Question about Kitchen Ranges
Our oven will light but goes right back off why is the igniter going bad the stove is nut that old?
  • esmith31471 Oct 03, 2009
    it is a propane stove the igniter lights the pilot bar but only for a few seconds and then goes out again does not operate the oven what could the problem be the thermocoupler?
  • milten1
    milten1 May 11, 2010
    if it lights its not the ignitor need more info to help
    President:
  • 1,304 Answers
Thermocouple or gas safety valve
some ranges these are seperate parts
on others these parts are as one
Posted on Oct 03, 2009
I have an old kelvinator stove ,the burners work, but the oven does not . i'm hoping it has a fuse or circuit breaker that just needs to be reset. ( I had one just like it and the burners worked but t
Some old stoves did have a fuse for the oven igniter. It could be just a bad igniter. Check under the top panel and see if there is a small black cap toward the right side toward the back. If there is one then it is the fuse. replace the fuse and see if the oven comes on. You may still need to replace the igniter. If it an electric stove then the element is probabaly burned out or a wire burned off.
Oct 06, 2014 | Kitchen Ranges
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
My frigidaire self cleaning stove(FGF368GM ) isnt lighting.... how do i light my stove?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 16, 2010 | Frigidaire FGB24S5A Gas Single Oven
MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
heatman101
dfasfdas
May 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Stove will ignite, oven will not ignite
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
May 04, 2010 | GE Profile 30" Self-Cleaning Freestanding...
Frigidaire Gas Range--Oven not heating
Hello, Yes your igniter is going to be bad on this one...even if you see that it lights the igniter is old and should be glowing a brillient yellow..I would replace the igniter and you will be good to go. If you have any questions or concerns please feel free to comment. Good Luck! Mike
Aug 17, 2009 | Kitchen Ranges
Oven door blows open during lighting sequence
Hi CL,
This is a common complaint and, luckily has a simple solution. I'll start with the solution and (if you're interested in the "why" of it) conclude with the cause.
First (solution)... your oven igniter has failed.
Second (cause)... Your oven utilizes a "glow" type igniter. In order for it to glow, electricity is applied and the current flowing through it causes it to get very, very hot. This electrical current is monitored by a device called a safety valve. This valve is programmed to open up main gas flow to the burner manifold after the igniter "flows" 2.6 to 3.2 amps.
Igniters are tricky little guys. Unlike a light bulb (which is either good or it's bad) igniters get "weak". So what happens is the igniter gets to 2.5, then to 2.59 then to 2.62, then back to 2.5 amps. It goes up and down. But the 2.62 amp "flow" was enough to open main gas, but not enough to ignite it. So there it goes... up and down. All the while the main gas is opening and closing, but not being ignited. This gas accumulates. Then finally, the igniter reaches it's ignition temperature.
That's when you get the explosion. The "whoosh".
It's not that difficult to replace the igniter. Yours is a part #WB2X9998 and can be purchased at a local appliance parts retailer or ordered online.
PULL THE OVEN OUT SLIGHTLY, REACH BEHIND IT AND UNPLUG IT!!!
Tools required:
1.) 1/4" socket or nut driver
2.) Flat or Phillips screwdriver
3.) Pliers
4.) Wire cutters
5.) Wire strippers
Remove the racks and then remove the "floor" panel of the oven. Then remove the diverter panel/burner baffle. Basically, your goal here is to disassemble the bottom of the oven. You may need to pull the lower drawer out.
After you have gained access to the igniter...you'll see that it's attached to the main manifold with two 1/4" screws (take note of its' position and how it's mounted to the manifold, the new one has to be mounted exactly the same). Word to the wise, here... use a little bit of liquid dish soap on the threads BEFORE trying to un-screw these. This will lubricate the threads and keep them from stripping. If you don't heed this warning and they strip? You'll have to grind them off in order to get the igniter removed.
Wire cutter time... snip the 2 white wires about 3" from the base of the old igniter. Wire stripper time... strip those 2 wires about a 1/2".
Now the old igniter is out. Pull out your new igniter. Cut any extraneous stuff off the END of the wires then strip them about a 1/2". Now mount the new igniter to the manifold (where the old one came from). Now take one wire (doesn't matter which one) from the new igniter and twist it to one of the wires you cut and stripped while removing the old igniter. Then use one of the ceramic wire nuts (included with your new igniter) and twist it on the exposed wires clock wise. Make sure there is NO WIRE EXPOSED after doing this. If there is, remove the wire nut and cut a small amount of you twisted wire pair off.
ALL OF THE EXPOSED WIRE SHALL BE INSIDE THE WIRE NUTS.
Do the same thing for the other wire. Now tuck all of the extra wire away. At this point, you're ready to test your handywork! Set it to bake and watch her light up (without the explosion tis time)!
All that's left to do now is rebuild the lower oven, grab a coolada and get some cookie dough. I'll be over at 6:00 for snacks :-)
SG
Apr 02, 2009 | General Electric PGS968SEMSS Gas Range
Ovens not lighting magic chef
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Fridgidaire stove
You probably have a week oven igniter. Unplug unit first!!
Remove oven floor. Remove flame spreader. Igniter is attached to side od burner tube. It removes with 2 screws. Remove drawer to access connections. New igniter will come with wire nuts. Cut wires at old igniter, strip back insulation and connect to new igniter. The 2 wires can go either way. Re-assemble and test.
Nov 10, 2007 | Ovens
Kitchen Ranges Logo
79 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
