
Canon 850 IS Grey 'Smudge' on Photos
Sounds like your ccd/sensor may have gotten dirty. This is not common in point and shoot cameras, but can be fixed. You may send it to the manufacturer or for a faster turn around, take it to an Authorized Service Center. I know of one in Florida 305-653-7355
Apr 20, 2009 | Canon PowerShot SD850 IS Digital Camera
Inkworks
866-381-0541
Nov 03, 2008 | HP DeskJet 5650 InkJet Printer
Oct 30, 2008 | HP LaserJet 4250n Printer
Faint grey lines Every 1/3rd of a printed page
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge or cleaning roller but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Oct 22, 2008 | Lexmark Optra S 1855 Laser Printer
Color lines/dashes at top and middle of page when printing.
Amand321,
Your problem lies with the fact that you manually refilled your cartridges. This is not recommended by any technician I know and your solution is in the replacement of all your cartridges with genuine brother consumables. It is going to be expencive, but it is the only real solution.
Gremlin11
Sep 29, 2008 | Brother MFC-9420CN All-In-One Laser...
jasbo
jasbo
