Question about Kitchen Ranges
Kenmore gas range model # 790.79992100
After using the self clean cycle my range says 'dr' on the screen.
what does that mean, i can not clear it.
SOURCE: Kenmore electric Range 2005
No! I haven't found a solution to this problem yet. The range still gives the F-30 error every time we attempt to program the oven. It has done this since the power failure accompanying hurricane Ike that blew through here in September.
I am still searcing for the reason for the F-30 code for free or very low charge. It is not worth $15 for the info alone. Once I find out what is causing the F-30 code, I will contact you again concerning the repair. In the meantime, the top burners still work, We are using them for now.
I would be much more inclined to use your repair services if you did not charge so much up front for mere informational troubleshooting.
Posted on Nov 04, 2008
SOURCE: how to use the self cleaning feature of kenmore gas range
Posted on Nov 27, 2008
SOURCE: Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Posted on May 25, 2009
  • 1304 Answers
SOURCE: maytag gas oven after self-clean cycle door locked "dr" on displa
unplug it and let it stand for a few minutes
let the e- prom clear
plug it back in, should unlock
if it does not you need a new sensor
Posted on Oct 03, 2009
  • 149 Answers
SOURCE: kenmore 790 range with f1 code. Waht does this
it means probibly the EOC has failed and needs replacing that is a pcb called the electronic oven control
Posted on Mar 27, 2010
  • 15935 Answers
SOURCE: What does the errror code F90 mean?
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
0 characters
1 Points
Beeping sound with a message dr
I have a kenmore elite range model#790.9802. the walls of the oven expanded after a self cleaning cycle that the rake fall. i want to take the oven cavity out and reshape it. the problem / anyone know how the oven cavity comes out? I don't want to break the oven by trying to remove it the wrong way.
Sep 23, 2013 | Kenmore 75844 / 75849 Gas Kitchen Range
After self- cleaning my Kenmore Gas Range, I have not been able to get the 'Cooktop Lock' light turned off! So while I can use my oven for baking I can't turn the gas on the top of my stove! I have...
This may be a silly question but, did you just try turning off the circuit breaker for a couple minutes to see if it resets itself when you flip it back on?
Nov 21, 2010 | Kenmore Kitchen Ranges
I have a self cleaning kenmore stove and I cleaned it today. It cleaned beautifully, but when it finished cleaning the clock did not come on; a code DR came on. I looked in my manual and could not...
My mother cleaned her oven this weekend and she got the same message on her display. I could not answer what 'dr' stands for, but I was able to clear the message simply by unplugging and replugging the range.
Still if anyone know what it means, it would be a big help.
Sep 09, 2010 | Kenmore Kitchen Ranges
I do not know how to use the self clean feature on my Kenmore Gas stove
Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Please post back for any further assistance. Hope this helps...
Aug 28, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore Gas Range
Hey Alan- 'Self clean' sells. Techs call this function 'self- destruct'. Depending on age and number of previous 'clean' cycles, the control may have developed errors, or lockout switches may not function. If inside is thoroughly scraped, and bottom pan checked, removed, and cleaned if necessary, oven should work fine. Preventitive drip pans and a lot of aluminum foil keep the 'Self Clean' Gremlins away. Hope this helps- Thanks- ED
Feb 25, 2010 | Kenmore 73053 Gas Kitchen Range
Not sure what to do after using self cleaning gas stove
The self cleaning is used to loosen grease only, when it has ran its cycle you must take a damp coth and wipe away the excess. As for the window it is best to use something like vinegar , just dampen a cloth and clean the window. Rember, Damp only no excess water
Nov 10, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Maytag gas oven after self-clean cycle door locked "dr" on displa
Sep 27, 2009 | Maytag MGS5770 Gas Kitchen Range
Kenmore elite oven lock
None of above worked for me. But, gave me a clue. I pressed the Stop/Clear button for apprx 10 sceonds. the "door locked" flashed for 5 seconds and then cleared and the door unlocked. Panel worked fine after that.
Mar 10, 2008 | Tappan TGF320 Gas Kitchen Range
Kenmore Elite Range door locked error message
Hold down the number three button until the LOC message disappears and then the door will open.
Dec 23, 2007 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
