Question about Haier HWD1000
Water is leaking from drain hose at the connection from the pump during the drain cycle. 4 year old front load washer
    Genius:
  • Haier Master
  • 1,474 Answers
Sounds like hole in hose, you can buy replacement hose ...£ 10.. approx,
Posted on Oct 02, 2009
Supra washer/dryer combo leaking significantly
In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Mar 20, 2013 | Supra SW5L65D Front Load Washer / Dryer
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Feb 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My Maytag MAV6000 washer leaks intermittently. In the past 3 weeks it has been used many times but has leaked 3 times. I removed the front panel to look at the pump and hoses and put the washer through a...
Realistically, a 10-year old Maytag is nearing the end of its usual life. The pump may be leaking at random times during a wash cycle. If you put 50% of the cost of a new one into repairs, it is time to thing seriously about replacement of the machine.
Apr 26, 2017 | Maytag Atlantis MAV6000 Top Load Washer
I have a 7 year old Frigidaire washer (Model #GLWS1349AS1) and the water drains really slow and the spin starts before all the water is drained and then the washer leaks as water is still in it during spin...
you have a restriction in the drain somewhere or there is something inside the pump housing,chk every line from the tub to pump to drain pipe and hoses for blocks or kinks
Apr 09, 2010 | Frigidaire FTF2140ES King Size Front-Load...
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Ge top load washer leaks from over flow during spin cycle
check your pump it may be partly plugged if it is try to clear or replace pump
Aug 06, 2009 | Washing Machines
Leaks
to jim, you may want to check the water pump closer, sometimes the water pump will leak a little during a cycle and the water will leak somewhere on the floor, not necessarily near the water pump.
to the second post (guest), it sounds like you have a bad water valve. the valve is not closing properly and causing water to leak thru.
Jun 20, 2008 | Kenmore 24032\24036 Top Load Washer
Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
Jan 17, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Haier HWD1000 Logo
119 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
