Question about Canon Office Equipment & Supplies
Canon DR-3080 CII scans only half or right side of document
Purchased last year Canon DR-3080 CII; worked fine until yesterday; only scans half or right side of document; power off/on, reinstalled driver, checked scan settings; nothing worked; no service warranty; cannot ask Canon for free; must have service application initiated first before anyone from Canon tech support would talk to you; please help. Percy-San Diego
  • 490 Answers
Try all formats, Color, Grey & Black & white. If you have problem it could be the scan module. Check for loose contacts, but this is rare in a working machine.
S. Mohan
Posted on Oct 02, 2009
Canon DR-2580C scanner only scanning half the page. What could be the problem?
Select Auto for page size. The scanning software displays scanned image in many options, including 'fit'. Choose 'fit' so that you see complete image.
S. Mohan
Dec 29, 2011 | Canon DR-2580C Path-Through Scanner
My canon dr-3080 cii is running at a low speed. it was at its maximum and suddenly slowed down. rebooted cpu and switched scanner on /off and chcked settings with no results. please help
Scanner will continue to scan at the same Speed! The problem is in the computer. Check if you have enough disk space, do a 'defrag' on your harddisk, create extra space by deleting unwanted files. IF your processor is slow and if you are scanning in color or converting to PDF while scanning, it may slow down the output.
S. Mohan, Chennai, India
Dec 22, 2010 | Canon DR-3080CII Path-Through Flatbed...
We recently acquired a Canon DR 9080C Scanner and purchases and installed a SCSI card in an older HP Pavillion. The scanner works fine using the USB port, but when using the SCSI port I get an error when...
CapturePerfect ver 3 is on chargeable basis! You can download ver 2.0 from http://software.canon-europe.com/software/0022439.asp?model= Though this is listed under Canon DR 5020, it works fine with DR 9080C. DR 9080C has very intelligent features and ver 2 works fine. I do not know if there are addl features with ver 3.0. I have used for scanning over 500,000 docs.
S. Mohan
Aug 05, 2009 | Canon DR-9080C Path-Through Scanner
When ever I scan, Capture Perfect adds zero's to
On the screen "scan batch to file setting" in the middle of the page under "save as type" change "type of batch separation" to "none". This will fix the problem.
Apr 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Not scanning full page Canon DR-3080II/CapturePerfect
U should select 'Scanners maximum'  and try this. I have found this does not work midway, after some scans. So close and exit out of captureperfect, re-enter and try. This should work.
S. Mohan
Nov 19, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-3080 CII Scanner
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
Sep 10, 2008 | Canon DR-3080CII Path-Through Flatbed...
Duplex Scanning
I havent used WYNN wizard. I use Capture perfect ver 2.0 it is available free of cost. Try with it. If it is okay, then may be some setting is missing. If it remains same, then there be some hardware issue in the scanner.
S. Mohan
Apr 16, 2008 | Canon DR-7580
Image problems
The lower scanner unit moves when doing the shading adjustment (scans the little white plate on the top and bottem scanners). Most common problem is a staple interfering with the lower scanner movement.
Oct 02, 2007 | Canon DR-2580C Path-Through Scanner
Scanner Problems
uninstall the device and reinstall it
you need to reinstall the drivers
Mar 09, 2007 | Canon PIXMA MP780 All-In-One InkJet...
279 people viewed this question
old marine
old marine
