Question about Miller Electric Mfg Co 903394 Deltaweld 452 MIG Welder, 3- Phase, 15 - 38 V
Wire slows down during welding and then suddenly jerks back to correct speed.i installed a new board and it did not fix problem. i also checked the brushes on the motor and they looked fine. its a series 60 dual feeder. i switched to the other side and all was fine.
    Problem Solver:
  • 18 Answers
Try replacing the potentiometer, this is the variable dial which alters the speed. It should show the value in ohms on the back of the case, these are relatively cheap and can be bought from RS. Its sound like the wiper in the dial is loose.
Posted on Oct 07, 2009
Car speed slows down and speeds up runs a little rough when speeding back up it does a jerk.
Dear Debbie,
Fuel filter costs about $ 20 plus installation, catalytic converter about $100 up to $ 600 plus installation..
Go for the fuel filter first.
If it is not that, do a diagnostic check before you do the catalytic converter.
The "cat" seldom is the problem.
God bless your efforts.
Mar 23, 2016 | 1998 Honda Accord
Acquired snap on ya219 that didn't weld. Replaced the capacitor. Powered on and struck an arc on the the ground lead. I removed the welding wire and noticed that when the wire speed was turned all the way...
Could be a shorted output rectifier (diode). This would cause a lot of current pull, and therefore voltage drop (fan slowing down). The electrolytic capacitors are for dc voltage, and will blow with wrong polarity, which means ac voltage would be the wrong polarity half the time.
Feb 27, 2015 | Snap-On Welding Tools
Why does wire weld to tip when trigger is pulled when welding aluminium
The tip of the welder may need cleaned out, your feed speed might need slowed down, check the polarity is it straight or reverse?
Sep 20, 2014 | Welding Tools
Welder won't speed up to weld ?
What doesnt speed up to weld? the feeder? is the wire burning back? are you getting any wire? this is gmaw / wire right? sounds like it may be running slow
Jul 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
My wire feed welder wont slow down. I was welding some thick galvanized pipe and went to turn the wire feed down and it didn't work
the speed feed rheostat(control) is shorted or you've got a short on the board if it has one. Hopefully just your switch. Check for a short from the switch to the drive motor. Remember, electricity can and will kill you. Be safe
Bryan
Nov 04, 2013 | Lincoln Electric Lincoln Easy MIG 140...
Wire feed speed problem
Check the speed control board's voltage from the fan. If you are below 20 volts, 1- oil the cooling fan bushings to see if that helps. Otherwise adding in a discrete 24 volt 1 ro 1.5 Amp "control" transformer and a 2 ohm 50 Watt resistor in place of the fan's 24 volt tap (it rarely gets to 24 volts) should bring your speed up.
This does assume the board is fully functional.
Dec 27, 2011 | Welding Tools
I have A handler 14 the problem is that the wire feed speed does not work right if you set it to slow down from say 5 it acts like it is on one and you turn it to 5.5 and it acts like 8 ? help
Hi:
I don't know how old it's your machine but the most common problem for the wire speed control is the rheostat. The coil must be worn out and there is no more contact in the required range. This is an easy fix, call your local welding store and request the wire speed control. If you don't have a local welding store and you are in the USA you can check the link below for sales, call them of input your zip code for the nearest store location:
http://www.praxairdirect.com/webapp/wcs/stores/servlet/TopCategories1_10152_10051_-1
If you machine is not old (more than 3 years) then your problem will rely on the main pc board.
Sep 16, 2011 | Hobart Handler 140 Mig Welder
Wire Speed Increases when voltage increases
What is it doing? stabbing the wire into the work? The voltage is too low for the speed of the wire feed.. Turn up your voltage and slow down the wire. then increase your wire according to the speed of travel of weld. That is an awesome machine but it is still up to you to get the settings dialed in. Good Luck, Ned.
Sep 16, 2009 | Welding Tools
Washer will not spin properly
Try this:
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
Apr 06, 2009 | Washing Machines
Broan Allure QS3
The Problem is the wiring. Take the 2 screws retaining the metal plaque off underneath the filters. You will see the wires leaving the motor going into a "molex" plastic connector which connects two another set of wires going to the control board. Check to see if the wiring colors match from side to side of plastic connector. Ive only seen it happen once but it was exactly that. I do service calls for broan & Nutone
Jean-Marc
Apr 29, 2007 | Broan-NuTone Allure III QS330SS Kitchen...
Miller Electric Mfg Co 903394 Deltaweld 452 MIG Welder, 3- Phase, 15 - 38 V Logo
172 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
