Question about Brother PT-1000 Thermal Label Printer
How do you center the word in the center of the label? Meaning if a lable is 4 inches long and the word is 2 inches long I want an inch on both sides.
    President:
  • 2,306 Answers
It's not a hi tech printer, to get close to that you need to space before printing and after, and use scissors to cut for an even label.
Posted on Oct 02, 2009
How many pieces 3.25 x 2.0 inches can be cut from a 8 1/2 x 11 inch sheet of Cardstock?
12. 3 across and 4 down with both the sheet and the labels in landscape rotation.
Oct 24, 2016 | Office Equipment & Supplies
I want to cut a circle where the outside line is 18 inches
To get a circle with a perimeter of 18 inches, you want a diameter of about 5.73 inches (just under 5 3/4 inches) or a radius of 2.86 inches (call it 2 7/8 inches). Get a compass, set its legs 2 and 7/8 inches apart, put one end at the center, and turn.
Oct 23, 2013 | Computers & Internet
We're using 4.00 X 2.00 inch labels. The barcode is printing just under an inch long when it should be about 2 inches long so our scanners cannot read the barcodes. The text is printing out the
in some barcode software you can see the preview. if you click on the barcode itself maybe you can stretch it out to fit better. or try swapping to 2 by 4 format and see if that works. good luck
Aug 12, 2017 | Zebra ZM400 Thermal Label Printer -...
I shut the water off to my house when I'm out of town. Now my icemaker doesnt get water. The line is not frozen.Did I ruin the water valve. mod # msd2456dew
take the cover off of your icemaker and use a 12 ga wire about 4" inches long with the ends stripped an inch. use the wire as a jumper and stick one end in the hole labled N and the other end in the hole labled M for 5 sec and remove. turn your icemaker off when you turn off your water
Mar 26, 2011 | Maytag Refrigerators
When printing from a Zebra TLP 2844, text is getting cut off. I am printing from internet software, center aligned. If there are too many characters, the text is getting cutoff on either side (I would say...
Check the drivers you are using, try downloading drivers from Nice Label or Segull Scientific. Setup the page size to fit all the text, use a ruler to measure the lables.
Apr 27, 2010 | Zebra TLP 2844-Z Thermal Label Printer
How to stop calibrating soo much?
There is no way to get around the recalibration for different sizes of label, you must do it at every different label height, The callibration only sets the label height/length, so try doing the same length labels in sequence.
Oct 22, 2009 | Zebra 105SL Thermal Label Printer
Serpent belt diagram
Your vehicle should have a black lable on the upper radiator support or on the firewall. This will have a white routing diagram on it. The lable is only about 2 inches by 2 inches square. Thank you, Dana
Oct 09, 2009 | 1997 Buick LeSabre
Zebra lp 2844 after printing 1 label , light change to red.
me have same problemo
i tried to update the frimware but still have problem
i think problem about lables? did u try bigger lables?
May 14, 2009 | Office Equipment & Supplies
140XiIII left side print right side completely blank
Verify your LCD Display Print Width setting is set wider than your actual label width. The printer will only print to the width of the PRINT WIDTH setting. Also verify any driver or software settings as these override your printer settings.
Jun 30, 2007 | Zebra 140XiIII Plus Thermal Label Printer
Brother PT-1000 Thermal Label Printer Logo
65 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
