Question about Home Security
I NEED TO KNOW WHAT EACH OF THE FOUR PINS ON THE FEMALE RJ11 JACK ON THE PHILIPS MODEL # VC86775T CCTV CAMERAS. +DCV, GROUND, VIDEO, AND AUDIO.
3 Suggested Answers
robmcd27
  • 423 Answers
SOURCE: I GOT A SAMSUNG SOD14C , OKAY I WANT IT TO CONNECT
Well, your going to need RJ45.
RJ11 is telephony and has 2 pairs of wires. With that, you could use the Blue/Blue-White for power and the Orange/Orange-White for video. Then your stuck.
RJ45 has 4 twisted pairs.
To find out which has power, use a meter to measure your 24 volts.
Rob
Posted on Mar 09, 2009
  • 3 Answers
SOURCE: Need wiring map for RJ11 conector for Samsung SOD-14C camera
I guess this is an ongoing issue with Samsung cameras. Did anyone EVER figure this one out?
Posted on Mar 31, 2010
I need the total wiring diagram for camera [8pin rj11]
8 pin RJ45 (8P8C) male connector
at the camera output
LG LVC-CY100NM Color Security Camera with 8-pin RJ45 (and other cameras for the LSP-M1017M Dual Quad Observation Systems by LG)
Pin
Number Pin
Name Description 8 SPK Speaker (Hot) 7 VID Video Out 6 GRN Ground 5 SPK- Speaker (cold) 4 AO Audio Out/Alarm Out 3 VDC 12VDC 2 N/C RS-485- 1 N/C RS-485+ Note: Pin numbers are labled backwards in the manual (corrected above).
The camera is adaptable for use in any composite video application with the use of a balun.
on the output. I had noise-less video and clean audio across a 350 foot run of cat 5e.
Jan 29, 2013 | LG LVCCy100NM Color Security Camera with...
ATI Radeon X1659 Pro - Which pins carry the composite video signal on the 7-pin S-Video output?
Looking at the female socket, there is a flat 'key' (slot) at the bottom of the socket, there are four pins directly above that.
The composite pins are the two middle pins of the four. Looking at the female socket, the left of those two pins (pin 7) is the composite video ground. And the right of those two pins (pin 6) is the composite video signal.
Aug 15, 2011 | ATI RADEON X1650 Graphic Card
I am getting engine noise? i have a mono block amp for my bass and another amp for my mids. How do I hook up the stinger SGN20 ground loop isolator?
It goes between the source and the amplifier , I don't know if it will work with guitar pickups, but no harm in trying. Also designed for stereo, but you could try dual mono I suppose. Not sure if that will work either but here are the instructions. You will need 2 mono female Jack to male RCA and 2 mono female RCA to male Jack adapters, (unless your guitar output is stereo in which case you will need 1 stereo Jack to 2 RCA etc. Good luck, it might work but I don't think it was designed for the use you have in mind. Will you let us know how you get on?
Mar 07, 2011 | Stinger Sgn20 Ground Loop Isolator
How to crimp 1 end of cat 5e cable with rj11 connector that was cut off. What is pinout order that each wire should in the rj11 connector? the colors are: Black,green,red, yellow & clear. ...
The pinout of the modular camera connections is as follows:
Pin 1 ----------------------- Alarm / In
Pin 2 -------------------- +15Vdc Out
Pin 3 ---------- Intercom Audio Out
Pin 4 ------------------------- Video In
Pin 5 ------------ Intercom Audio In
Pin 6 -------------------------- Ground
Goodluck
Oct 18, 2010 | Cameras
How to install philips portable speakers to my hp computer
use a multi-out jack....it will have two out jacks(female) and one pin(male) to be inserted into the audio out jack on the computer, connect your speakers pins(male) to those 2 out jacks....
look for this.....buy it on ebay look for "Audio Spliter"
guess this helps...pls let me know leave a feedback for this solution...
reg
Apr 27, 2010 | Philips SBP1100/37 Portable Speaker System...
Sony Vaio VGN 'B series' - broken headphone jack.
Hi there, your question has two way you can fix it:
1) see speaker jack circiut on your motherboard, picture here
there are 5 pins to the jack socket, you may just find out 2 and 3 pin which is stereo audio output lines, and also need a ground 5 pin. then connect 3 wires go outside speaker. this way quite tough for you.
if you cannt do this way go next
2) find a USB audio card instead of onboard one. this is very easy.
reference here:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=usb+audio+card&_sacat=See-All-Categories
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 24, 2009 | Sony VAIO® VGN-N130G/B PC Notebook
I GOT A SAMSUNG SOD14C , OKAY I WANT IT TO CONNECT TO A DVR WITH BNC INPUTS, BUT.. MY CAMERA USES RJ11E WICH NUMBER OF THE RJ11 JACK BELONGS TO POWER, VIDEO AND AUDIO?? SO I CAN RECONNET?
I salvaged an SOD14C and found this out by playing around with it.
the 6 pin RJ11 is wired as follows, holding the cable, connector up, cable hanging down with the pins facing you the pins count from left to right.
Pin 1 is green it is the Microphone +
Pin 2 is red it is the +12 Volts DC
Pin 3 is yellow it is the Speaker +
Pin 4 is the bare copper shield it is the common (-12 Volts DC, Microphone -, and Video -)
Pin 5 is whitish clear it is the Video +
Pin 6 is black it is the Speaker - got-samsung-sod14c-okay-want-connect-kkfjmd05sw3quyoyjvycjykz-5-0.jpg
Hope this helps!
Mar 09, 2009 | Samsung Weather Resistant Security Camera...
Jan 20, 2009 | Samsung Color Fixed Security Camera...
Matsui m19lid618
A regular TV will not display a CCTV camera, because the CCTV outputs a 1 Volt peak-to-peak RF signal. A TV uses a broadcast signal, it is different. However, if the TV has a yellow "video in" jack on the back of the set, this will display the camera, as the yellow video in will process and display the CCTV signal on the TV. Let me know if this does not work.
steven.burman@commandtechnologyassociates.com
Dec 05, 2008 | Home Security
Home Security Logo
157 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
