Loading clicking noise on spin
Beko WMXD 760, loud clicking noise on spin. no other time. sounds like it comes from top right side as when I push the empty drum it clicks. Could someone please help with a solution or is it on the way out. It is only 14 months old.
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
Could be excuse me ..Bra wire in drum stick your head in and look, if so best way to remove is take out heater to fix only if you are confident in repair..Good luck
Posted on Oct 02, 2009
My beko washer is only six months old its washed all day. On last load it has started to make a loud metalic noise while emptying and spin its like something is stuck but filter empty
Is it out of warranty?? It sounds like the washer drum bearing failed. Do you use approved super low suds detergent? You can not use regular detergent it will corrode the drum bearing.
Jun 01, 2016 | Beko Washing Machines
Beko 510w
the beko washer sometimes the concrete balance blocks come loose and cause a banging noise unplug and take the top off check the concrete block on the top off the outer drum to see if it moves about tighten it up if loose then check the one down the front to see if louse
Sep 20, 2012 | Washing Machines
Washing machine makes a loud whining noise when in high speed spin that it has not made before. Noise seems to come from the soap inlet tube.
usually when a front load washer starts making noise in the spin cycle it's not good,most of the time it's from the owner using to much detergent,it eats the spider gear and then it's time for a new washer,the gear costs around 500 bucks,next it will start to bang around and get real loud,i've seen the rubber boot get ripped off because it bangs all around,if you're using alot of detergent most likely this is the start of your problem,when you read the back of the bottle the measurements are for a top load washer not a front load so you better check that,also you could have a broken shock,also you can pull the middle of the pump out and check to see if there are any filings in there,i've seen that before.put it on high spin and listen to it,if it sounds like a knocking sound don't waste your money and call someone in,change out the washer and watch the cd that comes with it and use less detergent,i hope this isn't your problem but when the noise comes from the spin cycle it's usually the spider gear.
Aug 26, 2010 | Kenmore HE2 Plus Front Load Washer
General electric top load washer model #wpre6100g1wt loud noise
Your problem could be one of 2 things either the base is pushed up in the center or the front apron is bent. The apron is the piece of metal that runs across under the top cover. To remove the front cover to see either use a putty knife to release the catch between the top and the front cover and pull front outward one side at a time.
Feb 25, 2010 | Washing Machines
When entering spin cycle, making a loud noise. I
Check your belt it may be lose. A lose belt will cause a squealing noise and the machine spin slower or take time to come up to full speed
Oct 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Washer not drain, with clicking noise
If it has a filter, clean it out and start again
Mar 15, 2017 | Whirlpool LSR7333 Top Load Washer
Kenmore Series 80: Loud clicking at spin cycle
sounds like spin tube bad will need to remove basket and gearcase to remove it
Sep 30, 2008 | Kenmore 20172 Top Load Washer
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Loud noise only during spin cycle and slight burning odor.
cooleyd, is the sound like a chunk a chunk a chunk noise. If so, your motor is jogging between the high and low windings. the motor overheats and thus the burning smell. This is a common failure on these GE's. They came out with a motor kit with new harness and start cap. Remove the front panel by pushing on the 2 clips just below the top on each side. The panel will pull out. See if yours has the kit. It will have a start capacitor on the right side in front. On the motor harnes there will be a white and white/red wire. If you have a steady 120V during this jogging, you need the motor kit. Now with-out being there Im just trying to point you in the right direction. Other things to check would be the drain pump itself and whether there is something in between the tub and basket...Catriver..post back.
Feb 13, 2007 | GE WBXR3100B Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
